[RECOVERY][ks01lte] TWRP 2.8.5.0 touch recovery with F2FS support [15-02-2015]
  • 2 Antworten
SIII
-- Team Win Recovery Project --
Features:
- MTP auto mounting for SD / External SD
- Mass storage mounting for External SD
- Usb OTG
- Full SELinux support
- Supported F2FS (system, data, cache partitions)
- CPU temperature handled
- Thermal control and Performance profiles are active by
default
- Backup/Restore tested with 4.4.2/5.0.1 TW original samsung rom and CyanogenMod CM-11.0/CM-12.0
- Screen shot capture enabled (Volume (-) + Power) (saved in the "Picture" folder)
- Charge-Led
Changelog:
This is the changelog of CastagnaIT - Recognized Developer - Venice, Italy - XDA Forums TWRP versions releases, if you want read the original changelog of TWRP versions go to: TeamWin - TWRP
CHANGELOG for 2.8.5.0 [15/02/2015]:
-Fixed problem when wiping Data partition in F2FS
CHANGELOG for 2.8.4.0 [07/02/2015]:
-Added rewrite of TWRP settings after a SD wipe (prevent lost settings)
-Fixed mount F2FS or others filesystems to system, data, cache partitions
-Updated with latest changes from source
CHANGELOG for 2.8.4.0 [24/01/2015]:
-Switched to TWRP android-5.0 branch
-Brightness slider still does not work (it's a kernel related problem)
CHANGELOG for 2.8.1.0 [24/01/2015]:
-Updated kernel from cyanogenmod
-Screen blink on boot is not longer present
-Brightness slider no longer work (it's a kernel related problem)
-Added chargeled - adapted for samsung devices
CHANGELOG for 2.8.1.0 [27/11/2014]:
-Enabled mass storage mounting for external sd
-Fixed MTP mounting without external sd
CHANGELOG for 2.8.1.0:
-Initial TWRP release for I9506 (ks01lte)
Wie Installieren?:
Erst Installation eines Custom Recoverys mit ODIN 3.07 oder höher:
- Odin Herunterladen. Download Odin 3.09 - Odin download with Samsung ROM Flashing Tool
- TWRP_2.8.5.0-ks01lte.tar.md5 herunterladen.
- Samsung USB Treiber herunterladen und Installieren. Samsung USB Driver for Mobile Phones - Download
- Sicherstellen das nicht Kies oder noch Prozesse von Kies ausgeführt werden.
- Odin öffnen
- Das Samsung Galaxy S4 GT-I9506 in den Download Modus bringen ( Ausschalten, Volume Down + Home Button + An/Aus Taste gedrückt halten bis eine aufforderung kommt, ob sie hier an dieser Stelle weiter wollen. Ja wir wollen weiter unzwar mit VOLUME UP für Countinue). Das Android Männchen in Grün ist zu sehen, mit einigen Zeilen.
- Gerät mit einem Originalem USB Kabel an einem zuverlässig Funktionierendem USB Port anschließen. Jetzt einige Sekunden warten, da es beim ersten mal die Treiber Installiert. in Odin ist jetzt oben Links ein Blaues Feld mit 0:[COM und einer Zahl]. Des weiteren steht im Textfeld MESSAGE Added!!
- Sicherstellen das nur Auto Reboot und F. Reset Time mit einem Haken markiert sind.
- Jetzt auf AP klicken und die TWRP Recovery datei aus dem Zielordner auswählen.
- Auf Start klicken und einige Sekunden warten. Gerät startet neu. Achtung nach dem Klicken auf Start ist eure Garantie erlöschen.
Jetzt habt ihr ein Custom Recovery drauf und könnt alles für euer Gerät vorhergesehenen Dateien flashen. Oder unterwegs komplette System Backups auf eure SD Karte oder mit einem USB OTG Kabel auf einem USB Stick erstellen. Alles ohne Computer.
Kommend von älteren TWRP's oder eines anderen Custom Recoverys:
- Die TWRP_2.8.5.0-ks01lte.zip herunterladen.
- Die Datei auf den Internen oder Externen Speicher ablegen.
- In euer jetziges Recovery Booten (Volume up + Home + Power).
- Die Datei Flashen.
Viel Spaß mit dem Recovery.
Hinweis:
Wie immer gilt diese Anleitung auf eigene Gefahr!
Ich oder CastagnaIT - Recognized Developer - Venice, Italy - XDA Forums weder Android Forum & Community - Android-Hilfe.de noch Android Forum for Mobile Phones, Tablets, Watches & Android App Development - XDA Forums sind für Schäden aller möglichen Dimensionen nicht verantwortlich.
Download:
https://www.mediafire.com/folder/p3rwwfm7xn76x/TWRP
Danke für den guten Thread. Weiß jemand schon, ob es das neue TWRP für Gt-I9506 LTE-A gibt? Ich meine das TWRP 2.8.6.0 ;)
LG
Bis jetzt noch nicht. Verfolge es stetig auf XDA
