[Kernel][GT-I9500][1.0] Adam Kernel
  • 0 Antworten
ui_3k1
ui_3k1
Gesperrt
197
für diejenigen, die ein GT-I9500 besitzen, gibt es bereits einen Custom-Kernel.
Link zum XDA-Thread -> KLICK!
wanam schrieb:
-This kernel works only for Samsung 4.2.2 ROMs-
/!\ Flash it at your own Risk /!\
/!\ DO NOT TRY IT ON I9505 /!\
This kernel is built fom Samsung sources update1 with no modifications, Rooted with the latest SuperSu v1.25.
Tested on my I9500.
Features:
Built from Samsung sources Update1
Init.d support
Busybox
Built with Stock ARM Toolchain 4.6
AutoRoot with SuperSU v1.25
Download.
How to install: Flash it as PDA trough Odin (don’t check any additional options)
TODO:
  • ExFAT support
  • I9505 support
Sources (i will push it asap):
___________________________________________
Thanks to: Samsung; Google, Dsixda; Andreilux; GokhanMoral; Chainfire
Beste Grüße
Martin
