r00bst3r
Da ich auf meinem Galaxy S4 seid Wochen die X-Note Rom nutze war ich total begeistert das ich dieses hier auf XDA fand.
[ROM][N5100][Huge-Update-MultiDpi]X-Note build 5-MK1[30.11.2013]
[ROM][N5100][Huge-Update-MultiDpi]X-Note build 5-MK1[30.11.2013] - xda-developers
- Deodexed rooted busybox
- Stock boot.img
- Zipalign new applications at boot and db optimize
- Tweaks for battery, media, network, responsiveness.
- X-Note 4-way reboot
- Almost all apps are in place and updated
- New X-Note application to control the rom features and extra settings + OTA updater
- X-Transformer application to switch system dpi at 180 - 200 - 213
- many samsung applications reworked to have multi dpi feature and same layout at all screen densities (keyboard, launcher, calculator etc...) (only gallery need to be fixed at 213 dpi with xposed app density)
- fully customizable battery bar with animation all controlled by battery bar application (credits to pvyParts). To apply modification please restart only systemUI (read below)
- X note restart method application with option to restart only systemui to apply mods needed for battery bar (it will asks root permissions)
- X wallpapers application.... +60 wallpapers
- call recording and no mms conversion (xposed modules available in OTA)
- Enabled native multiuser support in fraework(4 user max) thanks Civato for the tip (bug: snote will work only with owner user, just use another application like papyrus for secondary users)
- KitKat launcher available (modded to fit the three density)
- Xposed framework
- Xposed per app density (set many options for each app included dpi density)
- boosted headphone audio level (pay attention with volume)
- boosted speaker audio level (pay attention with volume)
- customized some UI sound
- Pie control
- AD Away
- Cpu monitor
- Cpu spy
- New Multiwindow control app by @Xperiacle (super work as always)
- Modded tw launcher 9 homescreens (multi dpi of course)
- Fully themed notification panel, status bar and added:
lock button (single tap-lockscreen & longpress-reboot menu) + traffic meter + 101 customizable batteries (select using X-Note app) - Enabled secondary symbols on stock samsung keyboard
- Camera with shutter sound on/off option
- Browser with desktop view by default and exit option
- Sms will display sent time instead off received time
- Unlimited contacts join
- Greenify app
- Aosp calculator
- google Keep
- google calendar
- Multi dpi Play Store
- Chronus widget app
