[Recovery] ClockWorkMod (CWM) 6 by koush
  • 313 Antworten
Mal ne Frage, hat schon wer die unofficial 6.0.2.8 getestet?
... send with GNx - T-Rex 7.0 ...
https://github.com/CyanogenMod/andro...ommits/cm-10.1
Dec 16, 2012 - 6.0.2.3 is the most recent on ROM Manager, larger font for 1080p+, backup format is now tar again by default, format choice menu now displays correctly and shows currently chosen format, wipe battery stats option removed, sdcard partition menu fixes, fixes for dedupe and a crash during backup.
Dec 22, 2012 - 6.0.2.5 revision bump for new builds. No other changes.
Dec 28, 2012 - 6.0.2.6 fix backup format type error.
Dec 28, 2012 - 6.0.2.7 fix to not attempt sd-ext backups if on /data/media/.
Feb 6, 2013 - 6.0.2.8 updates for board specific events and support.
Mar 9, 2013 - 6.0.2.9 build branch change to cm-10.1: image improvements, text corrections; overscan compensation for large displays, add adb auth handling, improved error handling, exclude GMusic cache from nandroids.
(For an unofficial list of other changes between recent versions, see my previous changelog.)
Known Bugs:
- Sideload does not have a confirmation, so if triggered by mistake a hard reset is required if no USB connection is available to make it exit.
  • cwm-recovery-clockwork-touch-6.0.2.9.b21273-maguro.zip
  • cwm-recovery-clockwork-6.0.2.9.b21333-maguro.zip
Reaktionen: Radagast und blur
Version 6.0.3.1 ist verfügbar.
Link war Müll (Danke Tapatalk^^). Anhänge s. nächster post ;)
osm0sis schrieb:
CWM Official 6.0.3.1 Changelog - maguro:
https://github.com/CyanogenMod/android_bootable_recovery/commits/cm-10.1
Apr 13, 2013 - 6.0.3.1 is the most recent on ROM Manager, fix segfaults on non-/sdcard/ devices and writing recovery version/device to /sdcard/0/clockworkmod/, clean up minadbd, save recovery log with backups, extend courier font for minui, allow cancellation of sideload and triggering via command.
Known Bugs:
- Key test does not have a confirmation, so if triggered by mistake a hard reset is required if no USB connection is available to make it exit.
Fastboot Images Download: http://clockworkmod.com/rommanager
Reaktionen: Don_Ron und djxspeedy
Hier mal ein link zur flashbaren Variante:http://forum.xda-developers.com/attachment.php?attachmentid=1882803&d=1365934378
Known Bugs:
Fastboot Images Download: ClockworkMod ROM Manager - Recoveries
Attached are recovery flashable zips of both the touch and non-touch versions.
anhänge hinzugefügt
  • cwm-recovery-clockwork-6.0.3.1-maguro.zip
  • cwm-recovery-clockwork-touch-6.0.3.1-maguro.zip
Reaktionen: slideluxe, Don_Ron, Bondar und 2 andere
Hab ein Backup mit CWM 6.0.3.1 gemacht. Das will ich auf meinen PC verschieben, nur der Pfad "mnt/shell/emulated/clockworkmod/backup" ist ja über Windows gar nicht erreichbar. Kann man den Sicherungsort irgendwo festlegen?
Aufm Device nen Explorer mit Root-Rechten installieren (zB Root-Explorer) , ...
Damit hangels Du Dich über data / media nach clockworkmod / backup -> dort den gewünschten Backup-Ordner per Lang-Druck auf KOPIEREN (oder auch verschieben - je wie Du es willst) und wieder bis 0 (Null) zurückgehen - auf Null klicken und dort dort irgendwo in einen von Dir dafür erstellten Ordner hineinkopieren. Nun ist diese Kopie auch nachm Koppeln Device<->PC aufm sich am PC öffnenden Ordner sichtbar und Du kannst freei nach Wunsch irgendwo aufn PC oder Lappi ablegen -> Voila das wars.
@Don Ron
Also data/media..ja jetzt gehts, war im mnt/shell...dort ging kein Kopieren, ziemlich verwirrend diese Verzeichnisstruktur. Danke nochmal
Kein Problem - gerne. Nur immer schön drauf achten nen Explorer/Datei-Manager zu nehmen bei dem Du auch Rootrechte zuweisen kannst - sonst kommst nicht bis in die unterste Verzeichnis-Ebene bzw falls doch kannste aber dort nix machen.
Gruß und noch nen schönen Abend - Ronni
Gibt es eigentlich mittlerweile eine Möglichkeit, das Extrahieren von Daten aus dem Gerät mittels ADB Pull in CWM zu unterbinden? Klar, man kommt so nur an die einzelnen Dateien und nicht an irgendwelche Passwörter oder so, aber unschön finde ich das trotzdem...
Wenn ich einen Image-Zip Backup mache, wie groß sollte die Datei am Ende werden? Mein Zip-Backup ist nur 249 MB Groß. Ich kann mir schwer vorstellen, dass das ein komplettes 1:1 Image sein soll. :confused: Auf dem Nexus habe ich gerade mal die hälfte an Speicher Belegt (ca. 6-7 GB).
Habe mal eben eine image-zip erstellt, die Datei ist bei mir
120 MB
groß ... aber:
u dürftest auch einen Ordner image haben, da sind auch Dateien drin. Da ist bei mir u. a. die system.ext4.tar.a drin mit 202MB und somit wären es 320MB.
Dabei dürfte es sich aber auch nur um Daten aus dem System handelt ... daher so wenig Speicher.
Dennoch ist ein "normales" Backup ja um die 600MB groß oder auch mal noch mehr ....
Dürfte dennoch passen, probiers doch mal und mache vorher ein normales Backup, kann ja nichts passieren ...
Reaktionen: Happosai
Danke!! :)
CWM Official 6.0.3.4 Changelog - maguro:
Jul 23, 2013 - 6.0.3.4 is the most recent on ROM Manager, update zlib, SELinux warning display changes, add "headless" mode.
Known Bugs:
- Now that "No file_contexts" warning is not suppressed, it seems to display all the time on some configurations.
  • cwm-recovery-clockwork-6.0.3.4-maguro.zip
  • cwm-recovery-clockwork-touch-6.0.3.4-maguro.zip
Reaktionen: Radagast und Don_Ron
CWM Official 6.0.3.5 Changelog - maguro:
Jul 23, 2013 - 6.0.3.4 is the previous official, update zlib, SELinux warning display changes, add "headless" mode.
Jul 29, 2013 - 6.0.3.5 is the most recent on ROM Manager, remove fix permissions, add reboot options to advanced menu, fixes to Superuser for JB4.3.
Known Bugs:
  • cwm-recovery-clockwork-6.0.3.5-maguro.zip
  • cwm-recovery-clockwork-touch-6.0.3.5-maguro.zip
Reaktionen: blur, Don_Ron und qu4nd
CWM Official 6.0.3.6 Changelog - maguro:
Jul 23, 2013 - 6.0.3.4 is a previous official, update zlib, SELinux warning display changes, add "headless" mode.
Jul 29, 2013 - 6.0.3.5 is the previous official, remove fix permissions, add reboot options to advanced menu, fixes to Superuser for JB4.3.
Aug 13, 2013 - 6.0.3.6 is the most recent on ROM Manager, updated Superuser su_daemon install-recovery.sh method and related JB4.3 detection, update wipe data confirmation, add partition type to sdparted.
Known Bugs / Notes:
- "No file_contexts" warning will display on every boot because it is no longer suppressed. This has no effect on functionality.
- If you're using the SuperSU daemonsu then you may want to create /system/etc/.installed_su_daemon to suppress the CWM dialog to remove install-recovery.sh (required to run the root daemon on ROMs without a native service).
  • cwm-recovery-clockwork-6.0.3.6-maguro.zip
  • cwm-recovery-clockwork-touch-6.0.3.6-maguro.zip
Reaktionen: Fletch, motoroller, Don_Ron und eine weitere Person
frage an den Thread ersteller.. kannste ma ersten post aktualisieren mit neuster version bidde ?
Hey Leute, ich glaub ich bin grad bisschen zu blöd. Aber ich finde meine Backups nicht unter /sdcard/clockworkmod/....da ist kein Backup Ordner o.o aber wenn ich in die recovery boote sehe ich unter restore zwei Backups, an die ich mich auch erinnere. Nun wollte ich eins von beiden löschen, aber finde den Ordner nicht mit ES....
/data/media/clockworkmod/ ...
die sd-karte ist unter
/data/media/0/ ...
wenn Du die Backups dahin kopierst, kannst Du sie auch auf ein anderes Gerät übertragen.
Reaktionen: Riefi
