Tello ROM
  • 4 Antworten
kenosis
Anybody using Tello ROM? If yes, how can I change the color of Time Display which is Top-right corner of phone screen.
I cannot see the time because it is in black color and the background is also.
Anzeige
  • Gerade eben
  • Neu
Hallo kenosis,
schau mal hier: Tello ROM. Dort wird jeder fündig!
you have to move the service.jar to system/framework and overwrite the original one~
the file you meant should be "services.jar", i think ;) not a big thing but won´t work without the "s" at the end..
@kenosis
after copying/moving the file to /system/framework, don´t forget to set it´s permissions to 644! (read and write for user; read for group and also read for others)
my bad ^^ sure it's services.jar
Please use the Thread from TelloBJK for questions.
--> Closed!
