MoDaCo Superboot mit Root
  • 7 Antworten
Laberistikus
Laberistikus
Stamm-User
205
Hiho,
hier schon mal eine wirklich sehr einfache Geschichte zum rooten des Nexus S.
Introducing.... Superboot!
Superboot is a boot.img that when flashed, will root your device the first time you boot (installing su and the superuser APK). No need to flash the system partition, no need to use ADB, no messing with the contents of your data partition, no overwriting the shipped ROM on your device, just flash the boot image using the instructions below and you're done!
APPLY THIS AT YOUR OWN RISK!
Before download, you need to check your device 'about' screen to determine which superboot version you need.
  • Superboot for GRH78 - Superboot - DOWNLOAD (ROMraid Load Balancing) - MD5: a0c8b769986876bf5cb079b2fd9309ff
  • Superboot for GRH55 - Superboot - DOWNLOAD (ROMraid Load Balancing) - MD5: 809a8e41ae8f0bb88b870cf1865aedff
The superboot image is also 'insecure', allowing you to use 'adb remount' as well as having full ADB root access to your device.
How to use Superboot - Windows, Linux and OSX
- Download the Superboot zip file above and extract to a directory
- Put your device in bootloader mode - Turn off the phone then turn on with the 'volume up' button pressed to enter the bootloader
- WINDOWS - double click 'install-superboot-windows.bat'
- MAC - Open a terminal window to the directory containing the files, and type 'chmod +x install-superboot-mac.sh' followed by './install-superboot-mac.sh'
- LINUX - Open a terminal window to the directory containing the files, and type 'chmod +x install-superboot-linux.sh' followed by './install-superboot-linux.sh'
Note: If you are using a retail Nexus S, you may need to unlock the bootloader first, using './fastboot-windows oem unlock' (or the appropriate version for your PC). Note that the OEM unlock sequence wipes your device (including the internal SD storage!)
Enjoy!
23/Dec GRH78: Superboot - rooting the Nexus S - Android @ MoDaCo
und hier noch der Link zum Orginalthema bei MoDaCo.
Ich werde jetzt in den kommenden Tagen mal alle Anleitungen, zum Rooten, Bootloader entsperren und CR insrtallieren auf Deutsch zusammenfassen für jene, welche des Englischen nicht so mächtig sind.
Lieben Gruß,
Gregor
der Guide hat super geklappt. Nur die USB Treiber waren erst etwas launisch! :)
Wie kann ich denn wieder alles rückgängig machen und das standard boot.img einspielen.
Ich würde gerne die Variante von koush zum rooten verwenden und daher die MoDaCo (Paul) Variante wieder rückgängig machen.
MFG
MFG
Schau mal hier im CM7 !
danke mache ich !
hab grad cm7 nightly #14 drauf gemacht. ich komme von einem iphone 3g und hab jetzt seit 10 tagen das nexus s. und ich dachte besser gehts nicht mehr, aber cyanogenmod setzt nochmal eins drauf. WAHNSINN!!!
stiefa00 schrieb:
danke mache ich !
Was bringen die Nightly #14 ??
Viele Verbesserungen zu Gingerbread.
Nur ein Beispiel: Wenn du auf App am Desktop gedrückt hältst, kannst du sie jetzt auch komplett deinstallieren, umbennen oder einfach nur verschieben oder halt vom Desktop entfernen.
Sorry ich poste heute abend / morgen mittag mehr, muss das jetzt erst alles ausschecken!
Edit: Oder wenn du die Notificationbar runterziehst, kannst du oben WLAN / BT, GPS und SYNC ein und ausschalten!
stiefa00 schrieb:
................ App am Desktop gedrückt häst, kannst du sie jetzt auch komplett deinstallieren, umbennen oder einfach nur verschieben oder halt vom Desktop entfernen.
Das macht der integrierte ADW Launcher...........
Ok, ich denke das habe ich dann auch alles.
ah okay, kk man merkt ich bin allg. noch bissl neu in der materie! :D
