GalaxyStorm
Dauer-User
- 424
The VeinDroid Team, was born by first of, by two friends with a passion for modding. We started with toy, we moved to the PC and now we have a great interest in the SmartPhone ... We made some mistakes and they will continue to commit, but in the end all of our "experiments" we have found one thing in common ... the goal is was always obtained, and with great success (personally speaking).
Our project is ambitious, full of purpose and certainly the difficulties we will encounter will not stop us easily ... not by chance that our slogan is "Nobody could stop us Nobody will stop us." or at least be assured that we will try
Finally, Thanks in advance all those who will support us / bear through donations and any other form of help.
Greetings to all from the founders of VeinDroid Team.
Mirko (XaToR)
Francesco (Zeus)
The Team work on three devices (Note 2, S3 and Galaxy Tab 2 7.0), maintaining a common graphics reworked as simple as possible while increasing small customizations that we think make the terminal look more pleasant. We started with small graphic mod (for those who do not like, always recoverable) and in future versions if they feel it is appropriate we will implement new mod. Under the functional aspect we place great emphasis on the excellent base samsung, deleting apk that we believe are not used by many users or that are replaced with alternative apk ... The fluidity and stability will be another our strength, although currently these two features are difficult to view an excellent basis for improvement.
2. Go into Recovery mode
3. Make the three wipe (Wipe Data / Cache / Dalvik Cache)
4. Flash it!
v1:
- Samsung Base LJ1
- Modem LIH
- Kernel Perseus alpha24 (Thanks to perseus)
- Bootanimation VeinDroid HD by BigDenn (VeinDroid Team)
- Deodex, Zipalign, Busybox and Root by VeinDroid Full Team
- Reworked SystemUI with small graphical changes by VeinDroid Team
- Removed some apk system
- 15 Toggle + lidroid-res by VeinDroid Team
- Removed rebound effect of the toggle by VeinDroid Team
- Implemented 4-way menu (Reboot, Hot Boot, Download and Recovery) by VeinDroid Team
- Implemented call recording by VeinDroid Team
- Removed incremental ringtone by VeinDroid Team
- Implemented apk VeinDroid Team
- Implemented new apk on MultiWindows (Thanks to Lennyuk)
- Removed conversion from SMS to MMS and increased the number of selected contacts to send a text message by VeinDroid Team
- Reworked framework-res by VeinDroid Team
- Reworked build.prop
- Various Tweak to increase the speed of the system
v2:
- Base LJ7
- Updated kernel perseus 25.4
- Added script init.d (GPU Tweak) for best battery drain (thanks kakashi84)
- Updated Busybox
- Updated SuperSU
- Implemented UpdateMe
- Implemented new App VeinDroid
- Integration of app Multi Window Control App xda version (thanks Legendk95 http://forum.xda-developers.com/show....php?t=1953705 )***
- Reintegrated apk stock (SecEmail, SecExchange, ChromeBookmarksyncadapter)
- Incremented of 25% battery icon
- Fixed small graphic bug
v3:
- Downgrade kernel perseus alpha 25.3 (25.4 have audio bugged)
- Changed Modem to LJ4 thanks to kakashi84 and vrealino for testing
- Updated script GPUTweak for best battery drain thanks to kakashi84
- Deleted SMS from Call Log
- Implemented on Settings, the category VeinDroid Mod, with following apk:
- VeinDroid OTA (Apk for check OTA Update, you can download too "Gadget by VeinDroid Team, Mods, Kernel, Themes, Modem e Applications")
- QuickPanel Settings (For editing Toggle)
- Light Manager (Can set up the LED Notification, with color and other things)
- CPU Spy (Check CPU stats and Deep Sleep)
- MultiWindows Control Trial (Can add 2 apk on the MultiWindows, required reboot)
- AdAway (Delete ads from file hosts)
- VeinDroid App (Official Application of VeinDroid Team)
- Implemented Adobe Flash Player
- Solved little bug for fast speed
XDA Dev-Host: Dev-Host - The Ultimate Free File Hosting / File Sharing Service
AndroidFileHost: VeinDroid_v1_Galaxy_Note_2.zip ::. | by VeinDroid Team for Galaxy Note 2
If you want contact us, go to VeinDroid Blog
If you like our work, consider a donation
XDA
