[ROM] 17 Aug Gr3 XXKH1: MoDaCo Custom ROM for the Galaxy S II (stock-style/vanilla)
  • 17 Antworten
Gast5050
Gast
I'm pleased to present my MoDaCo Custom for the Samsung Galaxy S II! READ THIS WHOLE POST BEFORE YOU START! No, really, it contains everything you need to know.
About MoDaCo Custom ROMs
MoDaCo Custom ROMs are based on official ROMs - either shipping or leaked. A MCR release is designed to feel as far as possible like a stock ROM, with optimisations, tweaks and complimentary additions that enhance the user experience. The aim of a MCR is to be ultra reliable for use on an everyday device.
Requirements
In order to flash this ROM, you need ClockworkMod recovery installed. Once you have that, MCR is completely 'Odin Free' including the baseband flash. If you have yet to install ClockworkMod, you can find it (as part of CF-Root), in this topic.
The ROM is installed at your own risk. The ROM should be installed using ClockworkMod. A wipe IS mandatory, but if you do encounter issues, please wipe and try again before reporting them here.
Features Included (many optional)
  • Based on the XXKH1 release
  • Include a customised version of CF-Root
  • Packaged for ClockworkMod
  • Rebuilt using the MoDaCo MCR optimisation scripts
  • Full up to date Google experience + additional apps (including new look Market)
  • 'Stock Gingerbread' iconset
  • 'Stock Gingerbread' versions of almost every app available
  • HSPA icon differentiation ('H' icon when transferring data via HSPA)
  • Connected icon differentiation (green when connected to Google services)
  • 'CRT effect' on screen off
  • Camera without battery limitations
  • Ugly progress bar fix
  • su / Superuser.apk root
  • Busybox
  • Semi-transparent notification pull-down
  • Optional SIP over 3G
  • Modified build.prop to show full Market catalogue
  • sicopat's advanced power menu / battery percentage mod
  • Options to mute many of the annoying system sounds
  • Option to mute camera sounds
  • De-odex Browser lag fix (thanks brightidea!)
  • Bluetooth enhacements (thanks stevenz)
  • AppWidgetPicker
  • Additional application stores
  • Google Voice and Video talk
  • SIP calling over 3G
  • De-odexed
  • Many, MANY optional and additional apps in the kitchen
  • Much much much more!
Changelog
Please see the post below this one for the changes in each release.
Installation
To install this ROM:
  • Download the zip file of your choice and copy to your SD card
  • Restart your device in recovery mode
  • PERFORM A NANDROID BACKUP FROM THE MENU
  • Select the option to apply an update zip, and select the zip file you copied to your memory card
If you have problems with Market licencing, check your device date!
First boot may take a while - be patient while it carries out it's pre-dexopt. It's worth it!
Downloads
Prebake download
  • Gr3 (default options - please view the kitchen to see what is selected by default) - DOWNLOAD - MD5: 534411e455dabe3b24d0807df702cbe7
  • Gr3 (vanilla edition - Samsung apps replaced by Google stock equivalents, most Samsung added apps removed) - DOWNLOAD - MD5: 5d69927f7325d567174cc99adaca788c
  • Gr3 BLN patch (apply to either of the above ROMs to add BLN compatability) - DOWNLOAD - MD5: 9c38659df4f663c5ee62a9bb7eef52fb
Kitchen download
  • an online kitchen is also available in the MoDaCo topic for you to bake a Custom Custom ROM.
Thanks
It's impossible to mention everyone who contributes to the Android community by name, but to everyone out there who does great work and shares it with us all - you have my gratitude and respect.
Future Updates - READ THIS!
By providing this ROM I am not implying in any way that future updates will follow. Due to limits on my time and the fact that I have a large number of devices for short periods of time, it isn't possible for me to continue providing ROM updates indefinitely. Please do not donate / sign up on the assumption that future releases will be available (I don't want you to be disappointed!).
And finally...
Details on how to donate should you wish to do so are in download topic at MoDaCo.
Enjoy!
Changelog
16 Aug 17:00
  • Updated to MCK r3
  • Fixed init.d script running
16 Aug 09:30
  • Gr2 release
16 Aug 09:00
  • Added CSC regions
15 Aug 20:00
  • Updated to MoDaCo Custom Kernel r2 in BLN and no-BLN flavours
15 Aug 14:00
  • Added MoDaCo Custom Kernel r1 in BLN and no-BLN flavours
  • Added terminfo support to boot image (MCK only)
  • Added tmpfs Market download configuration (MCK only)
  • Added SIP XML in permissions directory (user request)
  • Added patched E-Mail APK (administrator removal) by gauner1986 (user request)
  • Added patched SQLIte library (sync removal) as discussed by ownhere (user request)
  • Added app_process smoothness patch by nikademus (user request)
  • Fixed 'CRT effect blockiness' issue
12 Aug 15:30
  • Modified build.prop to solve problem with apps not appearing in the Market (masquerade as Nexus S, option to revert)
  • Added Google Videos
  • Added sicopat's advanced power menu / battery percentage mod as an option
12 Aug 13:25
  • Added option to mute camera sounds
12 Aug 13:15
  • Added stock Gingerbread Email application
  • Updated kitchen text to note dependency on Social Hub for Samsung email application
12 Aug 11:40
12 Aug 10:00
  • Shell script fixes (thanks stevenz)
  • Bluetooth enhancement option (thanks stevenz)
  • AppWidgetPicker added (user request)
  • GetJar app added
11 Aug 16:10
  • Updated Google Talk to the latest release (with voice and video chat)
11 Aug 15:20
  • Corrected icon resource in stock Google Messaging APK
11 Aug 15:00
11 Aug 14:50
  • Added stock Google Calendar option
11 Aug 14:15
  • Added sound options (boot, battery full, charger disconnect)
11 Aug 12:45
  • Initial Release
Quelle:
[ROM] 17 Aug Gr3 XXKH1: MoDaCo Custom ROM for the Galaxy S II (stock-style/vanilla) - xda-developers
Reaktionen: Kjetal
Der hat es eigentlich drauf der Typ bei gelenheit werde ich das mal testen.
Geil ist das der sein Kitchen mit eingebaut hat..
Hatte vor geraumer Zeit auch einige Modaco ROMs und die liefen super
Cool, Paul und sein Rom aufm S2.
Nur leider etwas zu spät für mich ;)
Mein LG war nie ohne sein Rom, bis halt die CM RC kam..
Der Junge baut echt top Roms!
Also läuft bei mir exzellent.
Hab mir aus der Kitchen n recht schlankes Rom gebastelt, mit nur dem Nötigsten dran. Bisher alles super stabil und flüssig, wie halt aufm Desire auch schon.
Den Kernel hab ich nur durch den Ninphetamine 2.0.5 ersetzt, aus Gewohnheit.
Aber soweit: :thumbsup:
30,-Pfund für ne AddFree version? Soll das heißen das in der 10,-Pfund Version Werbebanner auftauchen beim telefonieren? :scared:
ich glaube nicht dass die Rom's mit werbung zugemüllt werden, sondern eher die Modaco Website... aber wer weiß....
Die Kitchen ist an den Premium-Zugang gekoppelt. Sprich das ROM ist völlig Frei von Werbung. Das Einzige was etwas kostet ist der Premium oder AdFree Account von Modaco. Der AdFree Account sollte ausreichend sein für die Kitchen, das eigentliche ROM in ner Standard Version kann aber ohne Premium geladen werden.
Reaktionen: BigBug
"Ausreichend" ist gut, Adfree ist das teuerste... ;)
Naja, Werbung auf ner Website schluckt mein Opera schon gut weg, da bekomme ich selbst auf Seiten wie b*ld.de kaum noch was zu sehen... :flapper:
Aber das eigentliche ROM in der Standardversion wird bei mir mit den obigen Links auch immer nur angezeigt mit "Sorry, this Online Kitchen is available to Premium members only"...
hmmm...:confused:
Also wer das zahlt ist selber schuld. Alles was man bei dem bekommt gibt es wo anderes umsonst daher null mehrwert. So was nennt man Abzocke.
hmmm...:confused:
Du unterliegst einem Irrtum:
MoDaCo Ad Free + Online Kitchens
£9.99 Add to cart
MoDaCo Plus + Ad Free + Online Kitchens
£29.99 Add to cart
Nun sag mir bitte warum die AdFree die teuerste ist?
Ich finde den Preis für ne Kitchen die so super Läuft mehr als gerechtfertigt. Wer da Abzocke ruft ist absolut geizig ... bei nem Handywert von 500 Euro nicht verständlich.
Ich bin nicht geizig und habe schon viel gespendet daher weiß ich wann was abzocke ist und wann nicht. Also etwas vorsichtig sein mit solchen aussagen wer geizig ist.
Hm, laut Board Statistik hat Monaco aktuell 755.861 Mitglieder.
Davon, schätz ich jetzt einfach mal, haben mit Sicherheit 10-20% nen Plus oder Ad-Free Account. Die meisten die die Roms oder die Kitchen ausprobiert haben sind ziemlich begeistert...
Fallen soo viele auf soo ne "billige Abzocke" rein? :scared:
Glaube kaum. Habs ja selber gemerkt, natürlich kann man sich seine Roms auch per Hand so hinbiegen dass sie einem passen, ist aber mit ungleich mehr Aufwand und oft auch Problemen verbunden. So simpel wie in der Kitchen isses mit Sicherheit nicht.
Von daher finde ich den Preis absolut verträglich.
hmm, ich weiß nicht obs erlaubt ist, aber wenn doch, würde ich wem mal was backen bei modaco. habe vom lg p990 noch den premium account.
bei interesse bitte melden
Bevor man hier von Abzocke:scared: usw. schreibt, wollte ich einfach mal darauf hinweisen, dass es sich hier immerhin um Projekte von Paul O´Brian alias MoDaCo handelt...
Wer ein bißchen länger in der Android Szene unterwegs ist, dem sollte dieser Name geläufig sein... Ich würde Paul in einem Atemzug mit Steve Kondik (Cyanogen), JesusFreke (einer der genialsten Köpfe in den Anfängen von Android), Chris Soyars, Koush...nennen! Noch vor Chainfire und Supercurion usw...
Ich glaube, dass man bei allen o.g. (und noch einigen mehr) davon ausgehen kann, dass sie KEINE Abzocker oder Betrüger sind. Ganz davon abgesehen, leben wir hier alle von den selbstlosen Dev´s, die uns tagtäglich mit genialen Ideen überraschen...hin und wieder kann man ruhig mal über eine "Aufwandsentschädigung" für diese Dev´s nachdenken ;) Und als eine solche kann man diese 9,99€ auch einfach sehen...
Gier frisst Hirn, dass ist doch lange bekannt...
Bin seit Jahren bei MoDaCoPremium Mitglied und habe mir ein GR5 erstellt, und bin absolut begeistert, gerade was Akkulaufzeit und Stabilität angeht.
Kann mich nur anschliessen! bin seit dem Nexus One, über zum Desire und nun beim SGS2 immer Paul treu geblieben.
Hey, mal btt...
Ich hatte auf meinem Hero damals auch Modaco und war sehr zufrieden.
Cyanogen kommt ja nicht aus dem Eimer, wie siehts hier aus?
Mal mit Lite'ning verglichen?
Bin damit auch recht zufrieden...
Lg
_____________________________________
Mit freundlicher Unterstützung von Tapatalk auf meinem SGS II ;-)
