[Sammy-ROM][ICS] *25.05.12* ZetaROM_v2.0 [XPLPD] - Style and Elegance
  • 19 Antworten
FotoMichi
FotoMichi
ZetaROM CLASSIC Theme STOCK v2.0 - XWLPD 4.0.3-------SOON THEME ZETA
INFO´S HIER--->http://translate.google.com/translate?langpair=it%7Cde&u=http://zetaserie.blogspot.it/
DOWNLOAD 2.0 Classic:https://www.wuala.com/davidez25/Documenti/ZetaROM%20CLASSIC%20v2.0%20-%20GT-I9100_LPD_4.0.3.zip/?key=PBv7GFnOTwtV
Changelog:
LP5 Modem - Kernel Siyah v. 3.2.5.1 + cwm manager
Rooted - Busybox - Deodexed - NO WIPE - Zipaligned Cars - Hosts Adblocking
Improved Touch Sensitivity - GPU Acceleration
WiFi tweak saving battery - Scrolling improved responsiveness
SONY BRAVIA: Increase the quality of photos and video
Modified Dalvik VM 180MB heap size
The user interface rendering with GPU
Internet connection ottimizzat - Fewer delays in calls
Sensor Screen Delay off - Memory management improved
Added Power Panel: Reboot - Download - Hot boot
MicroSD Card speed 1024KB / s
Market connections Fix Speed
Switch-off the camera when the battery charge 0%
Video / audio profiles 24-20Mbps/192Kbps_44100Hz
Disabled increased volume for incoming calls
Removal of the options for reducing noise in call
Off SMS to MMS - no autoconversion
Deactivated limit number of contacts for the simultaneous sending
Increase the maximum size of messages sent with 300 KB to 1 MB
Increase the response speed automatic brightness control (ABC)
Faster and smoother transitions of brightness (ABC)
Custom Brightness - static bus frequencies
DeepSleep custom levels - Tweaks GPS - Tweaks WIFI/3G/4G
AutoBackup EFS Folder - YoutubeHD Mod (Wifi-3G) - Mod LockScreen
Tweak your SD card for added control features: Lock Screen:
ICS / SAMSUNG
Text display screen unlock: ON / OFF
Torch lock screen when you press the home button: ON / OFF
Delay action to pressure the home button: ON / OFF
Changed Sound Power - Added pach font characters
Call Recording no Full Screen
15 toggles the status bar + battery percentage %
Silent Camera - eliminated sound battery
Mod. Play Store
Other extras: Audio Beats with a better sound quality and power thanks to app volume + - youtube hd that is 3g wifi and much more ....
Added apk:Touchwiz Galaxy S3, 80 pack font, SwiFTP, CMW Manager, FasterFix
Added soung notification Galaxy S3
Werd der Rom mal ne Chance geben obwohl (!) Ich aosp / aokp Roms bevorzuge :D und ein Link zu xda - thread wäre nicht schlecht :thumbup:
Super Rom, gefällt mir sogar besser als das GoA. Sehr smooth und das Theme ist klasse finde ich.
Reaktionen: soxian
Seit gestern auf der Suche nach einer neuen ROM? :p
Flashsuchti *hihi*
Ich habe die Lite Verison installiert und läuft bis jetzt mit dem Syiah Kernel sehr gut.
Neue Version Online!!!
Changelog:
ICS / SAMSUNG
Mod. Play Store
Thread-Titel aktualisiert... ;)
Reaktionen: FotoMichi
Bin ich blind, oder gibt es wirklich keinen Download-Link?
Auch wenn ich blind bin, zu bloede um eine ROM zu finden bin ich nicht, sprich ich habe sie woanders gefunden.
Aber ich scheine zu bloede zu sein um den LINK zu sehen den du reingestellt hast, also dieser hier
ZetaROM SERIE
ich finde den auf den vorherigen Seiten nicht
Naja... 3 Posts vor deinem "bin ich blind?"-Post steht der XDA-Link... :ohmy:
Hoffentlich kommt bald das Theme dazu. Sonst läuft das Rom sehr gut.
Naja man sollte schon in seinem thread im ersten post alles auf einmal haben, xda link und download link.^^
Stell dir vor der thread hätte 200 seiten... Dann wäre es mies oder? :p
Natürlich, sag ich garnichts dagegen. Aber da der Thread bis dato nur 1 Seite hatte, hätte man ruhig die paar Posts lesen können :) So genug OT :o
sorry, vergessen :(
downloadlink mit info´s hinzugefügt
Entschuldige mal bitte.
Der XDA Link ist nicht unbedingt der Download Link, ich denke das sind wir in diesem Forum etwas komfortabler anrangiert und haben nicht jnur den Hinweis auf den Original Thread sondern auch den Downloadlink in der Vorstellungen einer neuen Costum ROM sprich Opener. Und wenn ich mir ROMs bei XDA anschauen will, dann geh ich sofort in dieses Forum und nutze nicht den Umweg ueber dieses hier. :D
Aber hat sich ja erledigt mittlerweile
ZetaROM CLASSIC v2.0 - XWLPD Online!
Infos und Download, siehe Post 1. Habe sie mal installiert, sieht sehr sehr schön aus! Alles auf Deutsch(!) läuft Stabil und Solide.
Kann ich jedem nur empfehlen!
