r0b
Ehrenmitglied
- 4.349
	- Based on the latest Android 4.4.2 Official Samsung Galaxy S5 (G900F) Firmware XXU1ANE2
 - *** With Echoe's own custom S5 "AEL" Kernel*** (Check post #4 for Kernel Specifics and Download Links)
 - Prerooted (SuperSu v1.94)
 - Zipaligned
 - Deodexed (smali 2.0.3 and baksmali 2.0.3)
 - Ex-FAT Support
 - Custom Echoe Rom Settings allow for FULL CUSTOMIZATION of your phone as well as access to the Echoe Kitchen for OTA mods, tweaks, apps and themes (CREDITS: Ficeto for his CustomSettings.apk)
 - The Amazing OG Battery Mod with the ability to choose over 85 beautiful battery icons
 - Echoe Extended 4-way Power Menu
 - Call Recording
 - With Viper4Android
 - Fully modded SecMms app:
- No SMS to MMS conversion for messages
 - No SMS to MMS conversion for emojis
 - Enabled Group Messaging
 - Show sent (real) time instead of time received
 - Enabled Save/Restore function of your Messages to your SD Card
 - Enabled split view mode on landscape screen
 - Enabled the Screen on/off toggle
 - Enabled Folder View Mode
 - Enabled the ability to send a message to more than 1000 recipients at the same time
 - Increased the SMS hour limit to 1000
 - Increased the Max MMS size to 2048000 bytes
 - Increased the MMS Image size to 4096x2048 [8.4MP]
 - Implemented by default up to 7 apps in toolbox
 - Keyboard with secondary symbols for all languages enabled
 - Enabled Call Button in Contacts
 - Added Shutter Sound Menu in Camera Settings
 - Enabled All System Languages by Default (thanks to the GREAT wanam!!!)
 - Exit menu in stock web browser
 - Enabled Quadview (up to 4 windows) in multiwindows
 - Added custom color in Calendar (Sat and Sun are a bit more colorful now)
 - Extended Speed-Dial Entries to 100
 - Per APP DPI Control
 - Added Latest Xposed Framework (Credits: rovo89), Xposed Framework: XDA THREAD
 - Added Wanam Xposed Module: (Credits: Who else??)  XDA THREAD
	 - Added Gravity Box Xposed Module (Credits: C3C076), Gravity Box: XDA THREAD
 - Added PerApp DPI Xposed Module (Credits: Tungstwenty): Per APP Density Setting for Every APP: XDA THREAD
 - Added AdAway (THANKS TO THE CREATOR: mrRobinson): XDA THREAD [/B]
***UNIQUE 3 in 1 Aroma Installer with the following options***
- ROM Installer
 - Kernel Installer
 - Bloat/ Mods Installer
 - Wipe or No wipe (PLEASE DO A FULL WIPE FOR THIS VERSION!!)
 - 3 Types of Installation (Full, Slim and Custom)
 - Bloat (Choice of approximately 20 apps that are considered bloatware to choose from)
Kernels:
- Stock NCE Kernel
 - Exclusive Custom S5"AEL Kernel" (check post #4 for Kernel Specifics)
TW Launcher Mods:
- Stock Modded for Speed
 - 4X5, 4X5 Modded for Speed
 - 4X5, 5X5 Modded for Speed
 - 5X5, 4X5 Modded for Speed
 - 5X5, 5X5 Modded for Speed
 - 5X5, 5X6 Modded for Speed
SystemUI Mods
- Stock
 - OG Battery MOd
 - OG Battery Mod and Quick Launch PAnel
Additional SystemUI Mods:
- Lock Icon
 - Home Icon
 - Lock and Home Icon
 - No Additional Mods
Phone
- Stock
 - Call Recording
Keyboard
- Stock
 - Echoe
Framework
- Stock
 - Transparent
Boot Animations
- Stock S5
 - Stock S4
 - Echoe Illusion
 - Echoe Kit Kat
Boot Sound
- Stock S5
 - Stock S4
 - Pink Floyd "Time" Boot Sound
	(16/05/2014) S5 Echoe Rom v.3 (XXU1ANE2 Base)
Version: Android 4.4.2
Changelist:1539356
Product Code: BTU
PDA: G900FXXU1ANE2
CSC: G900FOXA1ANE2
- Added kids mode installer in setting
- Added torchlight function in setting/display
- Added pagebuddy function in setting/display
- Icreased up to 12 app max in toolbox
- Included in aroma the choice for Sfinder and Quickpanel button
*****All mods and tweaks from previous versions updated to latest base*****
		Changelist:1539356
Product Code: BTU
PDA: G900FXXU1ANE2
CSC: G900FOXA1ANE2
(03/05/2014) S5 Echoe v2 (XXU1ANCF Base)
- 1. Updated to G900FXXU1ANCF Base
Changelist: 1186806
Build date: Mon, 31 Mar 2014 10:55:18 +0000
- 2. Added the Amazing OG Battery Mod with the ability to choose over 85 beautiful battery icons
on the fly without needing to reboot or restart your SystemUI (CREDITS: Osama Ghareeb)
- 3. Enabled Call Recording
- 4. Abused the SecMms.apk resulting in the following mods (CREDITS: jovy23 for prob the BEST GUIDE on XDA)
. No SMS to MMS conversion for messages
. No SMS to MMS conversion for emojis
. Enabled Group Messaging
. Show sent (real) time instead of time received
. Enabled Save/Restore function of your Messages to your SD Card
. Enabled split view mode on landscape screen
. Enabled the Screen on/off toggle
. Enabled Folder View Mode
. Enabled the ability to send a message to more than 1000 recipients at the same time
. Increased the SMS hour limit to 1000
. Increased the Max MMS size to 2048000 bytes
. Increased the MMS Image size to 4096x2048 [8.4MP]
-5. Added More Options In Aroma
- Keyboards:
a.Stock
b.Echoe
- SystemUI:
a. Stock, Stock with OG, SystemUI with OG and Quick Panel
b. Choose Lock Screen and/or Home Icon on your status bar if you want
c. Choose from 10 Amazing Curtain Backgrounds
- Framework
a. Stock
b. Transparent
-6. Implemented by default up to 7 apps in toolbox
-7. Every mod, app, tweak and Aroma Option from v1 still apply!!
		Changelist: 1186806
- Keyboards:
a.Stock
b.Echoe
- SystemUI:
- Framework
a. Stock
b. Transparent
(15/04/2014) S5 Echoe v1 (XXU1ANCE Base)
16 April 2014 Initial Release
	- Make a Complete Backup (including EFS) and make sure you have a copy on your external sd card
To backup your EFS use this AWESOME TOOL by @ricky310711 - Use a Custom Recovery
(note: even though Echoe Rom contains no knox leftovers, the fact that you will flash a
custom recovery will automatically raise your knox counter to 0x1 thus voiding your warranty!!) - You need to do a clean install!!! Wipe cache, wipe dalvik cache,
Wipe data/factory reset and Wipe System (In Philz recovery use the Following Options: Wipe Data/ Factory Reset/
Clean to Install a New Rom) and then Install Zip (from either external or internal SD depending on where you chose
to save the Rom) - The installation process takes between 3-5 minutes. Let it do its job  Also the 1st boot also takes 3-5 minutes.
I would also recommend that before the initial setup, you dont do anything to your phone for 5 minutes...
Let it settle and then proceed with the initial setup... That's just my usual ritual with any Rom I flash - Reboot and Enjoy
	ECHOE DOWNLOAD CENTER
Quelle: [UPDATE 16 May 2014][ROM] [G900F] [XXU1ANE2] Echoe Rom v.3 [3 in 1 Aroma] [AEL Kernel] [OTA Customization] - xda-developers
