Fehler beim Rooten
  • 14 Antworten
X
xn0live
Hi, Leute
--- Wollte heute mein Xperia Ray Rooten ---
Easy rooting toolkit (v4.0)
created by DooMLoRD
using exploit zergRush (Revolutionary Team)
Credits go to all those involved in making this possible!
[*] This script will:
(1) root ur device using latest zergRush exploit (21 Nov)
(2) install Busybox (1.18.4)
(3) install SU files (binary: 3.0.3 and apk: 3.0.6)
(4) some checks for free space, tmp directory
(will remove Google Maps if required)
[*] Before u begin:
(1) make sure u have installed adb drivers for ur device
(2) enable "USB DEBUGGING"
from (Menu\Settings\Applications\Development)
(3) enable "UNKNOWN SOURCES"
from (Menu\Settings\Applications)
(4) [OPTIONAL] increase screen timeout to 10 minutes
(5) connect USB cable to PHONE and then connect to PC
(6) skip "PC Companion Software" prompt on device
CONFIRM ALL THE ABOVE THEN
Drücken Sie eine beliebige Taste . . .
--- STARTING ----
--- WAITING FOR DEVICE
* daemon not running. starting it now *
* daemon started successfully *
--- creating temporary directory
mkdir failed for tmp, File exists
--- cleaning
rm failed for *, No such file or directory
--- pushing zergRush
cannot open 'files\zergRush': No such file or directory
--- correcting permissions
--- executing zergRush
--- WAITING FOR DEVICE TO RECONNECT
if it gets stuck over here for a long time then try:
disconnect usb cable and reconnect it
toggle "USB DEBUGGING" (first disable it then enable it)
--- DEVICE FOUND
--- pushing busybox
550 KB/s (1075144 bytes in 1.906s)
--- remounting /system
mount: permission denied (are you root?)
--- checking free space on /system
27 KB/s (439 bytes in 0.015s)
--- Free space on /system : 175816 bytes
--- no cleanup required
--- copying busybox to /system/xbin/
/system/xbin/busybox: cannot open for write: Read-only file system
--- correcting ownership
Unable to chmod /system/xbin/busybox: No such file or directory
--- installing busybox
/system/xbin/busybox: not found
--- pushing SU binary
failed to copy 'files\su' to '/system/bin/su': Read-only file system
Unable to chmod /system/bin/su: No such file or directory
--- correcting symlinks
rm failed for /system/xbin/su, Read-only file system
link failed Read-only file system
--- pushing Superuser app
failed to copy 'files\Superuser.apk' to '/system/app/./Superuser.apk': Read-only
file system
--- cleaning
--- rebooting
ALL DONE!!!
Laut beschreibung steht da nun !ALL DONE! aber wenn ich einige Rootprogramme starte steht da immer NO ROOT
Hab ich etwas falsch gemacht?
hast du vielleicht die .62 od. .69 Firmware ?
hab die 42.firmware also android 2.3.4 (habe grad unter telefoninfo nachgeguckt)
versuche es mit dem Flash tool zu rooten.
(Schloss Butten)
gibs hier ne anletiung da ich ein anfäner im gebiet rooten bin :D
mit ein bisschen suchen findet man das hier an Board.
bisschen runter scrollen.
mit dem Flashtool funzt es auch nicht:
06/047/2012 20:47:53 - INFO - <- This level is successfully initialized
06/047/2012 20:47:54 - INFO - Flashtool Version 0.7.0.0 built on 2012-04-14 11:34:01
06/047/2012 20:47:54 - INFO - You can drag and drop ftf files here to start flashing them
06/048/2012 20:48:02 - ERROR -
06/048/2012 20:48:06 - INFO - Device connected with USB debugging on
06/048/2012 20:48:09 - INFO - Connected device : ST18
06/048/2012 20:48:09 - INFO - Installed version of busybox : N/A
06/048/2012 20:48:09 - INFO - Android version : 2.3.4 / kernel version : 2.6.32.9-perf
06/048/2012 20:48:21 - INFO - Pushing C:\Flashtool\.\devices\ST18\busybox\1.19.0\busybox to /data/local/tmp/busybox
06/048/2012 20:48:24 - INFO - Pushing C:\Flashtool\.\custom\root\psneuter.tar.uue to /data/local/tmp
06/048/2012 20:48:28 - INFO - Running part1 of Root Exploit, please wait
06/048/2012 20:48:28 - INFO - Running rootit
06/048/2012 20:48:30 - INFO - Waiting for device
06/049/2012 20:49:32 - INFO - Forced stop waiting.
06/049/2012 20:49:32 - INFO - Running part2 of Root Exploit
06/049/2012 20:49:33 - INFO - Running rootit2
06/049/2012 20:49:33 - ERROR - Cleaning rootit files
Mounting /system R/W
FTError
genau an die anleitung gehalten?
USB Debugging an, unbekannte Herkunft erlaubt?
stöpsel mal an und warte bis es vom pc erkannt wird.
überprüfe den USB Verbindungsmodus.
MTP und MSC brauchst du glaub ich.
kuemmeltuerk@ jap bei beiden ist ein haken
statler@ Ich kann nur ein von beiden anklicken, also MTP oder MSC?
ja, es geht immer nur einer
habe es mit beiden versucht aber funzt immernoch nicht
für es mal mit ADMI rechte aus
ggf deaktiviere mal dan Antivi. Programm
Du hast keine verbindung war bei mir auch so
Habe das problem auch... gibt's eine loesung? Danke
PS: Bin neu mit Xperia Ray
