dmark
There is a small gap between the back cover and phone frame where dust particles can go inside.
It's not really visible by naked eye only if you stick a really narrow piece of paper or something you notice that you can push it between the back cover and the phone frame a little bit.
Question is should there be visible glue/silicone between the back cover and phone frame?
Can someone share a similar close up photo?
