was ist besser zopo980+ oder 998
  • 3 Antworten
choco
choco
hallo,
was ist besser zopo980+ oder 998 die haben doch beide gleiche MTK6592,octa core, 1.7GHz drinnen auser Zoll grösse.
zopo980+ 5Zoll
zopo998+ 5,5Zoll
hat jemand vielleicht mehr ahnung danke
Zp998
Model: ZOPO ZP998
CPU: MTK6592
RAM: 2GB
ROM: 16GB
OS: Android 4.2
Band: 2G: GSM 850/900/1800/1900 MHz 3G: WCDMA 900/1900/2100 MHz
Sim Card: Dual SIM Card
Service Provide: Unlocked
Color: White,Black
Screen Size: 5.5-inch 404PPI
Resolution: 1920*1080
Screen Color: 16 Million Colors
Ringtones Type: Polyphonic/MP3
Audio File Format: MP3/WAV/AMR/AWB
Video File Format: 3GP/MPEG4
Image File Format: JPEG/BMP/GIF/PNG/GIF
E-book Format: TXT/CHM/DOC/HTML
FM Radio: Yes, earphone needed
Earphone Port: 3.5mm
Card Extend: MicroSD Card up to 64gb
Data transfer: Micro USB v2.0 /Bluetooth
Mobile Internet: WAP/WIFI
Camera: Dual Cameras, front camera 5.0MP, back camera 14.0MP with flashlight and auto focus, support full screen capturing
Phonebook: 500
GPS: GPS,A-GPS
WIFI: 802.11 b/g/n,DLANA,Wi-Fi hotspot
Bluetooth: Bluetooth 4.0
Gravity Sensor: Yes
Multi-Touch: Yes
Other Feature: Support OTG,3G, WIFI, GPS, FM, Play Store, Bluetooth, Ebook, Email,NFC,etc
Battery: 2400mAh
Standby Time: 400-580 hours
Dimensions: 151.4 x 76.1 x 9.1 mm
Zp980+
Model: ZOPO ZP980+
CPU: MTK6592
RAM: 2GB
ROM: 16GB
OS: Android 4.2
Band: 2G: GSM 850/900/1800/1900MHz 3G: WCDMA 900/1900/2100MHz
Sim Card: Dual SIM Card Dual Standby(one micro-sim card)
Color: White,Black
Screen Size: 5.0 Inch
Camera: Dual Cameras, front camera 5.0MP, back camera 13.0MP with flashlight and auto focus, support full screen capturing
Phonebook: 500
GPS: GPS,A-GPS
WIFI: 802.11 b/g/n
Gravity Sensor: Yes
Multi-Touch: Yes, 5 point touch
Other Feature: Support OTG,3G, WIFI, GPS, FM, Play Store, Bluetooth, Ebook, Email,etc
Battery: 2000mAh
Standby Time: 130-200 hours
Dimensions: 143.3 x 70.2 x 8.5mm
Quelle: WWW. Zopomobileshop. Com
Wer hätte das gedacht....
also ich habe den zopo zp980+ 5zoll gestern an comebuyshopping zürück geschickt mal sehen wie lange dies dauert bis ich den zp998 bekomme.
Von der grösse her 980+ und 998 ist minimal.998 passt doch auch in die Hosentasche:laugh:.
Hier nochmals die unterschiede:
Zopo zp998:
Multi-Touch: Yes
Battery: 2400mAh
Zopo zp980+:
WIFI: 802.11 b/g/n
Battery: 2000mAh
Heute habe ich den zopole zp998er bekommen:biggrin: aber ohne diesen Schutzhülle S-View Flip Tasche.
Aber die sind ja echt ok mit dem Versand.:thumbsup:
