nexus963
Ich habe hier diesen MOD den ich euch nicht Vorenthalten will da es merklichen Erfolg auf meinem Blade Vec 4g an den Tag legt...
Es handelt sich um den PurePerformances™X MOD aus dem XDA Forum, den Originalen Beitrag findet ihr HIER. Der MOD bietet folgendes...
◢ Features ◣
- Android performances improved at 360°
- Radically improved management ram on android (Lags...adios!)
- Script lightweight and revised to be adapted to this engine
- Improves a lot the graphics: of course Pure Graphic™HD, Pure Dithering Plus™ and... AOSPA 3.60 system tweaks
- Scan multimedia time drastically reduced
- Network Improvements, 3G experience even in 2G modality
- All SQlite database optimized
- Enable hardware features turned off by default for a better experience on entry level devices
- Greatly increases the score AnTuTu: Try it to believe it!!
- Reduces the startup time of Android
- A version for stock rom and one for CM, to squeeze any roms!
- Allows you to play ported games without lags
- Cleans the system every 24 hours, thecache every week and the Dalvik every month (cronos easter egg)
- Automatically Zipalign on each boot (sensitive to the user)
Battery
- Drastically decreased the drainage of battery
- Check the activities that consume too much battery stop them with PureWakelocks™
- When the phone is charging reduces system services for faster charging
- The battery is calibrated on every boot
- Disable animation of the system when the battery is nearly exhausted
- Improvements in build.prop as regards the part of consumption
Graphics, Screen, Images
- Enables a non-aggressive dithering to save CPU
- When you lock the device, the engine makes sure that the GPU is turned off
- Enables deep sleepalso in the bugged rom
- Parts of bravia engine
- Of course parts of CrossBreeder (credits to dev)
- Of course parts of Adrenaline Engine (credits to dev)
- Of course PureGraphics HD, even though I already told you
- Of course V6 supercharger
- Generates video entropy (like seeder)
CPU, Governors, I/O Schedulers
- Slightly improves the scaling of the frequencies (for better results you need a good kernel)
- Lightens the load on the CPU switching the workload to GPU rendering
- Enable the swap partition in Android (experimental)
Da das OS vom Blade dem CyanogenMod sehr nah kommt habe ich die CM Version des Mod´s genutz..
DOWNLOAD:
INSTALLER AUF MEGA
UNINSTALLER AUF MEGA
INSTALLER ORIGINALE QUELLE
UNINSTALLER ORIGINALE QUELLE
Credits
zeppelinrox for his default.prop of V6
ImbaWind for his parts of Adrenaline Engine
Exit_Only for his Turbo concepts, there aren't any parts of his work in mine
idcrisis for his CrossBreeder
nicolassp for his S1_Optimize
AUS DEM XDA FORUM
EUER NeXuS963
PS: Das passende Recovery um den MOD zu flashen findet ihr in meiner Anleitung
◢ Features ◣
Battery
DOWNLOAD:
INSTALLER AUF MEGA
Credits
AUS DEM XDA FORUM
EUER NeXuS963
