pro.aggro
Ikone
- 3.414
Das wichtigste auf Deutsch:
- Designed to keep the Samsung Galaxy S2 i9100 secure & waterproof
- IPX-4 Rated Tough Hard case design has strong clips to lock phone inside case
- Touch screen can still be used while in case
- Internal dimensions of case designed specifically to fit the Samsung Galaxy S2 i9100
- Rubber insert helps reduce shock if dropped or bumped
- Designed to allow charger to fit inside the case, only works with our charger available from our shop, please search for UltimateAddons Motorcycle HardWire Charger Cable for Samsung Galaxy S2 Case
- Case has a 3 prong mounting system on back of case allowing it to be mounted
- Case fits UltimateAddons mounting attachments, plenty to choose from!
- Use Touch Screen / Function Button while Samsung Galaxy S2 i9100 in case
- Access to Headphone / On/Off Switch & Volume Buttons
- Use its 8 Megapixel Camera while still in case, ideal for photo shots & video clips
- Listen to music through speaker while still in case
- Protect your Samsung Galaxy S2 i9100 while outdoors, ideal for work & outdoor pursuits
- Includes Free Lanyard to hold mount around neck
- UltimateAddons Brand
- 12 Month Warranty
- Consists on a durable outer shell with a bespoke rubber liner.
- Allows access to all the major function areas of your smartphone.
- Make & receive calls
- Sensitive touch lens.
- Control volume.
- Turn on / off
- Access headphones (inc: protective weather cap)
- Use your camera / video
- Shock resistant - Smooth rubber liner protects and cushions.
- Secure side clips click reassuringly into place.
- Cable access (inc: protective weather cap) for the new Ultimate Addons Galaxy S2 charging cable due out in 2012.
- Free screen protector
- Detachable lanyard with safety break.
- IPX4 - for general daily use.
- Telefonieren bleibt möglich!
- Touchscreen voll bedienbar
- alle Tasten bleiben bedienbar
- alle Anschlüsse sind wasserdicht verschliessbar
- Kamera verfügbar
UltimateAddons Hard Waterproof Tough Case for Samsung Galaxy S2 SII i9100 S 2 II | eBay
Dedicated Waterproof Tough Case for the Samsung Galaxy S2 SII i9100 | eBay
UA Tough Case for Galaxy S2 i9100 - YouTube
