Diamond-X
Dauergast
- 551
WARNUNG:
Weder ich, noch Android-Hilfe.de, noch irgendjemand anderes übernimmt die Haftung wenn ihr euer Telefon unbrauchbar macht. Flashen auf eigene Gefahr!
Features:
Code:
-5.0.1 LXR22C.H5 Google Play Edition from graffixnyc
-No rom branding
-Rooted
-Busybox
-Zip aligned
-App ops in security settings
-Advanced power menu
-Clear all in recents
-Expandable volume panel, link/un-link notifications to ringtone
-5.0.2 power off color fade memory bug fix.
-Aroma Options
--Dark material theme / settings, phone, contacts, calculator, framework-re (work in progress)
--Darker material theme
--Moto X camera & gallery
--Sense camera & gallery
--CyanogenMod apps (audioFX, browser, calendar, trebuchet launcher, file manager, music, gallery, sound recorder)
--AOSP email
--HTC keyboard
--MMS apps
--Live wallpapers
--Audio mods (viper4android, volume boost, cyanogenmod ringtones)
--Colorful navbar (mimics status bar)
--De-Bloat menu
--Stock kernel
--Quantum kernel
--ElementalX kernel
--Elite kernel
--CodeCraft kernel
-Custom extra settings (change in real time)
--Display
--Screen density (DPI)
--Power saver color (change the battery saver status bar warning color
--Show search bar in recents
--Show clear all recents button
--Location of clear all button
--Status bar
--Show alarm icon
--Show weather in notification header
--Double tap to sleep
--Network traffic meter
--Enable ticker
--Clock position
--AM/PM style
--Day of the week style
--Battery style
--Battery percent options
--Enable/Disable heads up
--Heads up timeout
--Quick Settings tile reorder
--One finger quick settings
--Navigation bar
--Long press recents
--Long press back to kill
--Navigation bar height
--Show arrow keys on navbar while typing
--Navigation bar layout
--Navigation ring targets
--Volume buttons
--Volume panel timeout
--Enable/Disable volume notification sounds
--Volume keys move cursor
--Music Controls, long press up action, long press down action, timeout
--Lock screen
--Quick unlock
--Scramble pin
--Display music visualizer
--Lock screen shortcuts
Installation:
!!!Ihr müsst die aktuelle GPE auf eurem Gerät haben!!!
Empfohlen wird entweder die Philz Recovery mit der Version 6.25.x oder TWRP 2.8.4 oder höher
1. Kopiert die .zip Datei auf euer Gerät und startet den AROMA Installer via Recovery
2. Wählt die Installation aus (custom oder default)
3. Folgt den Anweisungen
4. Neustarten!
Download:
Aktuellste: M8-GPE-03-16-2015
md5: 15dfcd88561fd492835bd7446292a2a6
AdroidFileHost
Changelog:
Code:
3-16-2015
*New Additions
HTC IME languages
New Darker theme
Visualizer on lock screen
Add Power button to navbar
*Updates
Update OTAUpdates app
New aroma 2.7 binary with Sprint patch
CM apps updated
Changed Extra settings to Extras
Updated APNs
Better handling of battery icons
Improved QS scrolling
Fix hide/show clock
3-02-2015
New Additions
Double tap lock screen to sleep
Hide search bar in recents
Hide & and move clear all button in recents
Ambient display options
Heads up display swipe option
-left = dismiss, right = background
Add left option to one finger QS pulldown
Add new QS tiles
Auto hide QS panel on tile toggle
Updates
Potential T-Mobile data fix
Fix center clock not animating when using ticker
Viper4Android audio
Fix volume link toggle not updating
Fix flashlight tile disappearing
Update CM apps
Update APN list
Fixed AppOps (now uses built in files instead of app)
Update busybox to 1.23.1
Update aroma binary to 3.00b1
2-22-2015
*Updates
Fixed network traffic
Fixed Enable ticker
Fixed Verizon/Sprint install
2-22-2015
*New Additions
Disabled APM on lock screen for extra security (Power off is still available)
Enable status bar ticker
Added screenshot to APM
Added airplane mode to APM
Link/unlink notification volume to ring volume
Enable/Disable long press recents
CyanogenMod Trebuchet launcher, Fully working (AROMA)
Viper4Android audio (AROMA)
CM ringtones, notificaions, alarms (AROMA)
Colorful navigation bar background, Mimics the status bar (AROMA)
OTA app, added option to ignore release
*Updates
Fixed lock screen shorcut FC
Extra Settings, reordered and added icons
System wide torch, quick setting and nav ring work together
APM icons
Elite kernel
Quantum kernel
Elemental X kernel
CM apps with bug fixes and material design updates
SuperSU 2.46
2-12-2015
*New Additions
Customizable NavButtons
Customizable NavRing
Navbar height on the fly... no more reboots
Volume marker sound on/off
Ability to remove lock screen short cuts
Weather in notification pull down
Date in clock mod
Ambient display / notificaions only, pick up is disabled
Change DPI (play store still thinks 480)
Audio boost (testing)
*Fixes
Updater script, should fix bootloops.
Dark dialer theme changes and fixes
Navbar back button
Location quick setting
*Updates
Quantum kernel
Elite kernel for gsm
Moved OTA from app drawer to settings>about
2-03-2015
*New Additions
Customizable quick settings
Disable signature verification
CodeCraft and Elite kernels for verizon/sprint
Sense video player
Started cleanup of extra settings
*Fixes
Multi-carrier support
FCs in apps like PowerAmp
2-01-2015
*New Additions
Multi-Carrier support (beta) needs testing.
AM/PM in clock mod
Nav bar height (*requires a reboot)
Sense camera and gallery
ElementalX kernel
Recents clear all FAB moved to center, added fade in animation.
.75 to animations
*Fixes
Battery mod
HTC keyboard
1-26-2015
5.0.2 memory leak fix for Color Fade when screen is turned off.
Battery mod
Use volume keys to move cursor
Lockscreen shortcuts
Double tap status bar to sleep
OTA support
HTC IME libs
*Updates
CM apps
Busybox
*Fixes
Dark theme
Extra settings defaults should match system on fresh boot
Initial release. 1-23-2015
