[ROM][N7100][XXUFNE1][4.4.2] *28.05.14* Omega v29 [Omega Files][Themes]
  • 1.810 Antworten
Nytro
Welcome to Omegas Thread for Samsung Galaxy Note II N7100
Omega v29 Kit Kat 4.4.2
Based on firmware XXUFNE1 Android 4.4.2 (Date: 06/05/2014)
Screenshots:
Omega v28 Installation:
Bootloader - Knox:
Omega does not include bootloader and will not change your knox warranty status.
Backup:
Backup your device (nadroid backup, titanium backup, efs backup ... etc), in case you ever need to restore!
Wipe:
Full wipe is needed if you are coming from another rom or stock firmware or Omega with another android version
and format of internal sdcard is needed if you are coming from Android 4.1.2 because updating to Android 4.3 will change the location of your internal sdcard
Installation Instructions:
Boot to recovery and flash Omega
Done, Reboot and enjoy kit kat Omega
NOTICE: If you are having the old bootloader WiFi will not work, flash this Fix N7100_wifi_fix_for_old_bootloader.tar file with odin. Credits to dr.ketan for the WiFi Fix
If you are using the new bootloader you do not need to flash this fix, WiFi will work.
To check your bootloader go to download mode and if you have an entry: KNOX WARRANTY VOID then you are having the new bootloader.
PLEASE FOLLOW THE EASY INSTALLATION INSTRUCTIONS ELSE YOU WILL HAVE VARIOUS ISSUES!
csc:
Multi csc included in Omega
Remove bloatware:
You can remove all bloatware during Omegas installation
Inside Omega v29:
Kernel Stock
Modem XXUFND3
csc multi set to BTU
Busybox
Aroma Installer
Installation is fully customizable by user and there is options to install everything or remove all Bloatware
aroma installer now has the option to remove more then 800 mb of almost 80 bloatware apps, widgets and services
Option to full wipe from aroma installer
Option to Remove all Bloatware from aroma installer
Option to install or not all Omega addon apps from aroma installer
Wipe cache partition automatic before roms installation
Wipe Dalvik Cache automatic during installation
Wipe preload partition automatic before roms installation
Wipe System automatic before roms installation
efs Backup (added the option to create efs backup during installation)
Omegadroid Walk Bootanimation by Jorq1H and anbech
Omegas Emblem Shutdown Animation by anbech
OmegaDroid Kit Kat Wallpapers by our artist Jorq1H
Applications developed by Omegas Team (bartito & indie):
Omega Files by indie
OmegaDroid - The official application of www.omegadroid.co by indie
OmegaDroid Wallpapers application - Screenshot by indie
Task manager shortcut app by indie
Accounts Sync Profiler - xda thread for support & suggestions - Play Store link - by bartito
Backup manager for apps & data - xda thread for support & suggestions - Play Store link - by bartito
CPU Adjuster - xda thread for support & suggestions - Play Store link - by bartito
Notification Manager - xda thread for support & suggestions - Play Store link - by bartito
Recycle Bin - xda thread for support & suggestions - Play Store link - by bartito
Wireless Scheduler - xda thread for support & suggestions - Play Store link - by bartito
more to come ....
if someone wants to help with our app development, with beta testing, suggestions, translations and be part of our app dev team please sent me a pm.
Mods:
Call Recording
Phone with no increasing ringtone
4-way reboot menu
Omegas OGBatteryMod app with 60 battery mods - credits to OsamaGhareeb
TW Launcher with scrolling wallpaper (can be disabled from Omega Files)
Hide sms from call logs
No sms to mms conversion
Unlimited contacts to sms - mms
sms/mms Backup - Restore
Increased sms hour limit to 1000
Disable scrolling cache
Email with Exchange Security Disabled
All supported languages enabled
All supported languages for Samsung Keyboard enabled
Exit button to stock browser
Join more unlimited contacts in the contacts
Enable sub Symbols on Stock Samsung keyboard
SamsungSans.apk with a lot of system fonts - by nitol
Addon applications:
Xposed Framework Installer by rovo89 - read more about Xposed here
Android Camera 4.4.2 with Photoshare
Android Keyboard 4.4.2 - available at Omega Files
Flash player Support
Dolphin Browser with Flashplayer support
Dolphin Browser Jet Pack
Es File Explorer
Hide It Pro
ZArchiver
Hi-Q MP3 Recorder
Pen Window Manager
Removed:
Knox
Removed (Can be added from Omega Files):
Boot sound
Charger Connection Sound
Stock Theme Changes:
Accuwheather widget transparent by indie
Omega Theme for aroma installer by our artist anbech
Bloatware :
Rom is Deodexed + Rooted + Zipaligned
Omega Files:​
Omega Files Pro:​
xda's support thread for suggestions and feedback!
Omega Graphics:​
Download:
Download Center
Please do not make mirror links
Twitter:
Omegas Team:
indie
anbech - Thread |OP| & Beta testing & Graphics
cooza - Thread |OP| & Beta testing
devabhishek - Thread |OP| & Beta testing & themes
Jorq1H - Thread |OP| & Beta testing & 3D Graphics
gimmick56 - Thread |OP| & Beta testing
kalagas - Thread |OP| & themes
motomoto00 - Thread |OP| & Beta testing & themes
mythtrandyr - Mods - Programming
MVKA - Thread |OP| & Beta testing
nadmaj - Thread |OP| & Beta testing - Themes - Mods
raubkatze - Thread |OP| & Beta testing - Themes - Mods
ttav - Thread |OP| & Beta testing
wesamothman - Thread |OP| & Beta testing
Thanks - Credits:
To my wife
To Omega's Team
To anbech - devabhishek - Jorq1H - kalagas - raubkatze for Omegas Graphics
To Jorq1H for Omegas 3D Graphics
To danishprakash for Note II psd icon
To Samsung
To all of you who support my work and help me
::indie's:: Omega Roms Series
<b>
OmegaDroid - your android portal ...
Omega Files Pro app - Build and Customize your rom the way you like it!!
Samsung Galaxy S5 Samsung based
Samsung Galaxy S4 Samsung based I9505 - Samsung based I9500
Samsung Galaxy Note 3 N9005: Samsung based 4.4.2
Samsung Galaxy Note 2 N7100: Samsung based 4.4.2
Samsung Galaxy S III I9300: Samsung based 4.3 - Omega AOKP 4.4.2 - Omega Omni 4.4.2
Samsung Galaxy S II I9100 Android 4.1.2 - Android 4.2.2 AOKP
Samsung Galaxy Note 10.1: Samsung based 4.1.2
HTC HD2 + Tmous HD2 - Omega v30 - WM6.5.x Build 29022
</b>​
:: User Friendly Developer ::​
If you like my work please consider a donation!
Please use Omegas Threads for Support and Suggestions and don't sent me pm's!
Reaktionen: datt-bo
Tastatur muss ich mal sehen könnte sie vieleicht aus der Stockrom rausziehen wenn es mir die Zeit erlaubt.
New version Omega v2.0 Jelly Bean:
Based on firmware XXALIE Android 4.1.1 (Date: 21/09/2012)
Added:
Es File Explorer (with great Root Explorer)
Hide It Pro
OmegaDroid wallpaper
Omegas JB Bootanimation by anbech
xperia keyboard
Mods:
TouchWiz with wallpaper scrolling
Disable Scrolling Cache
Battery % mod
Updated:
Flipboard
ChatOn
YouTube
hosts
Removed:
Samsung keyboard (due to not working)
Removed Bloatware:
Learning hub
Reading hub
All mods and updates from previous Omega JB versions added
Rom in no Full Wipe
Please read the following before flashing v2.0:
1. Make sure to make and keep in a safe place an efs backup - a nadroid backup + titanium backup, in case you need to restore.
2. After installation Device reboots automatically to Android.
Donation:
If you like Omega v2.0 please consider a donation to help me continue this project.
Enjoy the new Note II Omega
Edit:
Please fix the first posts to be the same with xda - thank you!
Reaktionen: Aponatur
New version Omega v3.0:
Based on firmware XXALJ1 Android 4.1.1 (Date: 02/10/2012)
New:
Kernel Stock XXALJ1
Modem XXALIH
CSC: XXALJ1 set to EUR
Updated:
YouTube
Mods:
Contacts with Greek index
Shutter Sound menu Enabled to stock camera
Moved to Bloatware:
Chrome
VideoHub
Rom is no Full Wipe
Please read the following before flashing v3.0:
Donation:
If you like Omega v3.0 please consider a donation to help me continue this project.
Enjoy the new updated Omega
Zwei Fragen
Ist der Mehrfenstermodus jetzt dabei kann oben nichts darüber finden
und hat jemand ein alternatieven download denn 134 kb pro Sekunde dauert Stunden
um die V3 runterzuladen.
Weiß jemand ob die Samsung Tastatur geht und die Synchronisation mit Kies.
Danke für die Info
Ich weis garnix solange die V3 nicht downloadet. Steht immernoch auf 39 Minuten.
Nimm den Torrent, der läuft mit ~ 1mbit/s (ich seede mit unter).
Samsung Tastatur läuft 1A und auch der Multiwindow läuft.
Reaktionen: Robby57
wie schalte ich das multiwindow ein bitte?
Lange die zurück Taste drücken
Gesendet von meinem GT-N7100 mit Tapatalk 2
Mal ne kurze Frage? Im Aroma wird mir gleich zu Anfang angezeigt:
Only for International Samsung Galaxy Note II - N7100
Für wen zählt das denn jetzt :). Nicht das ich mir heut noch das Teil zerschiess ^^.
Danke!
Europa würde ich sagen
aroma wird gezeigt und sogar führt sogar die installation aus
Ich habe es drauf und läuft super
Der ursprüngliche Beitrag von 20:16 Uhr wurde um 21:48 Uhr ergänzt:
Kann bitte jemand den wallpaper von 3.0 hochladen?
finde es meine irgendwie nicht mehr
Wird bei der Installation irgendwas gewiped? Oder kann ich die rom ohne probleme drüber bügeln?
Wie sieht es mit dem counter aus?
Es wird nichts gewiped. Einfach drüber. Der Counter bleibt auch bei der 1 falls Du gerottet hast.
Nee habe ich noch nicht. Muss ich wohl erst machen oder?
Ja ohne Root keine Coustom ROM wie OMEGA
Hallo Leute,
Das Omega Rom läuft absolut ohne Probleme ;)....
Die Multi Fenster Ansicht hat echt was gutes ;)... Muss man sich zwar etwas dran gewöhnen aber kann man gebrauchen ...
Gruß Partystoned
Reaktionen: Robby57
Hallo, Ihr Flasher,
Wo gabs denn nochmal eine schrittweise Anleitung für Omega und von wo habt ihr die Version 3 downgeloaded?
Danke Euch
Im ersten Post findest du auch den Link zum Download-Center (riesengroß :laugh:)
Ich empfehle jedoch die Torrent Variante (nicht Deposit-File), da sie deutlich schneller geht!
Genau die Anleitung gepostet von xmrr3dx folgen. Dann hast du das CWM und dann über das CWM die heruntergeladen Omega.zip flashen und schon hast du das ROM am laufen.
Reaktionen: Brunnebutzer69
