[ROM][I9300][4.4.2][XXUFNG3] *02.09.2014* Imperium KitKat ROM v3.0 [AROMA][OTA]
R4Sh
[ROM][GT-I9300][AROMA][OTA][Imperium KitKat ROM v3.0][Stock KK 4.4.2 FNG3][02/09/14]
(KK 4.4.2)
>>> Download <<<
>>> XDA Originalthread <<<
>>> Changelog & Tweaks <<<
Bekannte Bugs:
- Wlan funktioniert nicht (gibt einen Fix im OTA) > bei mir funzt WLAN ohne Probleme ohne Fix
- Reboots > treten bei mir nicht auf
- Wenn das Gerät aus ist und geladen wird, schaltet sich das Gerät automatisch an, aber es wird geladen!
Features:
Based on the N7100XXUFNG3 QS 2.6 Note2 fw porting by qaraqumus (thanks to him)
Deodexed + Rooted + Zipaligned
Aroma installer
Auto wipe cache, system and dalvik-cache before flashing the ROM
Wipe data and sd card (in aroma)
Custom Settings for Imperium ROM - (thanks to ficeto and Goldie)
OTA Update with Update me Imperium - (thanks acquariusoft)
Root with SuperSU
Busybox
Sqlite3
OpenVPN support
Updated all app
Kernel :
Stock Kernel
Boeffla kernel (thanks to AndiP)
Archi kernel (thanks to JustArchi)
Removed:
Bloatware and more app
Integrated:
Adobe Flash Player
FastDormancy Toggle for I9300 by gokhanmoral
AdAway
Xposed Installer Framework - (thanks to rovo89)
Xposed App Settings - (thanks to Tungstwenty)
Wanam Xposed - (credits to wanam)
Greenify (in aroma) - (thanks to oasisfeng)
GravityBox (in aroma) - (thanks to C3C076)
Complete Action Plus (in aroma) - (thanks to p.valenta)
Mods:
With Wanam Xposed (credits to wanam)
Call Recording
4 Ways Reboot (Reboot, Recovery , Hotboot, Download)
Full Color/Transparency customization for Status bar and Notification drawer elements
Secure Samsung Keyboard
Option to keep "Add Call" button with Call recording menu
Disable Camera shutter sound (+Screen Capture)
Flashlight trough volume button UP
Skip Music with Volume buttons
Save Call Logs View
Enable Keyboard Symbols
Enable Hangouts Calls trough cellular
Enable Camera while calling
Unlimited and Customizable Multi-View support
Bypass Exchange Lock check
Notification Panel Customization
Long Home key behavior
Long Back key to kill App (+ white list)
Disable increasing ringtone
Messaging Tweaks (raise limits and conversion)
Disable Scrolling cache
Enable Full rotations
White/Colored Circle Battery
Transparent Notifications panel
Customize Clock format and size
Customize Battery text helper size
Customize Quick Settings buttons number per row
Collapse Quick Settings after toggle
2 line formatted date on the panel header
Dark themed Multi-Window
Disable Boot sound
Customize Two line date header format
White/Black Email App background (Supported on some devices)
Transparent Quick Settings buttons background
Default hidden SMS logs
Add Call button to Logs and Contacts list
Disable Accounts icons on Contacts list
Custimize Wifi AP Clients number
Disable Launcher page rotation
Add Exit button to browser
SMS Automatic input mode
Disable Call number formatting
Enable unlimited Contacts joining
Enable Gallery Rotation trough button
Set default Browser view to Desktop
Hide Wireless charging popup
Hide Full Battery Notification
Clock position Status bar (Hide, Left, Right, Center) (Compatible with I9300 and I9500 only)
NFC behaviors (UN/Locked on Screen ON/Off)
Hide Headset icon and notification bar
Disable TW DVFS
Enable TW DVFS Boost Benchmark mode
Hide Smart Stay, Alarm, NFC icons on status bar
Launcher : Enable Scroll wallpaper and Hide Dock labels
Disable Wake Home button
Use separate Address field on Contacts
Add Fast PIN unlock (to be used with caution)
Added SMS sent time details
Enable Screen ON options on Messaging App
Disable low Battery warning
Add custom carrier label on notification label
Set low Camera battery level
Change System Holo Dark/Light background
Acces hidden Lockscreen shortcuts menu
Disable SEAndroid/Knox notifications
And much more to come...
Mods, porting and apps:
Home and Lock Button on statusbar (aroma)
AOSP Email (aroma)
AOSP Email (OTA)
S4 S Memo (aroma)
S4, Note3, S5 My Files (aroma)
Apollo Music Player and Sony Xperia Walkman (aroma)
Xperia Movies Video Player (aroma)
Inverted and transparent Play Store (aroma)
Tweaks:
build.prop tweaks
zipalign all app at the boot
Sqlite optimize
3G tweaks
Request:
- Recovery custom (suggest Philz or CWM)
Installation:
- Mache ein Backup deines bisherigen Systems
- Kopiere die Heruntergeladene zip Imperium_vX.X auf deine SD-Karte
- Starte ins recovery mod
- Installiere "Imperium_KitKat_vX.X....zip"
- Installiere "Bloat_Pack_XXX.zip"
- Folge den Anweisungen des Aroma Insatller
- Drücke "Next" und starte Dein Gerät neu
- Fertig!
Bilder:
Ich übernehme keinerlei Garantie für evtl. entstehende Schäden an eurem Gerät. Flashen auf eigene Gafahr!!!
Reaktionen: cybernoon, Grabbo und JK900
Denke das wichtigste ist jetzt eingedeutscht. Wer alles auf deutsch haben möchte kann mir gerne die Übersetzungen per PN schicken. :)
Bin nicht so gut im übersetzen.
Noch ein bisschen zur ROM:
Habe die Rom jetzt über eine Woche drauf sie läuft bei mir sehr zuverlässig. Ich habe keinen anderen Kernel drauf gemacht. Läuft alles flüssig, alle Apps funktionieren bei mir. Ich habe keinerlei Reboots. Das einzige was bisher noch ein bisschen nervt ist der recht hohe Akkuverbrauch.
Also viel Spaß beim ausprobieren!
Reaktionen: SaschaKH
OTA Updates ist übrigens von Kryten2k35 selber.
Und?
Habe die Rom seit Montag am laufen, vorher Imperium 27 mit boeffla. Hatte dort eine Laufzeit von etwa 7 uhr morgens bis max 22 uhr bei "normaler" Benutzung.
Jetzt bei diesem kitkat, ohne Änderungen an der config, habe ich um 18 uhr noch 60 Prozent Akku.
Läuft klasse! Bisher keine Fehler feststellen können!
Wenn Du jetzt noch normale Benutzung etwas genauer definieren könntest. Also ich bekomme den Akku in zehn Stunden leer, er kann aber bei mir auch fast drei Tage halten (OK das allerdings nur bei 4.3). Daraus kann ich für mich also schliesen das bei mir so ca. 30 Stunden normaler Nutzung entsprechen und auf die Zeit kommst Du mit der Imperium KK nicht ganz. Ich bezeifle jetzt allerdings das dies viel über die ROM aussagt.
Ich geb Dir mal ein Beispiel, wie ich finde das die Daten besser vergleichbar sind:
In einem Tag, also 24 Stunden, bei 4 Stunden Bildschirm an, habe ich 90% verbraucht.
Wobei das auch noch sehr schwanken kann was man gemacht halt als der Bildschirm an war, aber etwas aussagekräftiger dürfte es schon sein.
Also ich habe mir die Rom jetzt auch mal zu Gemüte geführt. Bin seit zwei Tagen sehr zufrieden. Habe seit langer Zeit mal wieder eine Samsung Rom drauf....
Alle Apps funktionieren soweit und es gibt auch keine reboots.
Zur Akkulaufzeit kann ich nicht viel sagen, da mit ich mit sehr schlechten Empfang hier zu kämpfen habe. Das liegt aber an meinen Anbieter! Wenn ich mobile Daten aus habe, komme ich sicherlich über 30 Stunden mit der Rom.
Läuft dieses ROM stabil ? Ohne tägliche Reboots ?
Der ursprüngliche Beitrag von 17:01 Uhr wurde um 17:01 Uhr ergänzt:
Und funktioniert bei euch WLAN ?
Dreimal Ja!
Reaktionen: feliiix91
Super Danke ich werds mir auch mal drauf packen :)
Der Erste Eindruck ist echt super, obwohl es am anfang 2-3 mal rebootet hat aber jetzt läuft es:scared: . Ich benutze den Stock Kernel, benutzt ihr den auch ?
Imperium 29 läuft etwas flüssiger. Ich vermute(!) ,dass der Arbeitsspeicher für kitkat nicht reicht!
Jupp kommt mir auch flüssiger vor, aber der akku verbrauch ist auch bei der v29 recht hoch.
Also bis jetzt läuft bei der V1.0 immer noch alles top, auch schön schnell, und der Akkuverbrauch ist auch gut, wenn das so bleibt bin ich zufrieden.
By the way: Weiß jemand wie ich bei dem Widget für Lesezeichen, meine Googlemail Lesezeichen bekomme ? Normalerweise ging immer ein Feld auf, wo man zwischen Googlemail und Home auswählen konnte. Aber bei der V1.0 blieb das Feld weg. :confused2:
V2.1 ist online. Ist nur ein Update von ca. 600 MB.
Hoffentlich wird der Thread noch angepasst.
Die 1.0 lief bei mir sehr gut muss ich sagen. Auch Wlan und alles andere.
Auch diese 2.1 läuft nicht so flüssig, wie Imperium v29!
Der ursprüngliche Beitrag von 11:00 Uhr wurde um 11:02 Uhr ergänzt:
V. 3.0 ist Online. Thread ist aktualisiert.
Installiert und läuft sehr flüssig... habe keinen Vergleich zur Imperium v29, aber die 3.0er rockt. Vielleicht auch einfach weil ich mal wieder einen Fullwipe gemacht habe.
Mal schauen wie es sich entwickelt.
Reaktionen: R4Sh
Hallo !!!
Hab das drauf habe alles versucht aber das WLAN geht einfach nicht könntet ihr mir bitte helfen Danke
Kani_23
Spot.Zwei
Spot.Zwei
Droid228
Droid228
Android_Noob.
