[ROM][I9505][4.4.2][XXUGNG4] *20.08.2014* Samy Deluxe S4 ROM
hanspampel
hanspampel
Ehrenmitglied
9.863
Achtung!! Dieses ROM ist nur für das GT-I9505!!!!
Wenn man so will, stellt diese ROM einen Mix der besten derzeit erhältlichen Elemente aktueller (und künftiger) Samsung Smartphones dar: Samsung Galaxy S4 als Basis, gewürzt mit Galaxy Note 3 Extras und den optischen Elementen des kommenden Galaxy S5.
Features
  • Android 4.4.2 I9505XXUGNG4 Base
  • AROMA Installer
  • S5 Dialer and Contacts with the PopUp incoming call, call recording
  • S5 Bootanimation & S5 Shutdown menu
  • S5 System Ui
  • S5 LockScreen
  • S5 Ultra Power Saving Mode
  • S5 Emergency Mode
  • S5 Download Booster
  • Emergency Launcher
  • All Galaxy S5 Libs and permissions
  • S5 Settings
  • Added UPSM Apps Manager
  • S5 Filemanager, S5 Calculator, S5 Translator
  • S5 Sview Cover (might be buggy)
  • S5 Touchwiz Launcher
  • S5 SPlanner
  • S5 SMS
  • S5 S-Gallery, S5 S-Browser, S5 Music Player
  • S5 Geo Lookout, S Baro, S5 Accuweather
  • S5 S-Memo, S5 Note
  • S5 Activity, S5 Remote
  • S5 Photo Retouching
  • S5 Story Album
  • S5 Health
  • S5 Video, S5 Watch-On, S5 Email, S5 Keyboard
  • S5 Group Play, S5 Optical Reader
  • S5 SFinder, S5 Baby Monitor
  • S5 Air Wake Up, S5 Quick Connection
  • S5 Car Mode, S5 SVoice
Changelog
Version "Pick Your King" (20.08.2014)
  • AROMA installer
  • option to choose between stock s5 TouchWiz launcher and TouchWiz Launcher Stock S5 smaller Icons
  • choose between S4 and S5 SHealth
  • S5 Camera (thanks to Albe95)
  • changed to AEL kernel
  • Readded missing XposedInstaller
  • edited apps: SViewCover, Group Play, a few others I forgot
Version "Peration Ivy" (02.08.2014)
  • new XXUGNG4 base
  • Updated GoogyMax3 Kernel to 1.1.3
  • Replaced S5 SHealth with Galaxy S4 App
  • Removed themechooser option TouchWiz launcher
  • Replaced Samsung LInk with Galaxy S4 version (less battery consumption)
  • Updated some Galaxy S5 Apps (Accuweather, S5 Mini clock, SNote, ...)
  • Reduced size: removed unnecessary apps, libs, permissions etc
  • added some (mild) battery and connection tweaks
  • added some Galaxy S5 CSC features (need to stand the test of time)
  • special thanks to xda member dany_ for help!
ältere Changelogs
Version "NOFX" (21.07.2014)
  • Updated Kernel to GoogyMax 1.1.1
  • Autorotation works permanently
  • Smart Scroll, Smart Stay working (again)
  • (Re-)moved some apps to Addon 2
Version H "Minor Threat" (09.07.2014)
  • renamed and fixed Less Than Jake ROM
Version M Bugs(9.7.2014)
  • One Hand and MiniMode crash
  • Clock broken
  • SView Cover untested
  • Settings -> SamyDeluxe Extras crashes (without function!)
  • Download Booster could possibly cause system restart
Version L Features (30.6.2014)
  • Android 4.4.2 I9505XXUGNF1 Base
  • S5 System Ui
  • S5 LockScreen
  • S5 Emergency Mode
  • S5 Settings
  • S5 Sview Cover
  • S5 SPlanner
  • S5 SMS
  • S5 Story Album
  • S5 Download Provider
  • S5 Health
Version I “I Don’t Want To Grow Up” (17.4.2014)
  • Took out the trash, bugfixes, bugfixes, bugfixes!!!
  • New SecSettings (thanks to yener90)
  • New SystemUI
  • Fixed Sbrowser
  • Fixed SViewCover
Version H “Hey, the KKK to my baby away” (internal joke!) (9.4.2014)
Version G ”Good Clean Fun (6.4.2014)
  • New Base (XXUFNC5)
  • massive cleanup: completely redone & rewritten
  • Added new S5 Apps ( SHealth, Snote, SPlanner, S-Baro etc)
  • LTE option can be selected
  • S5 Launcher & Themes
  • S5 Lockscreen Effect (flash after first boot as addon)
  • ISSUE: SBrowsersometimes crashes with activated smart functions (smart stay, smart scroll etc)
Version E "Evil Empire" (16.3.2014)
  • New Base VJUFNB2 (stability, but missing keyboard languages need to be downloaded)
  • Rework of all edited & added apps
  • New Galaxy S5 style reboot option
  • Galaxy S5 UI
  • Galaxy S5 style Accuweather widget
  • ViPER4Android FX integration (needs to be enabled in audio settings)
  • Note 3 style incoming PopUp Notification working (needs to be enabled under Phone settings)
  • FULL WIPE is RECQUIRED to avoid errors!
  • Adam Kernel 2.1 (more stable than previously used kernel)
Version D (12.3.2014)
  • Neue Galaxy S5 Apps ( Gear Fit Manager, Group Play, MyBoard, New Calculator, S-Translator, SVoice etc)
  • Einstellungen aktualisiert (zweites Icon entfernt)
  • FULL WIPE von anderen Versionen benötigt, ansonsten Addon flashen!
  • Talexop Kernel 2.4 (wird noch als 2.0 angezeigt)
Version C (10.3.2014)
  • Zurück auf XXUFNB8 Basis
  • Deutsch als Sprache hinzugefügt!
  • Galaxy S5 Status Bar
  • Fixed Multiview
  • kleine Verbesserungen unter der Haube!
Version B (8.3.2014):
  • geänderte Settings UI
  • weitere System-Apps gethemed
  • Performance verbessert
  • kleinere Änderungen
Bilder
Samy-Deluxe-S4-ROM-Screenshots.pngSamy-Deluxe-S4-ROM-Screenshots-2.pngSamy-Deluxe-S4-ROM-Screenshots-3.pngScreenshot_2014-06-30-12-35-25-576x1024.png
Screenshot_2014-06-30-12-35-36-576x1024.pngScreenshot_2014-06-30-12-36-16-576x1024.pngScreenshot_2014-06-30-12-36-29-576x1024.png
INSTALLATION
  • Download to internal SD card, do not put it on your external SD-card
  • Reboot into recovery. Please use TWRP
  • FullWipe or use option to factory reset
  • Install and reboot
  • Flash other addons after first boot (very important)
BEKANNTE BUGS & PROBLEME
credits
  • Seit Version L & M wird eine modifizierte SecSettings verwendet, die aus der PhoeniX ROM v9 stammen.
    Ich habe lediglich ein paar Änderungen durchgeführt.
  • XDA community (best, and will always be!)
  • zohawkish
  • shaji_ka_71
  • wanam (GOD of ROM)
  • MohammadAG
  • talexop
  • tamirda für Ultra Power Saving Mode und SecSettings.apk(PhoeniX Rom)
  • friedrich420
  • maxim000999
  • Repulsa
  • neodevkr
  • angelovitello (some new icons & apps)
  • irft
  • sanoc69 (mirror!)
  • rubbem06 (tested all apps!)
  • blackmen6969
  • gdmlaz
  • jserrano0628
  • robinmiclat
  • walid54
  • bigron77
  • zara86
  • perrito3
  • kristova86
Wichtig!!
Macht ein Nandroid(Backup) eures Systems!!
Thread @XDA
Ein
tut nicht weh. Wir machen uns die Arbeit auch für euch.:smile:
Reaktionen: twaks8, brainscann, tennesigi und 42 andere
leider funktioniert der DL Link nicht. DL bricht dauernd ab.
danke, sollte jetzt gehen! Werde noch zur Sicherheit ein paar Mirror hinzufügen!
Geht die auch mit dem alten BL?
Hallo nochmal,
Download hat funktioniert.
Was ist gemeint mit: Bei PhilZ Touch Recovery: “Don’t Allow Old update-binary” ->bitte (X) entfernen, da ansonsten Fehlermeldung erscheint??? Beziehungsweise was ist zu tun?
Danke schon mal
Du must im PhilZ bei "install zip" den Haken bei angesprochenen Punkt setzen. Ansonsten gibt's nen Abbruch beim Installieren.
Super,
danke hat alles soweit funktioniert. Erster Eindruck optisch schon mal sehr g*** :)
Der Punkt mit dem "Don't Allow Old update-binary" ist ganz wichtig, da sonst die ZIP-Struktur analysiert wird und die Recovery denkt, die Datei hätte eine falsche/veraltete Struktur.
So wie ich das sehe steht die Option in jedem Fall bei der aktuellen PhilZ Touch Recovery zur Verfügung, bei den anderen Recoveries taucht das "Problem" nicht auf.
Genau Richtig. Habe eine aktuelle Recovery und hatte den Punkt, da zuerst nicht gesehen, nicht rausgenommen und es funktionierte nicht. Danach lief es reibungslos.
hi, gefällt mir sehr gut. Herzlichen Dank.
Wie kann ich denn die deutsche Tastatur nachladen?
VG
Reaktionen: AeroGrafix
Hi. Die Frage wurde zwar schon gestellt aber nicht beantwortet geht die Rom auch mit dem alten Bootloader? Bzw wenn nicht wie Flashen? Gruesse OC
Würde mich auch interessieren. Komme von der echo 4.3. Und würde diese gerne probieren.
Gesendet von meinem GT-I9505 mit der Android-Hilfe.de App
VG
Online bei der Einstellungen von der Tatatur ;)
Der ursprüngliche Beitrag von 14:48 Uhr wurde um 14:57 Uhr ergänzt:
Also diese Rom basiert auf dem ECHOE v16so wie man es sehen kann ;)
Aber leider nur bedingt, den wenn man auf echoe kitchen gehen will, werden die einstellungen angehalten. Und warum habe ich im Menü 2x Einstellungen ??
Reaktionen: tosch85
Das ist noch ein Fehler in der Rom, wird wohl in einem der nächsten Update behoben... ist zumindest bekannt...
das ist ein blöder Umstand, der mich wurmt, aber ich habe keine befriedigende Lösung gefunden, die keine weiteren Probleme beim Nachladen anderer Sprachpakete macht.
Das Nachinstallieren der Tastatur geht folgendermaßen:
Einstellungen -> Mein Gerät (Eingabe und Steuerung) -> Sprache und Eingabe ->Samsung-Tastatureinstellungen -> Eingabesprache auswählen:
Hier Herunterscrollen bis zu "Verfügbare Sprachen" und "Deutsch" auswählen ("zum Herunterladen tippen").
Der ursprüngliche Beitrag von 15:52 Uhr wurde um 16:33 Uhr ergänzt:
Reaktionen: tosch85
@tosch85
schau doch mal unter Sprache und Eingabe oder nimmst die Google Tastatur aus dem Play Store die hat deutsches Layout.
Reaktionen: tosch85
Diese ROM basiert NICHT auf der Echoe ROM! Die aktuelle V16 ist auf XXUFNB8 Basis, Samy Deluxe auf XXUFNB9!
Die Erklärung ist recht einfach: die SecSettings (für S5 Optik) haben diese About ROM Infos drin. Man könnte sie mit Aufwand entfernen, aber um ehrlich zu sein, steck' ich die Arbeit lieber in andere Bereiche.
Also lieber genau hinsehen!:biggrin::biggrin::biggrin:
Leider wird die frage mit dem alten Bootloader nicht beantwortet :(
Bin auf I9505XXUFNA1 , kann ich die Rom direkt flashen, oder muß ich mit odin
erst auf XXUFNB9 sein ?
Ich habe zwischenzeitlich die 4.3 basierende Samy Deluxe Beta geflasht und bin wieder zurück auf die aktuelle 4.4.2 Samy Deluxe ohne Probleme.
Wie es sich mit offiziellen 4.3 ROMs verhält, kann ich nicht sagen.
Ich hatte irgendwann zwischendurch auch die I9505XXUFNA1 und habe nun problemlos eine XXUFNB9-basierende ROM drauf.
sav
Rosenköpfchen
  • Niklas434
Holomen
Holomen
Fifaheld
Fifaheld
Fifaheld
