Scum
Moderator
Teammitglied
- 6.439
Der eine oder andere wird die Roms von LorD ClockaN noch von DesireHD sehr gut kennen ...
Dazu könnt ihr folgende mini gapps flashen!
Die neuste Nightlie´s ink. Changelog ist hier zu finden:
AICP Downloads
AICP
<u>In the beginning I would like to thank:
AICP m7 dev team:
What is AICP?
AICP is known by someone as Ice Cold Project that started on Desire HD and since than evolved as a mature rom with the BEST community you can find!!!
Rom has always been AOKP based so expect all AOKP goodies + new additions.
If there are any bugs, either we will sort them or AOKP team if it conserns their modifications. This rom isn't AOKP supported so no need to report errors or bugs to them!!
LATEST STABLE RELEASE + CHANGELOG (INCLUDED IN DL LINK)
Download: LINK
Actual version: AICP 3.0 - 28-02-2014
What's New
KERNEL:
Kernel in this rom follows CM source with additions from @n3ocort3x so maybe you don't have to automatically search to flash new kernel after flashing rom. This kernel will also be continuously updated with patches and features.
CUSTOM KERNEL SUPPORT (teaMseven Kernel):
Please flash CM11 version (v54) ->STOCK in this ROM, no need for more
Feature list:
IceColdJelly AICP G+ community
What's Broken:
ROMS
ROMS should contain everything you need to enjoy JB. You are not required to install any Add Ons, simply download the latest ROM, gapps, flash it, and go!
You are STRONGLY recommended to fully wipe your device before flashing, and if possible avoid restoring system apps and system data with Titanium Backup - these can cause stability issues that are very hard to debug. If you believe you know what you're doing - then fine, go ahead, but please don't complain if you experience strange behavior.
How to flash:
You want to see a normal night at the DEV office, click here!!
If you want to contribute to the AICP or wanna see what is being worked on/merge feel free to visit our gerrit, link is at the bottom!!!
kernel git
rom gerrit
XDAevDB Information
[ROM] [28FEB] AICP - 3.0 - KK 4.4.2_r2, a ROM for the HTC One
Contributors
n3ocort3x
Version Information
Status: Stable
Stable Release Date: 2014-02-28
Created 2014-02-01
Last Updated 2014-02-28</u>
- AOKP team
- CM team
- maxwen
- SlimBean rom team
- ParanoidAndroid team
- CarbonRom team
- LiquidSmooth rom team
- Omni rom team
- Community
AICP m7 dev team:
- @LorD ClockaN
- @zipsnet
- @n3ocort3x
- @semdoc
- @eyosen
DONATIONS:
We are now paying for servers that build nightlies and everything that comes with it, so EVERY DONATION is going there.
Thank you!!
Thank you!!
What is AICP?
Download: LINK
What's New
- MMS: allow 6 line text input field
MMS: few APN fixes
MMS: Enter key: force newline
Dialer: Open source google dialer and more
Dialer: Add WhitePages Canada reverse lookup provider
Contacts: support for import contacts to local phone storage
Contacts: few patches
Screen recorder: add audio support
Screen recorder: settings
Toggles: longpress Torch to get into WhiteScreen
Framework AV patches
Add ADB Paranoia mode
Recents clear all button position
Ad blocker
TeloRadio
New Halo Icon
NFC polling mode
frameworks: Hope systemui improved battery life
Add 0.25x animation scale fof
Port BatteryBar
OmniSwitch as default for recents
Add Download Speeds in notification
Hebrew T9 for Dialer
Greek T9 support for Dialer
LatinIME: Add more emoticons
LatinIME: Add more extended ASCII characters
Left handed navbar for landscape mode
Updated translations
Bugfixes
Updates to kernel
And a lot more that didn't fit in here
KERNEL:
Feature list:
- AOKP features
- TRDS Dark switch
- Halo
- OmniSwitch
- Profiles
- Lockscsreen Notifications
- Active Display
- Wakelock blocker
- System app Remover
- Animations
- Lockecreen color theming
- Lockscreen blur, gestures etc...
- etc...
What's Broken:
ROMS
How to flash:
- Don't do it if you don't know it
- ROM has gapps persistance in between dirty flashes
kernel git
rom gerrit
XDAevDB Information
Contributors
n3ocort3x
Version Information
Status: Stable
Created 2014-02-01
AICP Downloads
