taiman23
Philosoph
- 5.626
Hat schon einer die FRD-L09C432B120 installiert
Rückmeldung HonorUK:
Hi... , I had to reject the thread about the Honor 8 B120 firmware, it isn't a straightforward update. If you check the URL here http://update.hicloud.com:8180/TDS/data/files/p3/... it shows three different zip files that need flashing. It is going to problematic for people to correctly manually flash all of those files. So it is best to leave it to the OTA process. Apologies.
Full:
B120
Changelog:
This update helps reduce system power consumption and improves stability. Please update your device for improved experience.
[System]
Reduced system power consumption and improved stability. Improved device security with the latest Google security patches.
[Update notes]
1. Before the update, make sure your phone is not rooted. If you experience any issues during the update, please go tohttp://consumer.huawei.com/ or an authorized service center for assistance.
2. This update will not erase your personal data.
Full:
B120
Changelog:
[System]
[Update notes]
