2WF
Ikone
- 15.535
Erster Custom stock JB Kernel aus den sourcen von HTC um sweep to wake erweitert.
Gibt es hier
Kernel 27.02.13 Jelly Bean sweep2wake Kernel | HTC One X > XDA
Hab den unter OrDroid laufen, bin voll zufrieden.
Und hier gibt es eine neue Version von Alex-V Alex-V_S.E_0.6_fixed_incom_call/touchscr /Viper-UMS /cpuquiet/BLN
Habe ihn unter OrDroid 14.0.0 am laufen, mal sehen wie der sich so macht.
[08.04.13] [Kernel] | HTC One X > XDA
CHANGELOG
Changelog 2.7 Classic PA 2
-original hotplug (still faster in ui)
-no auto bln (had a 8h wakelock from buttons blink
-so its bad for battery)
-still buttons backlight brighness control
-smartmax and row as default (to compensate battery from original hotplug)
-wakes fast
-disabled 3D Scaling as default (can be enabled if wanted)
-fastcharge again
-3 versions
=old s2w
=old s2w with led buttons go on on slide (buggy)
=new s2w with dt2w
-repacked with sebby´s edited ramdisk (optimations and htc pnp manager compatible)
-enabled wifi powersave again (like original)
DL
Download Alex-V HTC Roms from SourceForge.net
Changelog 2.6 RC
-mpdecision hotplug (after your tests..it seems the best..thx to all)
-fixed light sensor (this fixes button backlight only go off on really sunny day..back to normal now)
-wifi: allow reconnect if already connected
-wifi: pre power up wifi =will fix sometimes not working wifi [if you still see its connected] i hope...my tests are good -interactive, smartmax, pmc from 2.4...it looks like these are the best atm
-still 3 versions: old s2w, new s2w with dt2w and without s2w -updated git with latest changes
Download: 2.6RC
Changelog 2.1
-fixed all cores online
-fixed max Cpu Freq on boot back to 1300mhz (will fix the to hot on Start-save boot)
-original Nvidia Hotplug -removed TDF Framework/Hotplug
-still based on trips ( so thx to him ) -OC
-Auto_BLN (led backlight notification)
-LED backlight brightness -(Viper)/UMS
-(for other rom it must be tested)
-original Fastcharge (must be enabled before)
-Control how many cores online
-old S2W
-new S2W with DT2W
-new govs =Smartmax =PMC =Touchdemand =Gaming
-new I/O Sheduler =Row =Sio =Cfq -original vibration
-maybe more -on my list:look to bt and wifi from original/mpdec/gpu interface/etc...etc
Download 2.1 Sense 5 Kernel
Find out more about Alex-V HTC Roms | SourceForge.net
Changelog 2.0
-based on trips latest only working sense 5 kernel source (thx @TripNRaVeR)
-first test release
-Sweep2Wake (S2W)
-pocket protection
-as kernel is based on his aosp source (which is the latest updated)
=fixed Sound and usb
-as default interacive (with 1.3 max at boot) no oc atm
-as default deadline with 128kb read ahead
-no repack for sense 5 needed
-till we have the htc source i will look on mhl (because of tegra4 driver)...maybe back to original wifi and vibration and also will look at hotplug
Download 2.0 Sense 5 Kernel
Changelog 1.7
-smartmax and pmc gov from xm304
=to get it work some cpu patches from 304
(found one bug in last minute - i can set 1.6ghz but max is @1.55ghz
please dont report this - i know it and will fix)
-3 versions:
=old s2w (now with pocket protection and calibration control) - should solve call problems
=new s2w (this version contains the touchscreen source from viper 11 kernel + calibraion control)
=new s2w + dt2w (also with calibration control)
=new but still compatible viper ramdisk (also for all other sense roms-no need to repack)
-new viper tweaks beta 3.7.9 with calibraion control toggle (thx richmondo)
=means you can now quick toggle it on or off if you have call problems
next version should be a rc 1 with working vpn
Download 1.7Kernel
Download Viper Tweaks 3.7.9 with calibraion control toggle
Download Viper Tweaks 3.7.9 with calibraion control toggle if you got fc with old s2w
Changelog 1.5 Test Kernel
-as requested auto-bln
-old s2w with all old values and calibration off (multitouch fix) =^ this should solve end call problem for someone...incoming needs testing
-lp core low voltage disabled (as i had a reboot while charging..since i got no problems)
Changelog 1.5
-OC and Voltage table from 0.8 again = (up to 1.6 ghz for variant 0+1 and 1.7 for 2+3)
-updated git
Download 1.5 Test Kernel
http://sourceforge.net/projects/alex...l.zip/download
Download 1.5 old and new s2w
http://sourceforge.net/projects/alex...5.zip/download
Changelog 1.3
-changed cpu table values (still 1.55 ghz but the way it will be used) -changed millivolts table (you want notice...but stabilty)
-again old and new s2w (the way you like it)
-added gaming gov (thx xmister) [see Epic Citadel Benchmark over 50) -added pmc (battery gov)
-still nvidia hotplug -very stable (at least for me 2 benchmark Epic Citadel and no reboot with gaming gov)
-perfect miixture between xmister / kozmickick /n3o / maxwen
Download 1.3 old and new s2w
http://sourceforge.net/projects/alex...3.zip/download
CHANGELOG
Change 0.8
-oc and voltage table from latest kozmik version (big thx again, you are great)
-touch input updates (thx maxwen)
-s2w update (thx maxwen)
- my source git to this
https://github.com/Alex-V2/Alex-V_SE_OneX/tree/play2
Alex-V_S.E_0.7_fixed_incom_call/touchscr /Viper-UMS/cpuquiet/DT2W
DL V_se.0.8 Download Alex-V HTC Roms from SourceForge.net
Neuer Kernel ist up
CHANGELOG
-removed auto-bln (its not stable enough for me)
-added complete ums (must be tested as i´m on viper
-added 85°C throttle back
-added the new s2w (no viper tweaks error-2-3 buttons) thx maxwen -added Double tap 2 wake (DT2W) thx maxwen
Download 0.7: Download Alex-V HTC Roms from SourceForge.net
Gibt es hier
CHANGELOG
-wakes fast
-fastcharge again
-3 versions
=old s2w
=new s2w with dt2w
DL
Changelog 2.6 RC
Download: 2.6RC
Changelog 2.1
-old S2W
-new S2W with DT2W
Changelog 2.0
-first test release
-Sweep2Wake (S2W)
-pocket protection
Changelog 1.7
-3 versions:
Download 1.7Kernel
Changelog 1.5
-updated git
Changelog 1.3
CHANGELOG
Change 0.8
Neuer Kernel ist up
CHANGELOG
