Poor audio on handsfree bluetooth
V
Vinay4584
Hi All,
We are experiencing the same poor audio quality when making calls using hands free Bluetooth calls in company vehicles. This is across 8 devices in the company with audio problems. The reason point to the CAT S60 handsetcant work out what is causing this.
Have raised with CAT Phone support and they have a similar resolution (see below). This has not improved audio quality whatsoever unfortunatley and our FSE's rely on making / receiving calls in their vehicles on a daily. Can anyone help with this problem? Thanks in advance.
Dear Mr Dhimar,
Thank you for contacting CATPhones Support.
I can advise that in some cases.
> Go to Settings.
> Go to Apps
> Click the three dots in the right hand corner.
> Choose Show System
> Go to Bluetooth Share
> Click Storage
> Choose
ClearCache Bluetooth is an open standard so if it is connecting, then the handset is working, however, this looks like an interoperability issue. The manufacturer of the car kits have to be able to do their own thing. We would recommend you visit the manufacturer website for your car and check which compatibility tests have been done. If we are not on the list,
It means the manufacturer has not been tested and has not been tested. If you have any further questions, please do not hesitate to contact us.
Kind regards,
Michelle
CATPhones Support
ref: _00Dj01o5yW._5000aTzlRp: ref
V
vnloth
V
Tobi1982
winne
