Problem mit eigenen ListViewAdapter
Scogit
Servus,
ich hab ein Problem mit einen Adapter.
Das TextView Objekt title ist immer null.
Hat hier jemand eine Idee warum das Object nicht gefunden wird?
Code:
public class ProgramAdapter extends BaseAdapter {
    private Context mContext;
    private int mRowResID;
    private Vector<EpgChannel> mProgramList;
    public ProgramAdapter(Context context, int rowResID,
            Vector<EpgChannel> programList) {
        mContext = context;
        mRowResID = rowResID;
        mProgramList = programList;
    public int getCount() {
        return mProgramList.size();
    public Object getItem(int position) {
        return mProgramList.get(position);
    public long getItemId(int position) {
        return position;
    public View getView(int position, View convertView, ViewGroup parent) {
        EpgChannel EpgChannel = mProgramList.get(position);
        LayoutInflater inflate = LayoutInflater.from( mContext );
        View v = inflate.inflate(mRowResID, parent, false);
        EpgEvent event = EpgChannel.iterator().next();
        TextView title = (TextView) v.findViewById(R.id.title);
        title.setText(event.getTitle());
        return v;
Code:
public class CurrentActivity extends MainMenuActivity {
    /** Called when the activity is first created. */
    @Override
    public void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.current);
        JRegistry registry = JRegistry.getInstance();
        if  (registry.isRegistered("CommandWrapper")) {
            CommandWrapper cmdWrapper = (CommandWrapper) registry.locate("CommandWrapper");
            Vector<EpgChannel> result = cmdWrapper.getProgram(CommandWrapper.PROGRAM_CURRENT);
            ProgramAdapter programAdapter = new ProgramAdapter(
                                            this,
                                            R.layout.program_row,
                                            result);
            ListView myList = (ListView)findViewById(R.id.mylist);
            myList.setAdapter(programAdapter);
Code:
<?xml version="1.0" encoding="utf-8"?>
<TableLayout android:id="@+id/TableLayout01" android:layout_width="fill_parent" android:layout_height="fill_parent" xmlns:android="http://schemas.android.com/apk/res/android">
<TableRow android:id="@+id/TableRow01" android:layout_width="wrap_content" android:layout_height="wrap_content"><TextView android:text="TextView01" android:id="@+id/TextView01" android:layout_width="wrap_content" android:layout_height="wrap_content"></TextView><TextView android:text="TextView02" android:layout_width="wrap_content" android:layout_height="wrap_content" android:id="@+id/title"></TextView>
</TableRow>
</TableLayout>
Ich weis nicht wirklich was ich jetzt anders gemacht habe da kein Unterschied zu sehen ist aber nachdem ich einmal Project -> clean aufgerufen habe scheint es zu funktionieren.
FabianDev
swa00
swa00
Ritartet
  • RudolfHagen
koje71
koje71
