Programmier Problem
DonnerBalken1
hi ich hab ne frage und zwar wenn ich meine app starte kommt immer :
The application ....(process ...)has stopped unexpectedly.Please try again!
wie fixe ich den error?
activity:
package Crocos.Stauf;
import android.app.Activity;
import android.os.Bundle;
import android.view.View;
import android.net.Uri;
import android.content.Intent;
public class CrocosActivity extends Activity {
/** Called when the activity is first created. */
@Override
public void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView(R.layout.main);
private void goToUrl(String Url){
Uri uriUrl = Uri.parse(Url);
Intent launchBrowser = new Intent(Intent.ACTION_VIEW, uriUrl);
startActivity(launchBrowser);
public void goToJuS(View view){
goToUrl("http://www.briv-online.de/team/128/liga/205/");
public void goToJuT(View viewI){
goToUrl("http://www.briv-online.de/liga/205/tabelle/");
public void goToHIS(View viewII){
goToUrl("http://www.briv-online.de/team/124/liga/199/");
public void goToHIT(View viewIII){
goToUrl("http://www.briv-online.de/liga/199/tabelle/");
public void goToHIIS(View viewIV){
goToUrl("http://www.briv-online.de/team/138/liga/201/");
public void goToHIIT(View viewV){
goToUrl("http://www.briv-online.de/liga/201/tabelle/");
main.xml :
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:id="@+id/LinearLayout2"
android:layout_width="fill_parent"
android:layout_height="fill_parent"
android:orientation="vertical" >
<TextView
android:id="@+id/textView1"
android:layout_width="wrap_content"
android:layout_height="wrap_content"
android:layout_gravity="left"
android:layout_marginTop="10dp"
android:text="@string/Herren1"
android:textAppearance="?android:attr/textAppearanceLarge" />
<Button
android:id="@+id/button1"
style="?android:attr/buttonStyleSmall"
android:layout_width="150dp"
android:onClick="goToHIS"
android:text="@string/h11" />
<Button
android:id="@+id/button4"
android:onClick="goToHIT"
android:text="@string/h12" />
<TextView
android:id="@+id/textView2"
android:text="@string/Herren2"
<Button
android:id="@+id/button2"
android:onClick="goToHIIS"
android:text="@string/h21" />
<Button
android:id="@+id/button5"
android:onClick="goToHIIT"
android:text="@string/h22" />
<TextView
android:id="@+id/textView3"
android:layout_marginTop="20dp"
android:text="@string/Jugend"
<Button
android:id="@+id/button3"
android:onClick="goToJuS"
android:text="@string/j11" />
<Button
android:id="@+id/button6"
android:onClick="goToJuT"
android:text="@string/j12" />
<Space
android:layout_gravity="fill_horizontal" />
<TextView
android:id="@+id/textView4"
android:layout_marginTop="40dp"
android:text="@string/briv"
android:textAppearance="?android:attr/textAppearanceSmall" />
<Space
android:layout_gravity="fill_vertical" />
</LinearLayout>
Log:
06-23 12:26:46.312: E/AndroidRuntime(582): ... 20 more
außerdem möchte ich noch ein hintergrundbild für die app einfügen
wie geht das?
sorry wenn das problem simpel zu lösen ist aber ich bin neu hier^^
Danke für eure Hilfe!
MFG
Ein vollständiger Logcat wäre sinvoll um das Problem zu finden.
Zeigt dir Logcat nicht noch mehr an, außer:
"06-23 12:26:46.312: E/AndroidRuntime(582): ... 20 more"?
EDIT: Da war wohl jemand schneller... :flapper:
wie krieg ich den vollständigen logcat ich hab ihn ja als txt dokument gespeichter und mehr gibt das nich an..
mfg
Reaktionen: GENiALi
Was ich mittlerweile herrausgefunden hab:
Ich hab das teil auf android 2.3.3 probiert da kommt der error aber ich hab die version in der manifest auf 10 geändert aber auf der 4.0.3 läuft das teil einwandfrei. Kanns sein dass ich irgendetwas verwendet habe dass nicht in der 2.3.3 verwendet werden kann?
Mfg
Eclipse zeigt das Log eigentlich sehr auführlich, das wäre durchaus hilfreich zur Problembehandlung ;)
06-30 17:14:48.931: E/AndroidRuntime(364): at android.view.LayoutInflater.inflate(LayoutInflater.java:408)
06-30 17:14:48.931: E/AndroidRuntime(364): at android.view.LayoutInflater.inflate(LayoutInflater.java:320)
06-30 17:14:48.931: E/AndroidRuntime(364): at android.view.LayoutInflater.inflate(LayoutInflater.java:276)
06-30 17:14:48.931: E/AndroidRuntime(364): at android.app.Activity.setContentView(Activity.java:1657)
06-30 17:14:48.931: E/AndroidRuntime(364): at crocodiles.stauf.CrocodilesActivity.onCreate(CrocodilesActivity.java:14)
06-30 17:14:48.931: E/AndroidRuntime(364): at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1047)
06-30 17:14:48.931: E/AndroidRuntime(364): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1611)
06-30 17:14:48.931: E/AndroidRuntime(364): ... 11 more
06-30 17:14:48.931: E/AndroidRuntime(364): Caused by: java.lang.ClassNotFoundException: android.view.Space in loader dalvik.system.PathClassLoader[/data/app/crocodiles.stauf-1.apk]
06-30 17:14:48.931: E/AndroidRuntime(364): at dalvik.system.PathClassLoader.findClass(PathClassLoader.java:240)
06-30 17:14:48.931: E/AndroidRuntime(364): at java.lang.ClassLoader.loadClass(ClassLoader.java:551)
06-30 17:14:48.931: E/AndroidRuntime(364): at java.lang.ClassLoader.loadClass(ClassLoader.java:511)
06-30 17:14:48.931: E/AndroidRuntime(364): at android.view.LayoutInflater.createView(LayoutInflater.java:471)
06-30 17:14:48.931: E/AndroidRuntime(364): at android.view.LayoutInflater.onCreateView(LayoutInflater.java:549)
06-30 17:14:48.931: E/AndroidRuntime(364): at com.android.internal.policy.impl.PhoneLayoutInflater.onCreateView(PhoneLayoutInflater.java:66)
06-30 17:14:48.931: E/AndroidRuntime(364): at android.view.LayoutInflater.createViewFromTag(LayoutInflater.java:568)
06-30 17:14:48.931: E/AndroidRuntime(364): ... 20 more
mit dem ..11 more und dem ..20 more da hat er mir nich mehr ausgegeben.
MFG
Der ursprüngliche Beitrag von 19:24 Uhr wurde um 19:28 Uhr ergänzt:
Btw ich hab nur bei der manifest das 15 auf 10 geändert macht das irgenetwas? bzw kann das daran liegen?
Mfg
Mfg
Das ist dein Problem:
Der Widget "android.view.Space" kann nicht gefunden, da diesen erst seit API Level 14 (Android 4.0) gibt. Entferne die <Space ... /> aus der main.xml, dann läuft es auch unter 2.3.3
Reaktionen: DonnerBalken1
Oh man bin ich blöd da nich selber drauf zu kommen :D
Ok danke :) er funktioniert jetzt auf 2.3.3 :)
Dummheit Dummheit Dummheit xD da kommt doch sogar n voller anfänger drauf wenn da cause steht...ohh man :D
Trotzdem Danke :) (warsch hätt ichs sonst immernoch nicht gepackt xD)
Mfg
Der ursprüngliche Beitrag von 19:58 Uhr wurde um 20:01 Uhr ergänzt:
Krieg ich den Space auch noch irgendtwo anders her? also dass es auch auf der 2.3.3 arbeitet?
Der ursprüngliche Beitrag von 20:01 Uhr wurde um 21:19 Uhr ergänzt:
  • Gesperrt
  • roland-senior
swa00
swa00
  • WuDiDong
jogimuc
