[ROM] DNA_GB 3.3.3 V21E base with tweaks for performance [/5/5/2012]
lynn0r
Scheint eine ziemlich interessante und sehr smooth laufende ROM zu sein!
Quelle: [ROM] DNA_GB 3.3.3 V21E base with tweaks for performance [/5/5/2012] - xda-developers
DNA_GB 3.3.3 based on the new V21E
Very stable V21E rom with stock theme if you want a theme you can take the systemUI.apk and the Framework-res.apk out of the rom and use it in UOT to make your own theme..
Features:
*Base: V21E..
*Kernel: Stock kernel with ram management tweaks...
*EXT 4 Ability
*Battery Stats Fixed!
*Performance tuning..
*Speed tweaks
*Smoothness Tweak added
*Init.d support
*SD Bosst
*Better 3G speeds..
*Better video and image quailty..
*Disabled all LG crap except flex..
*Wifi fix (better management) now you can use any kernel...
*Better video streaming..
*Better screen transition very responsive..
*Extra Ram Tweaks..
*Deodexed
*Zipaligned
*No apps installed (app installation is upto the end user)
*Updated HTC Beats modules
*Updated to True Bravia Engine...
*Xloud Engine..
Kernel it takes are 21A kernels at the moment i have not changed anything just seems to work with 21A kernels untill lg release 21E source you will have to use 21A kernels..
How to Install:
This is a new base you cannot flash over V21D you must wipe everything before flashing this rom...
1. Download the rom duh..
2. Put the rom in your SD Card.
3. Boot into your recovery via rom manager.
4. Make full wipes.
5. Flash the rom.
6. Let it start.
7. After it has started and you set everything up download any 21A kernel and use it with DNA_GB 3.3.3..
Download Link to DNA 3.3.3: Hotfile.com: 1-CLICK Dateihoster: DNA_GB 3.3.3.zip
Smart Flash: SmartFlash.exe
Use smart flash to install basebands without having to update via kdz..
Werde ich am Wochenende mal testen. Wem der Download über hotfile zu langsam ist ---> PN an mich
Ich nutze die DNA 3.3.3 jetzt seit ungefähr einer Woche. Ich komme vom Galaxy Nexus& S3, bin also extrem gute Performance und Akkulaufzeiten gewohnt.
Das 3D läuft mit der 3.3.3 recht schnell und halbwegs flüssig, das Scrolling in Menüs und vor allem in Tapatalk ist extrem smooth (beeindruckend für 2.3.5 Gingerbread! :))
Bei intensiver Nutzung muss mein 3D bereits gegen Mittag an die Steckdose aber das wusste ich ja schon vor dem Kauf. Wenn man nur hin und wieder mit dem Smartphone spielt, kommt man natürlich ohne Probleme durch den Tag.
Trotz der stark abgestaubten Software bin ich mit dem 3D aber sehr zufrieden!
Mit der 3.3.3 + Blue-Kernel 120 + 1.3GHz OC kann man auch als Quadcore/Jellybean verwöhnter User sehr gut leben....
[ Optimus 3D | DNA 3.3.3 | OC Kernel ]
palma
palma
palma
I
wholefish
Driv3r
