[Sammy-ROM] *06.06.12* [XWLPG] Pure Look S3 " Design by Nature" [v3.1.1 Final] [Jkay]
Chris1996
Chris1996
Stammgast
141
Pure Look S3
Pure look S3 - simple - Fast - smooth _ stable - battery friendly !
System Details:
- Rooted
- Busybox
- Deodexed
- NO WIPE
- Hosts Adblocking
- Improved Touch Sensitivity
- GPU Acceleration
- WiFi tweak saving battery
- Scrolling improved responsiveness
- SONY BRAVIA: Increase the quality of photos and video
- Modified Dalvik VM 180MB heap size
- The user interface rendering with GPU
- Internet connection ottimizzat
- Fewer delays in calls
- Sensor Screen Delay off
- Memory management improved
- Added Power Panel: Reboot
- Download
- Hot boot
- MicroSD Card speed 1024KB / s
- Market connections Fix Speed
- Switch-off the camera when the battery charge 0%
- Video / audio profiles 24-20Mbps/192Kbps_44100Hz
- Disabled increased volume for incoming calls
- Removal of the options for reducing noise in call
- Off SMS to MMS
- no autoconversion
- Deactivated limit number of contacts for the simultaneous sending
- Increase the maximum size of messages sent with 300 KB to 1 MB
- Increase the response speed automatic brightness control (ABC)
- Faster and smoother transitions of brightness (ABC)
- Custom Brightness
- static bus frequencies
- DeepSleep custom levels
- Tweaks GPS
- Tweaks WIFI/3G/4G
- AutoBackup EFS Folder
- YoutubeHD Mod (Wifi-3G)
- Mod LockScreen
- Tweak your SD card for added control features: Lock Screen:
- ICS / SAMSUNG
- Text display screen unlock: ON / OFF
- Torch lock screen when you press the home button: ON / OFF
- Delay action to pressure the home button: ON / OFF
-Changed Sound Power - Added pach font characters
-Call Recording no Full Screen
-15 toggles the status bar + battery percentage %
-Silent Camera - eliminated sound battery
-Mod. Play Store
-Other extras: Audio Beats with a better sound quality and power thanks to
-app volume + - youtube hd that is 3g wifi and much more ....
-Added apk:Touchwiz Galaxy S3, 80 pack font, SwiFTP, CMW Manager,
-FasterFix
-Added soung notification Galaxy S3
-rom nowipe
-fixed boot and many Fc ( Pm me if you still Fc )
-syiah v3.2.6.4 ( newest)
-NELP3 modem ( better battery life)
Changelogs:
Update 6/6/2012 : v3.1.1 final XWLPG
—» Stock dialer + no call big picture
—» Remove Jkay setting ( buy here here or here)
—» added googleSeachWidget S3
—» Fixed icon camera
—» Fixed theme of Task manager & Video player ( stock theme)
—» Syiah kernel v3.3.1+
—» more Build.prop and tweak in init.d
—» disable MTP ( USB stogare is defaul)
...and other things i don't remember.
and much more... you can find in my rom :D
Falls ihr keinen Lockscreen-Wallpaper einstellen könnt downloaded touchwiz UX 1.5.1 oder 1.4 und das Problem ist behoben ;)
Downloads:
-Pure Look S3 v3.1.1
Mods:
Battery Green %
GreenCircle
Stock Battery - no %
XDA-Thread
Reaktionen: bobby21 und kiriakos1963
download geht nicht, wird nicht gefunden
[Sammy-ROM] *30.05.12* Pure Look S3 " Stock theme" XWLPD v2
Download
Reaktionen: xneo70 und svs2610
wo downloade touchwwiz UX 1.5.1 or 1.4 ich das?
denn bei mir geht das auch nicht.
aber sonst TOP!
ich möchte nämlich ein live wallpaper von der blume.. geht das?
bei mir stürtzt der TouchWiz launcher ständig ab und die widgets laden nicht...
was kann ich machen?
wenn ich es nochmal installiere, bootet das handy nicht.
und dann muss ich die firmware wiedr per odin neu flashen..
deshalb möchte ich es vermeiden, neu zu installieren und suche nen anderen weg, die probl. zum laufen zu bringen.
danke
Die Rom scheint nicht zu laufen. Ich glaube, eine S2 Rom in dem Look einer S3 Rom zu basteln ist für die Devs nicht möglich. Da gibts wohl zu viel Probleme
Ich dachte soo wooow mega geil, genau was ich suche!
und boom geht leider nicht... manchmal fährt es nicht hoch, wenn schon dann bleib ich am anmelde assistenten hängen (auf deutsch [deutschland] sofort auf deutsch[österreich] komme ich ein wenig weiter, es wird allerdings alles 1000 mal abgefragt...) und wenn er doch mal durchkommt bleibt danach der bildschirm schwarz...
echt schade naja, wäre sehr erfreut wenn man diese rom vernünftig zum laufen kriegt :)
Bei mir läuft die v2.0 einwandfrei. Habt ihr nach dem flashen Wipe dalvik und Fix permission gemacht? Steht auch im xda Thread :rolleyes:
Sent from a second Galaxy
na dann werd ich es auch nochmal probieren,warte aber bis V3. Ist im Anmarsch
Sehr cool funktioniert jetzt auch, hab cih beim ersten mal vielleicht etwas vergessen hmmm. Aber freue mich sehr, das es jetzt geht :)
Komisch habs schon n paar mal geflasht aber die Rom hängt immer im Bootloop -.- Werd wohl auch noch auf die v3 warten :D
Sent from my GT-I9100 using Tapatalk 2
Uiiii v3 ist online und kommt mit JKay!
—»Build XWLPG
—»JKAY support ( you can buy jkay setting from here or here)
—» Deodexed + Rooted + Zipaligned ( if root is failed, flash this over CWM : http://www.mediafire.com/?ut07xl4ei0b7d8r
—» Modem XXLPX
—» Syiah kernel 2.3.7.2+
—» Boot animation S3
—» boot sound S3
—» Shutdown animation S3
—» Update new and more icon S3
—» For who want call rec mod- flash this : http://www.mediafire.com/?k3qgplzdb84tfj3
—» remove some samsung apk
—» transparent dialer UI
—» sms/mms hacked
Download
https://sourceforge.net/projects/romasv1/files/XWLPG_purelook S3_by_ksr007 v3.zip/download
Wie schauts eigentlich mit Themes aus, worauf muss ich achten, wenn ich mir welche flashen möchte ?
einfach drüber flashen ;)
muss ich da nicht auch drauf achten, dass die Themes für LPG geeignet sind ?
Einmal ist ja die 3.1 schon raus...^^
DOWNLOAD V3.1 XWLPG
und die 3.1.1 schon angekündigt
""v3.1.1 will coming in a 4hours ! fix dialer, icon camera, remove JKAY setting , add search widget S3...
Finds schon erbärmlich, dass der Dev nach wie vor Jkay app in seine Rom als freeware einbaut.
Ääh... und wo genau ist jetzt dein Problem?
Man muss sich dann die Deluxe Settings noch aus dem Google Play kaufen.
Also woran liegt das Problem?
Kjetal
fotia1980
fotia1980
Jtotheo
Chris1996
Mirok80
