Chris1996
Stamm-User
- 141
Hi @ all!
War heute auf xda unterwegs und bin auf die Rom hier gestoßen:
[ROM][AOSP][4.0.4][IMM76I][01-05-12] F1 GalaxyNexus| Pure Galaxy Nexus Experience - xda-developers
F1 GalaxyNexus is a ROM built entirely from Google's ICS source code. The main idea behind this was to give users the experience of pure ICS as it is on the Galaxy Nexus with no visual changes and ZERO bloatware or any 3rd party app. F1 GalaxyNexus is just plain AOSP ICS with under the hood tweaks, optimizations and the features to make AOSP a little bit better. Big Kudos to Teamhacksung as without them this ROM was not possible. This ROM will be updated on a daily basis and will be also updated whenever Teamhacksung improves the device tree or patch new stuff.
System Details:
-Android ICS 4.0.4 (IMM76I - Android-4.0.4_r1.2)
-Latest CM Source Compiled Kernel
-Multi-Language
-All ICS Features and Apps (Nothing excluded from AOSP)
-No Visual Changes!
-Stock ICS Look and Feel
-This will turn your Samsung Galaxy S2 into a Galaxy Nexus
ROM Features:
-Fully Deodexed
-Zipaligned APKs
-Rooted (Superuser)
-BusyBox Installed
-No 3rd Party App
-ZERO Bloatware
-Official ICS Bootanimation (From Official Nexus S 4.0.4 Firmware)
-Extended Power Menu (Reboot, Recovery & Download)
-Galaxy S II Settings In The Launcher (Device Settings)
-Tweaked Scrolling Cache (Smooth Scrolling)
-Huge APN & SPN List (Thanks To CM)
-Patched Settings with F1 Version
-EXT4 File System Optimizations
-SD-Card read ahead Tweak
-Init.d Support
-Fully Working Mass Storage
-T9 Dialer Functionality
-Landscape Dialer Support
-Notification Toggles (Press and hold the settings icon in the notification bar to reveal them)
-180 degree rotation enabled
-Both MTP/UMS Support (Settings>Storage>Press Menu>USB Computer Connection)
-Video Recording in MP4 with higher bitrate and Stereo Audio Recording
-Storage Option In Camera (Internal SD Card, External SD Card & USB Storage)
-F1ROM Build Prop Tweaks
-Enabled GPU UI rendering
Known Issues:
-Same CM Known Issues (Teamhacksung List)
-Found one ? Comment below.
Requirements:
Clockworkmod Recovery (CWM)/Any custom recovery
Wipe if coming from any other ROM
How To Install:
-Copy GAPPS and F1 GalaxyNexus to your internal SD Card
-Enter Recovery
-Do a Wipe/Factory Reset (OPTIONAL:If already on F1 GalaxyNexus skip this step but it's always recommended to Wipe your device)
-Flash F1 GalaxyNexus ROM
-Flash GAPPS
-Reboot your device!
-Voila!
Downloads:
Latest Build:
F1 GalaxyNexus Build 5 - TEST BUILD 1
Google Apps:
gapps-ics-20120429-signed.zip
Previous Builds:
F1 GalaxyNexus Build 4 (01-05-12)
F1 GalaxyNexus Build 3 (23-04-12)
F1 GalaxyNexus Build 2 (17-04-12)
F1 GalaxyNexus Build 1 (15-04-12)
Source Code:
F1 GalaxyNexus @ Github
Click here to donate
PS: Der
-Button tut nicht weh
System Details:
-Multi-Language
-No Visual Changes!
ROM Features:
-Fully Deodexed
-Zipaligned APKs
-Rooted (Superuser)
-BusyBox Installed
-No 3rd Party App
-ZERO Bloatware
-Init.d Support
Known Issues:
Requirements:
How To Install:
-Enter Recovery
-Flash GAPPS
-Voila!
Downloads:
Latest Build:
Google Apps:
Previous Builds:
Source Code:
PS: Der
