[Kernel] 4.4.2 [Stock Rom] SimpleKernel v1.0
  • 48 Antworten
LGG2kitkat2
Gast
Hi
ich wollte hier mal einen neuen Thread aufmachen, ich hoffe im richtigen Bereich, da hier auch andere custom Kernel gepostet sind. Der Kernel ist leider nur nebenbei in nem andren Thread erwähnt, da dachte ich, ich eröffne mal die "kitkat custom kernel ecke" :rolleyes2:
[Kernel] 4.4.2 [Stock Rom] SimpleKernel v1.0 [D80x/LS/F320] - xda-developers
Simple Kernel V 4.0
For 4.4.2 stock based roms and stock variants
- Based on Stock LG 4.4.2 Kernel
- Thermal control (Franco)
- Mpdecision replacement (Franco Mako Hotplug)
- A single, well tuned interactive governor based on CAF source, not bloated with tons of govs. Still contains performance gov for users who need it
- Tuned frequency control, cores will not max, boost or turn on unless needed. This saves battery without losing performance,
- CAF touch boost driver (Will ensure cores do not go crazy when touching screen like stock)
- Voltage Control
- Can choose to download a version that supports overclocking (See FAQ)
- All modules built in, no modules folder. Slimed down kernel size. Junk Removed.
- Motorola memory optimizations
- Many improvements
FAQ
Can you add "x" governor?
I will not add additional governors. The goal of this kernel is a simple, fast smooth kernel with one well tuned governor that works as intended. There is no advantage for me to add additional governors to my kernel, only downsides.
Why are 2 cores online all the time?
The hotplug I am using uses 2 cores online. Leaving 2 cores online while the screen is on is more efficient on both battery and performance rather than having the second core hotplugging nonstop.
Why is there an OC and non OC version?
Many people don't know this, but even using an overclocking compatible kernel ups the Vcore on your CPU whether you actually increased the frequencies or not. (Vcore is the amount of power supplied to the CPU) This increases the heat of the phone by a bit. The extra voltage is needed for the CPU to stay stable if the user overclocks. The only way to drop this extra voltage to the CPU is by making a version not capable of overclocking. If you have no intention of overclocking, download the non OC version.
Coming Soon
LS980
VS980
Downloads
(See FAQ on OC vs Non OC)
OC Enabled
OC Disabled
Old versions
Changelog
V4.0:
Hotplug and Interactive settings returned to v1 (Until franco figures out the issues with his changes)
Use power efficient workqueues (supposed to be better on battery)
Screen should turn on a bit quicker after knock on / power button
Add a 345mhz step for users who may get audio glitched on 300mhz with certain apps
RGB control is now functional, you can use trickster to adjust it
Add VS980 Support and LS980 Test kernel.
Reaktionen: Bukongahelas, hms, Flat-Eric und 2 andere
Hat jemand einen Link wo ich den Stock Kernel her bekomme damit ich evtl. wieder zurück flashen kann?
Hast du den Kernel schon getestet?
Nicht OK?
@ Switchgott Nein möchte ihn erst testen wenn ich den Stock KitKat Kernel habe sodass ich bei Problemen zurück flashen kann.
bzw.mal ne Frage wenn ich im Recovery ein Backup mache wird dann auch von meinem Kernel ein Backup gemacht???
Dann könnte ich bei Problemen ja einfach mein Backup aufspielen.
Hi ich hab den Kernel jetzt ne Std drauf kann nix negatives sagen ausser das Voltage Control nicht geht.
Den Kernel flasht man doch einfach so drüber. Da muss man nix wipen oder so?
Steht zwar nix davon habe aber trotzdem nenn dalvid cache wipe gemacht sicher ist sicher.
funktioniert knock on mit dem kernel?
Ja funktioniert ganz normal wie mit dem stock kernel auch.
Reaktionen: mirko2812
V2 ist erschienen. OP angepasst.
Schon jemand getestet?
v2.0 nonOC installiert heute morgen 7uhr..das g2 läuft bis jetzt sehr rund und sparsam. bin überrascht wie gut das system und der simple kernel (bei benutzung ja immer mindestens 2 cores aktiv) zusammen harmonieren. danke an den dev der das sicher nicht lesen wird :)
Geht den jetzt Voltage Control?
V 3 erschienen:
Changelog
V3.0
All specifics found on my git
Add exfat support to all devices
Hotplug improvements
Governor improvements
CPU related changes/improvements to properly support new updates
Fixes:
Reverted a commit causing lag issues in v2
Possible fix for F320 sdcard (need confirmation)
A few modules had to come back
Re-enabled Westwood TCP (Removed module killed it)
Reaktionen: morpheus620
wie installiert man den Kernel?
Bei mir ist alles Stock ( 4.4.2 )
Grüße
Du brauchst wie bei 4.2.2 auch ein custom recovery um den Kernel zu flashen. Und jetzt bitte nicht verwundert fragen "wie gibt's recovery für kitkat". Das es das gibt, wenn auch über Umwege wurde ausgibig diskutiert und ist schon länger bekannt.
Einfach mal die Mühe machen und die Suche verwenden :thumbsup:
V3 läuft perfekt mit der pardus :)
Bitte thread Titel aktualisieren!
Frage möchte die non OC Version testen, ist es dabei erforderlich irgendeine Voltage App zu nutzen oder nicht ? Habe nicht vor OC zu betreiben, daher ja die non OC ;)
P.S. Frage hat sich erledigt habe die non OC jetzt mit Pardus Rom am laufen. App ist nicht erforderlich.
