[p920] KING_3D_ROM_V1.9
boostermbkking
10th version of the KING_3D_ROM by KING3Developers.
  • Based on v10j
  • Busybox + Root + Su
  • Full deodex apps & Framework
  • Original kernel
  • New framework
  • Optimized ram
  • Increased speed of microSD
  • Performance patch
  • Increased speed of system
  • Added more ringtones and notification sounds
  • Added ubuntu font
  • Added live wallaper
  • Added widgets dialers
  • Added KING-manager
  • Removed LG Apps
  • Android Market 3.1.5
  • Facebook 1.7.1
  • GoLauncher 2.58
  • KING-manager
Installation procedure:
make a backup of applications and data with wipe because you will delete 'all the contents of your phone
1) copy the files on the external sd
2) reboot into recovery (ClockworkMod 4.0.0.9)
3) make a backup nandroid (useful to restore your files and apps)
4) make the wipe 3 (Cache, date and Dalvik)
5) Flash zip from sdcard -> select the file
6) reboot system now
7 optional) reboot into recovery and go to backup and restore / advanced restore / YOUR BACKUP / Restore date (this puts all the files and apps as you had before flashing this rom but leaving unchanged the current Roma)
CAUTION DO NOT BELIEVE ME RESPONSIBLE FOR DAMAGE CAUSED TO YOUR ENDING TO THIS ROM
INSTALLATION REQUIRES A LONG TIME, EVEN 5 MINUTES, AND THE FIRST TO START is very slowly because recreate the cache, do not be alarmed, JAM IS NOT NOTHING
Rom screenshots
Download:
KING_3D_ROM_V1.9
Now I want to talk about the new program that you will find in the rom, free downloadable also from the market, is called King-manager, is an app created by lpirro (team member of the Rom as well as very good programmer), at my request, you can check with this rom changelog of the new ROM, you can download a new version of the rom if available via mobile phone and then flash from cwm, but most importantly, you can report bugs and ask for help the Roma to me directly via the function bug report and I will answer all very quickly trying to satisfy everyone who wants a mobile rom and my performance even though they are starting out with Android, in short, I will give you a better feeling with the Roma than all the others that for every problem you have access to the forum to report it But with this app wherever you are and for whatever reason, it is trivial, you can contact me to ask for clarification ...
THIS 'DO A GIFT THAT I WANTED TO ALL THOSE WHO TRUST IN ME Put DEVICE FOR THEM! ! !
I leave you now with the screenshots of this fantastic, functional and useful app:
PREVIEW:
SCREENSHOT
Reaktionen: Kyomo
Kann man mit dem King-manager das ROM updaten ohne vorher ein fullwipe auszuführen?
not today,but tomorrow you can do!
So you mean you are actually working on updating without wipe? That would be really awesome!! The 3D converter is missing, isn't it? Anyway sounds good, I'll flash tomorrow I think. Keep up the good work :thumbsup:
Internet geht bei mir nicht, mit V1.8 geht es.
was haste denn für APN settings?
Auf einem funktionierenden System ein Backup mit APN Manager machen und auf dem neuen ROM wiederherstellen in der App.
3D Konverter ist übrigens vorhanden, läuft extrem gut! Theme auch sehr schick :thumbup:
oder mittels google die richtigen einstellungen suchen und per hand einrichten :)
funzt super schnell..
aber ich will eeeendlich meinen 3d button als auslöseknopf zum fotos machen
wisst ihr vl. wie man diese Optus Kategorie entfernen kann?
MarcoJoo
MarcoJoo
  • Schimun
LGG3_32GB
LGG3_32GB
  • streetracer
Harry734
