Woschdi
Dauer-User
- 604
xda-developers - View Single Post - ★ ROMeOS3D ★ ICESLATED [02/04] [v1.3.4-FINAL] (-SENSE,+RTL,+BEATS,+BATT) [BUGS-FREE]
Sieht nicht mehr nur vielversprechend aus - monxs´ ICS Version ist nun auch zum Download verfügbar
Jetzt wird geasaugt und getestet
★ ROMeOS3D ★ ICESLATED [08/05] [v2.0.0] ICS403/SENSE36 [RC1] NO-SENSE - xda-developers
monx®;25807880 schrieb:ROMeOS3Dsimple • clean • stable
NO HTC-SENSE + SLATE THEME = UNSENSLATED
High Performance & Quality of HTC based ROM for EVO3D (ShooterU)
THIS ROM WILL RESTORE TO DEFAULT STATE AUTOMATICALLY JUST LIKE CLEAN WIPED FLASH AFTER DOING FACTORY RESET
Just use factory reset thru system settings to get clean state. No need to reflash rom.
monx®;25807908 schrieb:[v2.0.0] (08/05) RC 1
[+] Based on 3.08.401.1 ICS 4.0.3 Sense 3.6
[+] No Sense (Rosie Launcher) - GO Launcher EX as default launcher (pre-config)
[+] Heavy SLATE theme (will improve/fix/enhance frm time to time)
[+] Stock Android bootanimation (u can get ur own custom boot animation floating around this forum)
[+] Recent Apps disabled frm notification bar (u can always hold Home key for recent apps function)
[+] Sense 3.6 Lockscreen (lockscreens type are available via Personalize setting app)
---[>] Since no Rosie, so no shortcuts availabe!
---[>] Only Display & Sound tabs are functional in Personalize setting app
[+] Percentage battery bar
[+] Latest total-commander as default file manager (pre-config)
[+] Latest SuperSU
[+] Improved EXT4 performance + alignment
[+] more to come
[BUGs/ISSUEs-TRACKER]
[X] Data/signal drop
---[√] Flash ROMeOS3D-XCE_HTC-RIL from rom download folder.
monx®;25807924 schrieb:[PRE-REQUISITES]
[1] asS-OFF
[2] ROM package & copied to SDCARD
[3] New ICS Firmware
--[1] Get from HERE
--[2] Copy to SDCARD root folder
--[3] Reboot to bootloader
--[4] Flash the firmware
--[5a] Let it boot, use adb to reboot to recovery (adb reboot recovery) or use any known methods to boot directly to recovery
OR
--[5b] Let it boot, delete firmware /sdcard/PG86IMG.zip , reboot to bootloader > recovery
[4] Flash ROM
Monxs´ Download:
Zitat aus dem xda
"PLEASE DO NOT MIRROR TO OTHER SERVER. THANK YOU.
Please click XDA Thanks button is u like this rom.
Optionally rootbeer fund is HIGHLY APPRECIATED
======== DOWNLOAD ========
(1) Go to ROMeOS by monx® (create an account for free, wait for activation email, activate acc, LOGIN)
(2) Go to Download menu on top of the site
(3) Find desired ROM to download (ANDROID) then select your device name folder
(4) Make sure file size is correct as shown on rom description (if not same, means rom is corrupted or uploading)
(5) Proceed to download
(6) Check file(s) MD5 checksum & proceed to flash. *THANK YOU* DONATIONs are highly appreciated :' "
All credits go to Monx
Quelle Originalthread aus dem xda-developer Forum!
★ ROMeOS3D ★ ICESLATED II [08/05] [v2.0.0] ICS403/SENSE36 [RC1] NO-SENSE [READY] - xda-developers
Add Ons:
Statusbar im AOSP Stil: https://www.android-hilfe.de/forum/...rc1-no-sense-arrived.239816.html#post-3223012 oder http://forum.xda-developers.com/showpost.php?p=22754414&postcount=1
Beats Audio: http://forum.xda-developers.com/showpost.php?p=25803318&postcount=1
Call Drop Patch von monx: http://romeos.monx.biz/index.php?option=com_vfm&Itemid=92&dir=%2801%29+ANDROID|%2802%29+ROMeOS3D+SHOOTER_U|V-200+XCE+B-308+D-120508+PUBLIC
Erste Eindrücke meinerseits!
1.) Läuft alles fehlerfrei, wie es zu erwarten war und auch bei den anderen ROMs, die auf dem leak bsieren der Fall ist.
(WiFi, Datennetz, Telefonfunktion, Playstore, Spiele, fb, Cardock, GPS, Tethering) alles getestet
2.) Sehr flüssig mit Nova Launcher - den vorinstallierten GO habe ich nicht weiter beachtet
3.) Audioverbesserungen inkl. beats funktionieren [MOD]8/5/12 Beats Audio,Dolby Mobile,SRS,Equalizer+XLOUD(soon) sense3.6 CDMA UPDATED! - xda-developers Anleitung auf deutsch: https://www.android-hilfe.de/forum/...tc-sense-3-6.238636-page-16.html#post-3227967
4.) Sense Lockscreen hat keine Shortcuts mehr - klar, da ja kein Rosie vohanden ist
5.) Benchmarkwerte:
Antutu: 5413
Quadrant: 2779
6.) Batterie hat im GSM ohne Datennetz Modus 1 Prozent auf 7 Stunden verloren? Mehr kann ich noch nicht sagen
Ein paar ergänzende Screenshots noch:
Cheers
