morpheus620
Android-Guru
- 2.483
ROM soll alle Sprachen enthalten.
Und wie immer.
Ich weiß nicht ob Deep Sleep geht.
Bugs die ich jetzt raus lesen konnte:
- Keine 1080p Videoaufnahme mit Ton.
- Blaustich bei Bildern
Changelog:
Download:
XenonPower.V4.1_U9200_Lzsmt.zip
Und wie immer.
Changelog:
Main function of the work:
- Call
- SMS
- Internet
- WIFI
- Bluetooth, may not be able to connect with CM10.1]
- GPS
- Photography
- Gravity sensing
- Four kings vibration
- Sensors
- SD card reader
- USB connection (using MTP connection)
Not work (see instructions):
- Camera 1080P, [still no sound]
- Music third-party player perfect player, video untested
If you found a bug, please microblogging private letter to inform.
- About Home monarch can not long press bring up task manager, you can open the PIE shortcut gestures [Settings / Advanced / PIE quick gesture] as my screenshot that there
Because I do not have a machine to others tested. Concluded high boot animation resolution display incomplete. . The Four Diamond does not vibrate with cm10.1. . Bluetooth able to open but does not work same cm10.1. . wifi hotspot does not to work with cm10.1. . Photography without sound with cm10.1. . . Photographed bluish. . Telephone, text messaging, Internet, wifi, gravity sensor, sd reads usb. Third-party music video. Normal to thank microblogging oil hl99
Blue camera interface is no effect, select the set / color effects /]
Default is 1.5G frequency, you can set - performance - the processor to adjust the CPU frequency lower, and thus play a certain power-saving effect, it is recommended that the regulator to modify the CPU for the Ondemand check startup settings ".
Bug to the author did not mention that part of the preliminary tests were normal, timely feedback Sina microblogging @ sexy green peppers
- Call
- SMS
- Internet
- WIFI
- GPS
- Photography
- Gravity sensing
- Sensors
- SD card reader
Download:
