dumbo1
Stamm-User
- 422
!!!Weder ich noch Android-Hilfe übernehmen eine Haftung sollte durch das flaschen dieser Rom euer S7 edge defekt werden!!!
Im voraus Vielen, vielen Dank an asc1977
[ROM] MinotaurusEatsNougat V7 [PL3][7.0][22.12.16]
-Deodexed
-Knox removed
-Debloated
-Root Supersu ( thx @lyapota )
-SD Card permissions FIX
-Userdata encryption disabled
-Based on beta4 G935F ( thx @geiti94 )
-Newest Modem and Bootloader comes with rom (thx @geiti94 )
-Build.prop tweaks for speed, battery and more
-RebootRecovery in powermenu
-Removed confirm button from power off and restart, so only press one time without confirm it
-Option to switch on/off usb plugin wakeup
-DPI changer in RomControl app (SourceCode here)
-Option to show/hide emergency button in reboot menu ( thx @tdunham )
-BetterBatteryStats app
-Free Root Explorer on rom ( thx @sanoc69 )
-Unlock after reboot with fingerprint possible without using pin or pattern ( thx @sanoc69 )
-Multi-User support
-Network traffic indicator in statusbar with settings in RomControl ( thx @daxgirl )
-Support for grey on white apps for networktraffic ( thx @Silassi1 )
-Disable SMS to MMS converting
-Shutter Sound option in camera settings
-Call Recording Button
-Auto Data connect to send and recieve MMS without Toogle Data
-Enable Black list in Stock Message settings
-Support Recent App Protection
-Data usage in expanded SystemUI near brightness auto check
-SMS to MMS convert
-Matrix effect in recent panel ( thx @thereassaad )
-0,25 animation scale in developer options (only english and german)
-Viper4A and DolbyAudio to Rom with settings in RomControl
-Clock with more options like size, allignment, font and more on Statusbar with settings in RomControl
-Knox removed
-Debloated
-Multi-User support
-SMS to MMS convert
-Added tap on clock to launch activity with settings in RomControl ( thx @kep2008 @stangdriver44 )
-PrivateMode fixed
-Fingerprint Setup fixed
-Added option for DataUsage in Quickpanel with settings in RomControl app
-Added Carrier label text with custom text and color in notification panel with RomControl settings
-Added option to remove PowerOff button on Reboot menue with RomControl settings
-Added BatteryBar on statusbar with settings in RomControl ( thx @stangdriver44 )
-Updated SuperSU to 2.79
-Fixed Bluetooth bug
-Added 3MinitBattery
-Added switch for show/hide stock battery
-Added switch for show/hide 3Minit battery
Donators Changelog V6
-Added virtual Buttons for lock,recent and home with all three allignments to RomControl Changelog V7
-Fixed SHealth app
-Added Whitepages /identify unsaved numbers
-Added 1060 fonts to stock fonts settings ( thx @Winb33 )
-Added fixed SBrowser with secure mode fully working
-Added expanded Volume Panel
-Added Quicklauncher to recents with switch in RomControl
-Removed High Volume warning
Donators Changelog V7
-Added expanded statusbar colors with RomControl app settings
-Added colorize Volume Panel with options in RomControl
-PrivateMode fixed
-Fixed SHealth app
1. Odin hier Downloaden
2. Die neusten Bootloader und Modem werden mit installiert
3. Rom hier Downloaden und auf sd-Karte kopieren, BEVOR ihr Twrp aufspielt die Entwickleroption frei schalten und die OEM-Entsperrung + USB Debugging anschalten.
4. TWRP hier ziehen und über Odin flashen, wenn neu startet sofort Lautstärke+/Home/Powertaste gedrückt halten. Wenn zu spät einfach Lautstärke -/Powertaste getrückt halten, startet neu
5. Im TWRP erst formatieren und dann wipe, delvik cache
6. Das Verzeichnis auswählen wo die Rom liegt und starten
7. die Installation dauert ca. 5 - 8 min und startet neu
8. Spaß haben
9. Natürlich bei asc1977 bedanken
8. Spaß haben
Das sind die kleinen Dinge die man einfach braucht (Freie Version)
MinotaurusEatsNougat Free Playstore apk
Wenn ihr die Pro-Version kauft, helft Ihr den Entwickler dieser Rom sehr
-Colorize for all statusbar icons with grey tint on white apps
-InCall Ui Button Background
-Virtual Buttons for lock,recent and home with all three allignments to RomControl
MinotaurusEatsNougat Pro Playstore apk
HIER noch Link zu xda
