Von Usern nicht gewartete, veraltete und bereits eingestellte Roms
Soeben wurde der Tread geupdatet...
Anleitung zum Installieren des 2.2 Rom ist nun da...
Downloadlink noch nicht verfügbar.
MfG
zdzihu schrieb:
Froyo 2.2.1 AOSP ROM
Video:
Description:
Xperia X10 Froyo 2.2.1 rom is a fresh and clean build of latest AOSP, without any custom modifications. The first release (alpha build) is not fully suitable as main operating system, but still pretty ok for most of the tasks. The alpha build is compiled with engineering and debug flags, so please don't expect it to be fast or stable. It definitely will lag and crash every now and then. The main reason of releasing it is to gather as much end-user feedback as we can. Most of the issues are already addressed and being worked on (as described below), so I'm expecting BETA version to come in several days.
The BETA version will be flashable into your X10's flash memory and ready to be used as main (and only) system. For now, I feel like dual booting is the way to go (and hope you like the idea).
New features:
DUAL BOOT
Press any key during the boot process (right after "Sony Ericsson" text logo) to boot into 2.1 ROM. Otherwise it will boot into 2.2 Custom Rom.
There is a plan to prepare boot menu, this would allow us to multiboot (number of ROMs only limited by SD Card capacity:))
Known problems:
- no Audio playback (voice calls work)
- no native Video playback (RockPlayer works)
- camera - not implemented yet
- random reboots (identified - WIP)
- random lags (identified - WIP)
- slight radio issue - voice calls - sometimes (1 out of 25-30 for me) both you and the other person sound like a chipmunk :D (identified - WIP)
Requirements:
- 1GB of free space on SD Card
- phone needs to be rooted with busybox installed
Installation:
1. Download the rom package
2. Unpack it to the root (main folder) of your SD Card
3. Connect your phone in USB Debugging mode
4. Open ADB shell, switch to root user (SU)
5. Issue the command:
Code:
dd if=/sdcard/install of=/data/install && chmod 777 /data/install && ./data/install
6. Reboot when installation is finished
7. Enjoy
Download link:
TBA
Wenn der link da ist dann zieh ich mir es gleich mal drauf
Also beim booten kann ich dann eingeben welche Rom geladen werden soll?
zdzihu schrieb:
New features:
DUAL BOOT
Also aktuell muss man eine Taste drücken um das 2.1 zu booten. Drückt man nichts, bootet das 2.2
MfG
UKSheep
Download wird erst nächste Woche verfügbar sein. Da heute ein paar Probleme entdeckt wurden die er erst fixen will.
MfG
UKSheep
Kann vielleicht einer mal das ganze in Deutsch übersetzen wie man es genau installiert? Wäre echt super von euch.
Beschreibung:
Xperia X10 Froyo 2.2.1 rom ist eine frische und saubere bauen neuester AOSP ohne kundenspezifische Modifikationen. Die erste Veröffentlichung (Alpha Build) ist nicht vollständig geeignet als Haupt-Betriebssystem, aber immer noch recht für die meisten Aufgaben in Ordnung. Die Alpha-Build mit Engineering-und Debug-Flags kompiliert, also bitte nicht erwarten, dass es schnell oder stabil. Es wird definitiv Verzögerung und Crash hin und wieder. Der Hauptgrund für die Freigabe ist es um so viel End-Nutzer-Feedback zu sammeln, wie wir können. Die meisten Probleme sind schon angesprochen und gearbeitet (wie unten beschrieben), so erwarte ich BETA-Version in einigen Tagen kommen.
Die BETA-Version wird flashable in Ihre X10 Flash-Speicher und bereit, als Haupt-(und einzige) System verwendet werden. Denn jetzt, fühlen Ich mag Dual-Boot der Weg zu gehen (und hoffen, Ihnen gefällt die Idee) ist.
Neue Features:
Dual-Boot
Drücken Sie eine beliebige Taste während des Bootvorgangs (direkt nach "Sony Ericsson" Text-Logo) zu booten 2,1 ROM. Sonst wird es booten 2.2 Benutzerdefinierte Rom.
Es gibt einen Plan, um Boot-Menü vorzubereiten, würde dies erlauben uns, Multiboot (Anzahl der ROMs nur von SD-Karte Kapazitäten begrenzt)
Bekannte Probleme:
- Keine Audio-Wiedergabe (Anrufe Arbeit)
- Keine native Video-Wiedergabe (RockPlayer Werke)
- Kamera - noch nicht implementiert
- Zufällige Neustarts (identifiziert - WIP)
- Zufällige Verzögerungen (identifiziert - WIP)
- Leichte Radio Problem - Anrufe - manchmal (1 von 25-30 für mich) Sie und die andere Person klingen wie ein Eichhörnchen (Identifiziert - WIP)
Anforderungen:
- 1 GB freier Speicherplatz auf der SD-Karte
- Handy muss mit busybox installiert verwurzelt sein
Installation:
1. Laden Sie die ROM-Paket
2. Packen Sie es an die Wurzel (Hauptordner) Ihrer SD-Karte
3. Verbinden Sie Ihr Handy im USB-Debugging-Modus
4. Open ADB Shell, wechseln Sie zu root (SU)
5. Geben Sie den Befehl:
Code:
dd if = / SDCard / der install = / data / install & & chmod 777 / data / install & &. / data / installieren
6. Starten Sie, wenn Installation abgeschlossen ist
7. Genießen
so muss es dann in deutsch sein
probier mal google chrome der übersetzt automatisch:smile:
Reaktionen: lounge77 und beauceron
Installation: Punkt 1 und 2 verstehe ich, ist ja nicht sonderlich schwer. :) Ab Punkt 3 - 5 wäre mal eine Hilfestellung nötig.
Anleitung für Eclipse und Android SDK
lies dir da mal durch
adb treiber vom handy müssen auch richtig installiert sein
klick auf start
geh auf ausführen
es öffnet sich ein terminal
gib den befehl cmd ein
und da gibst du dann den ensprechenden befehl ein
ich habe es auch erst nach ein paar anläufen gerafft
Hab jetzt mal ne blöde Frage, wie ist es möglich eine Customfirmware aufzuspielen wenn der Bootloader nicht geknackt ist? Oder haben Sie es jetzt Gott sei Dank geschafft?
Sollte er geknackt sein, gibts auch schon Customloader mit Nandroid etc?
LG
Nein, der Loader ist noch nicht geknackt... Sie haben eine andere möglichkeit gefunden.
So kann man aber wohl nur den "alten" Kernel benutzen... und diesen nicht anpassen...
Zum Thema CMD...
man geht auf Start Ausführen... gibt dort cmd ein... und dann öffnet sich ein Terminal... :)
Bei Win7 auf das Win7 Logo unten Links :) ganz unten auf Programme/Dateien durchsuchen... dort gibt man cmd ein... und es öffnet sich ein Terminal (Schwarzes fenster... kennt man in der Regel zB aus der guten alten DOS Zeit)
MfG
UKSheep
NEWS
"Lange mussten die Besitzer eines Xperia X10 warten, bis Sony Ericsson ihnen das Update auf Android 2.1 zur Verfügung stellte. Nun können sie sogar Android 2.2 installieren - allerdings nur eine inoffizielle Hacker-Version. Ein Entwickler im Forum der Website xda-developers.com hat die Originalversion von Google auf das X10 portiert. Noch ist Froyo allerdings in einem Stadium, das selbst der Hacker als Pre-Alpha bezeichnet. Es ist weder voll funktionsfähig, noch stabil. Er hat die Software deshalb auch nur als Dual-Boot-Lösung veröffentlicht. Während des Startprozesses kann man sich für das Betriebssystem von Sony Ericsson oder die Google-Variante entscheiden.
Nach Angaben des Hackers lassen sich die grundlegendsten Hardware-Funktionen schon ansteuern, etwa Display, GSM und UMTS, GPS und Wlan, Kamera, Lagesensor, Energie-Management und Bluetooth. Anrufe selbst durchzuführen, ist dagegen gar nicht möglich, Videos werden nur über Zusatzsoftware abgespielt. Darüber hinaus sind die Codecs durcheinander geraten. Eine Installation wird nur erfahrenen Nutzern empfohlen."
Quelle: areambole (Bald verfügbar: Hacker zeigt Android 2.2 auf Xperia X10)
Interessant , halt uns bitte auf dem Laufenden ;)!
Also leider noch kein Nandroid, aber wie ist es dann möglich auf Basis des alten Kernels 2.2 zu flashen? Stehen die nicht in einer Abhängigkeit zueinander?
Gibt es eigentlich eine Möglichkeit den Just in Time Compiler (JIT) auch unter 2.1 zum laufen zu bringen, und würde sich das auch was bringen?
LG
Zum thema JIT guck mal diesen Thread.
Bringt definitiv was...bei mir laut Quadrant vorher 598 jetzt 731!
Glaub das Flashen hat nicht unmittelbar ws mit dem Kernel zu tun.
Soweit mein Wissen reicht sind im Kernel ja nur die Grundfunktionen 'verbaut' (berichtigt mich wenn ich Blödsin rede ;)). Du kannst dir bspw. unter Linux deinen Kernel so zusammenbasteln wie du willst und nur die Sachen reinpacken die du brauchst, was nen riesen Vorteil für die Geschwindigkeit des Systems ist wenn du nicht irgendwelchen Scheiss mit durchziehst den du eh nicht brauchst.
Wenn jemand in die Root/Hacking Rubrik gucken würde da stehen schon unmengen zu dem ROM.
[OFFURL]https://www.android-hilfe.de/root-hacking-modding-fuer-sony-ericsson-xperia-x10/55030-neues-vom-inoffiziellen-update-auf-2-2-a.html[/OFFURL]
LG
[YT]http://www.youtube.com/watch?v=eEZQjKLOhUk&feature=player_embedded#![/YT]​
Die NEWS sind keine NEWS :) und es ist auch noch nicht veröffentlicht...
Da der "hacker" dieses in seinem Beitrag geschrieben hat...
Download link:
Today I have found very annoying issue that I need to patch before releasing the ROM.
Download links will be available next week.
also müssen wir noch ein Paar Tage warten...
und zum Thema Kernel...
über den Kernel kann man ziemlich viel am Gerät anpassen... zB wäre so evtl. eine MT unterstützung möglich... und auch viele andere Sachen...
Soweit ich das verstanden habe ist das aber nur möglich wenn der Bootloader geknackt ist... vorher müssen sie wohl den alten Kernel verwenden...
Als ROM nutzen sie ein ROM was natürlich für ein anderes Gerät gedacht war... da SE ja noch kein 2.2 für das X10 anbietet... also müssen sie in dem ROM allerhand anpassen usw... was extreme viel Arbeit ist und weswegen es aktuell auch noch so viele Bugs gibt.
Ich denke aber je mehr die Leute daran Arbeiten... umso schneller werden sie in den Umsetzungen...
MfG
UKSheep
Soweit so klar und das Wissen wurde wieder berreichert, aber frage mich trotzdem wie ich ein Dualbootsystem verwenden kann ohne das der Bootloader geknackt wurde...
LG
hier nochmal den kompletten Beitrag zum 2.2.1
This is an alpha build for testing purpose
It's not ready for daily use!
Video:
Description:
New features:
DUAL BOOT
Known problems:
Requirements:
Installation:
1. Download the rom package (FreeX10_alpha-release_0.0.1.tar.bz2)
Code:
7. Enjoy
Notes:
- the build comes pre-rooted and with busybox installed, there's no need to do it again.
- DON'T use the "factory reset" option in custom rom. It's hardcoded to wipe nand "data" partition!
- when message pops up "Force Close / Wait", select wait... it will eventually finish the task.
- this build IS very early alpha, bear in mind it will crash and lag. If you don't like it, try 2.1 AOSP build instead.
- first run may take up to 5 minutes, this is directly related to the lagging issue.
- remember you won't hear any ringtone, enabling "Vibrate:always" is good idea.
- be patient :) it gets much faster and less laggy over time, when everything is cached
Download link:
23/11/2010 FreeX10_alpha-release_0.0.1
Hier dann nochmal eine Erklärung zum installieren...
rabetionline schrieb:
1- copy to file "freex10.zip and install" in sdcard (in the root of sd card)
2- install terminal emulator in 2.1 se rom from market
3- remove phone cable after copying 2 above file on sd
4- run terminal emulator
5-type su and ENTER
6-$ will become # on the screen
7-type this code:
8-ENTER and wait to install
Nun meine Übersetzung...
1. Entpackt die Runtergeladene Datei entweder auf eurem PC und verschiebt dann die beiden Dateien "freex10.zip und install" auf eure SD Karte vom X10 (root Verzeichnis - also nicht sdcard/2.2 oder so sondern direkt auf die SD Karte) oder ihr entpackt die runtergeladene Datei direkt auf eure SD Karte vom Handy... somit sind danach auch die beiden Dateien "freex10.zip und install" drauf.
2. Nachdem ihr die beiden Dateien auf die SD Karte übertragen habt entfernt ihr das USB Kabel. Damit euer X10 wieder auf die Daten zugreifen kann... nun öffnet ihr den Market und Ladet euch einen Terminal Emulator runter.
3. Nun startet ihr den Terminal Emulator.
4. Gebst su ein und drückt Enter
5. Aus $ wird #
6. Dann gebt ihr diesen Code ein:
7. bestätigt mit Enter und wartet bis die installation abgeschlossen ist.
Da es sich um ein CustomRom handelt sollte man die ganze Sache mit Vorsicht behandeln... wenn ihr nicht genau wisst was ihr machen müsst... dann lasst es lieber... nicht das ihr euch danach nen neues X10 kaufen müsst ;)
MfG
UKSheep
Reaktionen: tim2202
meetdaleet
  • Gesperrt
  • Angepinnt
  • meetdaleet
meetdaleet
meetdaleet
Ecart
Ecart
Ecart
Mikemr
