[ROM] Erachter ROM
  • 18 Antworten
Scum
Scum
Moderator
Teammitglied
11.835
I proudly present to you:
My first custom ROM
Features:
Quote:
Based on stock Sony 6.1.A.2.45 FW
Deleted Sony garbage
Very smooth (extremely fast from V2)
New statusbar icons
Great battery life
Changelog:
Quote:
V5
1.Many Xperia T apps
2.unlimited boost script(increased performance )
3.Modded Xperia T Home.apk
4.Battery tweaks
5.Network tweaks
6.Music tweaks (files from AC!D Audio Technology)
7.More transparent app drawer
Quote:
V4.1
Bugfix release!
1.Fixed music bugs (now there is only dsp manager).
2.Fixed contacts bug.(infiniteview)
3.Added Google Now.(you can disable it in it's settings)
Quote:
V4
1.added email app
2.added exchange account
3.changed statusbar toggles
4.added picasa
5.added geeky tweaks(alot increased smoothnes)
6.music tweaks (added Beats DSP Manger and deleted sound enchancements.apk)
Quote:
V3
1.fixed statusbar battery issue
2.moved to Xperia GX launcher
3.changed Xperia GX launcher
4.updated build.prop
4.(possible)fixed bad data connection(for those who had it)
5.changed Camera UI more
6.added statusbar toggles ^_^
Quote:
V2
1.A ton of performance tweaks (much more than v1)
2.New black theme (there isn't more purple them
3.New red theme (no pink theme
4.A bit modified Camera UI (more coming soon)
5.fixed music bug
6.New bootanimation (very cool).
Quote:
v1
1.Performance tweaks
2.Statusbar icons
3.ICS Bootanimation
4."No data traffic" notification removed
5.New App Drawer icon
6.Battery Life tweaks (great improved)
7.Scrolling tweak (really better than stock)
Quote:
BUGS:
1.Theme Manager bug(if someone know how to fix it PM me)
Downloads:
V5:
Dev-host: Dev-Host - Erachter ROM v5.zip - The Ultimate Free File Hosting / File Sharing Service
Depositfiles: DepositFiles
V4.1:
Dev-host: Dev-Host - Erachter ROM v4.1.zip - The Ultimate Free File Hosting / File Sharing Service
Deposit-files: DepositFiles
V3:
Dev-host: Dev-Host - Erachter ROM v3.zip - The Ultimate Free File Hosting / File Sharing Service
Screenshots:
RED THEME
BLACK THEME
Instalation instructions:
1.Download ROM
2.Put on SD card
3.Flash binary recovery
4.Mounts and storage--->format system
5.Wipe data
6.Wipe Dalvik Cache
7.Install ROM
8.Flash a kernel (i recommend XSX kernel v6)
9.Rebot.
If you want to save your data on your phone follow these steps:
Note:
1.CMW nandroid backups don't work in TWRP(XSX Kernel)
2.This won't work if you come from CM10, AOKP, CM9 and other non-stock base ROMs
1.Download ROM
2.Put on SD card
4.Make a nandroid backup
5.Mounts and storage--->format system
6.Wipe data
7.Wipe Dalvik Cache
8.Install ROM
9.Flash a kernel.
10.Reboot.
11.Go in recovery and do this: Restore-->Advanced restore-->restore data
12.Reboot and enjoy!
Ich werde es mal ausprobieren :)
Du kannst dann ja mal berichten ;)
Gesendet von meinem Xperia S mit Tapatalk 2
Das mache ich...
Mal schauen ob das mit CWM zu installieren ist.. " eigentlich schon " :)
Mache nur eben fix eine Sicherung.
Hatte schon die Version 2 drauf werde aber die neue ausprobieren und dann berichten! :blink:
Wie meine Fragestellung schon vorher...warum das Xperia T Rom nicht auf dem Xperia S geht ??
Der ursprüngliche Beitrag von 18:54 Uhr wurde um 18:55 Uhr ergänzt:
War nicht so gut ???
Doch war ok nur dann kam DualCore 5.2 und da bin ich hegen geblieben ... :blink:
DualCore 5.2 ist was ?
Eine Rom ^^
Ein paar Schreenshots ...
kann man das Rom auch bei einem locked Bootloader drüber werfen ?
dann würde ichs probieren ;-)
Kann ich dir nicht sagen da ich mich solcher "Hürden" gleich entledige :tongue:
Ach hätte ich die Möglichkeit wäre die Hürde schon lang entfernt :p ...na dann auf gut Glück
"not allowed" :-(
Der ursprüngliche Beitrag von 14:42 Uhr wurde um 15:00 Uhr ergänzt:
BTW :läuft -> jetzt mal anschauen
Halben Tag mit dem Rom hinter mir , läuft soweit ganz gut ...Akku kommt mir gefühlt etwas besser vor als unter DualCore vor , hin und wieder hab ich aber ein paar Hänger drin .
Lass es auf jeden Fall noch oben und schau wie es sich im Alltag so schlägt
Habe sie jetzt auch drauf, werde später mal berichten ;)
Gesendet von meinem LT26i mit Tapatalk 2
Ich habe es jetzt seit gestern abend drauf.
Absolut vergleichbar zum DualCore. Es ist ein sehr gutes ROM, läuft geschmeidig und recht Akku-schonend. Dazu hatte es bisher keinen Aussetzer wie das DC.
Wenn jetzt nicht noch größere Bugs auftauchen, ist das ROM mein derzeitiger Favorit. Kernel ist SSpeed V6.
