Lineage OS 15 aka Oreo Alpha erschienen
  • 4 Antworten
GaborDenes
Stamm-User
70
Hier der XDA-Link:
Grundfunktionen und mehr sind schon da
Hier der Status eines Users:
I've been using the last build for 2 hours and I can say it's completely different from the first one I tried. It's far more stable. I just faced a laggy system on first boot, but it was gone once I rebooted. The system is smoothly and stable.
Every single app is working perfectly, but camera (known problem)
GPS is very fast (got my location in 5 seconds)
Audio is good.
Hdla earphones works.
Quick charge works.
Fingerprint works like a charm
I attached a Bluetooth logcat. I hope it helps you. I'll keep using this build once there is no big problem for me (I don't use Bluetooth or camera frequently, so it's ok).
I just wanna say one more time big thanks for your awesome work."
Ich hoffe, der englische Text ist ok...
Uppdate von gestern:
Originally Posted by andr68rus
CHANGELOG:
09 Sep
* First build
10 Sep
* Sound fixed
* Wifi fixed
12 Sep
* Gapps/Playmarket fixed
* Display/Media/Audio used QCOM CAF HALs
* Adreno blobs revert to N-variant
13 Sep
* BT fixed
BUGS:
* Camera does not work
ToDo:
Working on camera now
Dadurch, dass diese Builds nicht mehr geupdatet wird, würde ich jedem abraten, sich das draufzuflashen.
