[Firmware][10.0] OxygenOS 10.0.16 | für 7T
TomTim
TomTim
Ehrenmitglied
6.425
System
  • Updated Android Security Patch to 2021.01
  • Updated GMS package to 2020.09
Reaktionen: Timmih und hellmichel
OnePlus 7T Updateverlauf
System
  • OnePlus Bullets Wireless Z can now be integrated with Dolby Atmos for better sound quality
  • Optimized the volume adjustment to improve user experience
  • Improved system stability and fixed general issues
  • Updated Android Security Patch to 2020.05
Camera
  • Supported the slow-motion recording at 720p at 960fps
  • Adding lens stain detection
Phone
  • Newly added Epic Games in Game Space(India only)
System
  • Optimized the Ram management
  • Improved system stability and fixed known issues
  • Updated Android Security Patch to 2020. 03
Gallery
  • Improved stability for recording videos in slow-mo
  • Fixed the random disappearance of screenshots in Gallery
  • Synched video playback speed with audio
System
  • Optimized the RAM management
  • Improved black/blank screen issues with some apps
  • Added the feature to support reminders for privacy alerts
  • Improved system stability and fixed general bugs
  • Updated Android security patch to 2020.01
System
  • Improved the launching speed of some apps
  • Optimized the RAM Management
  • Optimized the black and white screen issues with some apps
  • Improved system stability and general bug fixes
  • Updated Android security patch to 2019.11
Camera
  • Improved the photo quality
System
  • Optimized standby power consumption
  • Optimized the Bluetooth connectivity in automobiles
  • Optimized the expanded screenshot feature
System
  • Fixed the double-tap gesture for screen activation
  • Updated Android security patch to 2019.10
  • Improved system stability and General bug fixes
System
  • Optimized translation accuracy
  • Optimisedoverall communication (network, phone calls, mobile data) performance
  • General bug fixes and improvements
  • Added Cloud Service for Gallery (India only)
Camera
  • Optimised quality of the front camera for better pictures at night
System
Camera
  • Improved photo quality
  • Enhanced stability of Camera
  • User experience improvements
Reaktionen: Launebub, mj084, EdgA und eine weitere Person
Neuestes Update: OxygenOS 10.0.4
@TomTim Mir wird kein neues Update angeboten.
Die Updates werden partiell beziehungsweise in Intervallen verteilt, bis Weltweit alle Regionen erreicht sind kann es auch Tage dauern.
Nun habe ich auch das neue Update erhalten.
Ist noch jemand unter euch der es auch schon hat?
Hier auch angekommen.
Fix installiert, nix negatives bemerkt.
Bilde mir ein, dass die Zurück-Gesten rechts und links besser funktionieren. Ganz angefreundet hab ich mich damit aber immer noch nicht mit der Gesten Navigation.
Dito.
Wann kommen den bei OnePlus die Sicherheits Updates immer?
Wenn alles optimal läuft, dann mit dem monatlichen Update.
Verstehe ich das richtig das es monatliche Updates gibt mit verschiedenen Verbesserungen plus das Sicherheits Update?
Die OnePlus interne Richtlinie die angestrebt wird, ist folgende:
Closed Beta = 4x pro Monat
Open Beta = 2x pro Monat
Official Release = 1x 1-2 Monate
Reaktionen: freeztyler, TimeTurn, dadri und 3 andere
TomTim schrieb:
Das war aber glaube nur bei den aktuellsten Modellen so oder?
Also Aktuell 7(t)er Reihe.. je älter desto größer werden die Abstände leider, musste ich bei meinem 5T feststellen.
Reaktionen: dadri
Immerhin hat das alte 6T meiner Frau vorgestern auch Android 10 bekommen (offiziell, keine Beta). Ging dann ja doch relativ zügig. Heute kommt ihr neues 7T an.
Habe ihr die neue Gestensteuerung eingestellt, mit der ich auf meinem 7 Pro schon eine Weile rumspiele - sie kann die aber gar nicht leiden :)
Wo kann man die Update Dateien runter laden um manuell zu installieren?
Gibt es keine direkten Links?
Gibt wohl keine Links.
Update noch nicht da auch nicht über den Oxygen Updater.
Scheinen nicht die schnellsten zu sein.
Beim 6 und 6T gab es Probleme beim Update.
Vielleicht darum erstmal gestoppt.
RadHeiner
RadHeiner
RadHeiner
Boostar
Mannimb
RadHeiner
RadHeiner
