Cris
Moderator
Teammitglied
The conversation in our forum is in German. For questions and answers in English,
please add a translation to German. Prompt or Google Translator are sufficient.
[Custom Rom] Huawei Mate S.-CRR-L09-PHOENIX-B789-
EMUI 4.1.3 - Android 6.1 - (TWRP 3 backup file)
Because it becomes with EMUI 5 nothing, here I have a custom firmware. Constructed on the
C432, C900, C00, B370, B380, B390. An advancement of the V4.
The following Mods are integrated and activated:
Application Manager and Atitivir
in the phone manager
Application Drawer
Call recorder
Dolby Atmos
Dolby Cinema
HiLink
K-Settings
No-frills CPU Controll
Online number recognition
Perfect Color bar
Viper4 Android FX
Xposed
This Rom is developed and tested on this device:
Model Huawei Mate S CRR-L09
Build number CRR-L09C432B390
System version CRR-L09C900B390
free device - Root -
TWRP Recovery 3.0.2
It is so installed, as if you restored a TWRP backup.
TWRP-Recovery 3.0.2 (carrera3.img) is necessary,
OEM+FRP unlocked. The base firmware version makes no difference.
With provider Branding was able I do not test it.
Before the Rom installation, a TWRP 3.0.2 put on backup for emergencies!!
The download folder contains 22 compressed files. Please
not as a ZIP archive download.
With extracting of the first file extract to itself the others then automatically.
There generate the TWRP backup folder:
"2017-05-18 - CRR-L09-PHOENIX-B789".
You copy this into the backup path TWRP on the external Sd.
Installation:
In TWRP restore the backup and reboot.
All your settings and applications are away of course;
but you have a Huawei data Backup.
If serious mistakes appear after the installation,
if repeats the Restoring with this previous Wipe before.
If superuser TWRP liked to instal, declines of this please.
Now the Rom installation is complete.
An additional installation of SuperSu and
BusyBox is not necessary any more. Both is integrated
and configures. It pass
read and full writing rights.
The ROM is not debloated, however, something
deodexed and zipaligned.
- In Xposed I have only Perfect Color bar actively.
- The icon for the application Drawer is below in
the middle of the Homescreen.
- The Call recorder is activated.
- No-frills Having I on Powersaving preset.
- I have reduced the Icon size from 175 to 120
and the Homescreensetting on 8x8.
- The download of HWThemes probably does not go.
Please, regularly backups, there
Google sometimes creates problems with Custom Roms. ,
With the installer in the application of managers you can fix many things.
...... And also remembers: a Custom ROM is
never so perfectly, as a stock Rom. To him one has to go
always teach something itself suitably.
It can not hurt to deal with minor problems,
Between a little wiping Close. (Cache + Dalvik)
Forget the FACTORY RESET in the future.
This will make Googledebloating in the future.
This means that afterwards also no Google registration and no keyboard more
is available. If for any reason you get into the situation, make a TWRP Restoring only the system
of my BACKUP-ROM run.
Then everything is all right. All your apps remain with settings.
There is also this "emergency brake":
A completely broken system can also save.
Simply update with the current UPDATE.ZIP of the B390
And all is well again.
Have fun !
Many thanks to: KangVip, Chainfire, Stephen (Stericson) + Jmz Software, rovo, and
Huawei Technologies Co., Ltd 华为技术有限公司
Disclaimer:
In spite of careful elaboration I cannot guarantee, that by the realisation this
Instructions no damages to device or operating system originate and, hence, takes over
no liability for appearing damages and malfunctionings in hardware and software!
Should you be still unsafe, obeys these steps:
The instructions carry out only, if perhaps called conditions
(Model number, Android version etc.) apply to you or your device.
Instructions read carefully and completely, unknown concepts look up.
Downloaded files for viruses check. A backup more importantly Settings and data make.
The instructions do not carry out if you do not know what you do.
Though the perhaps relock of the Bootloaders is possible, however, becomes in Fastboot-and
Rescue fashion indicated. Such actions lead to expire to the manufacturer warranty and the.
Application Drawer
Call recorder
Dolby Atmos
Dolby Cinema
HiLink
K-Settings
Perfect Color bar
Viper4 Android FX
Xposed
TWRP Recovery 3.0.2
Installation:
Have fun !
Disclaimer:
[Custom Rom] Huawei Mate S -CRR-L09-PHOENIX-B789-
EMUI 4.1.3 - Android 6.1 - (TWRP 3 Backup-File)
Da es mit EMUI 5 nichts wird, habe ich hier eine angepasste
Firmware erstellt. Aufgebaut auf die C432, C900, C00,
B370, B380, B390. Eine Weiterentwicklung der V4.
Folgende Mods sind integriert und aktiviert:
App Manager und Atitivir
im Telefonmanager
App Drawer
Call Recorder
Dolby Atmos
Dolby Cinema
HiLink
K-Settings
Online-Nummernerkennung
Perfect Color Bar
Viper4 Android FX
Xposed
Die Firmware wurde Entwickelt und getestet auf diesem Gerät:
Modell Huawei Mate S CRR-L09
Build-Nummer CRR-L09C432B390
Systemversion CRR-L09C900B390
freies Gerät - Root -
TWRP Recovery 3.0.2
Es wird so installiert, als ob Ihr ein Backup einspielen wolltet.
Erforderlich ist lediglich TWRP-Recovery 3.0.2 (carrera3.img),
OEM+FRP unlocked. Die Firmwareversion ist egal. Mit Provider Branding konnte
ich es nicht testen.
Vor der Rom-Installation, ein TWRP 3.0.2 Backup für Notfälle anlegen !!
Der Downloadordner beinhaltet 22 komprimierte Dateien. Bitte
nicht als ZIP-Archiv downloaden.
Beim entpacken der ersten Datei entpacken sich die anderen dann automatisch.
Es entsteht der TWRP-Backupordner:
"2017-05-18--CRR-L09-PHOENIX-B789".
Diesen kopiert Ihr in den TWRP-Backuppfad auf die externe Sd-Karte.
Installation:
In TWRP das Backup wiederherstellen und rebooten.
Alle Eure Einstellungen und Apps sind natürlich weg;
aber Ihr habt ja alles in Euerer frischen Datensicherung.
Treten nach der Installation gravierende Fehler auf,
wiederholt das Restoring mit diesem vorherigen Wipe.
Wenn TWRP Superuser installieren möchte, lehnt dieses bitte ab.
Die Rom-Installation ist nun abgeschlossen.
Eine zusätzliche Installation von SuperSu und
BusyBox ist nicht mehr nötig. Beides ist integriert
und konfiguriert. Es bestehen
umfassende und volle Schreibrechte.
Das ROM ist nicht debloated, jedoch einiges
deodexed und zipaligned.
- In Xposed habe ich nur Perfect Color Bar aktiv.
- Der Button für den App Drawer befindet sich unten in
der Mitte des Homescreens.
- Der Call Recorder ist aktiviert.
- No-frills Habe ich auf Powersaving
voreingestellt.
- Die Icon Größe habe ich von 175 auf 120 verkleinert
und den Homescreen auf 8x8 gesetzt.
-Der Download von Themes geht wahrscheinlich nicht.
Bitte regelmäßig Backups anlegen, da
Google gerne mit Custom Roms "rumzickt".
Mit dem Installer im App Manager kann man auch
einiges ausbügeln.
......Und denkt auch daran: ein Custom ROM ist
nie so perfekt, wie ein Stock-Rom. Dem muss man
stets einiges selber passend beibringen.
Es kann nicht schaden, wenn es mal "klemmt",
zwischendurch einen kleinen Wipe
zu machen. (Cache+Dalvik)
Der FACTORYRESET gehört ab jetzt der Vergangenheit an.
Dieser "entgooglet" die Firmware nun komplett.
Das bedeutet, dass danach auch keine Google Anmeldung und keineTastatur mehr
vorhanden ist. Kommt Ihr aus irgendwelchen Gründen in die Situation,
in der Ihr sonst einen Reset durchführen würdet, macht Ihr Folgendes:
Per TWRP Restoring nur das System meines Backup-Roms ausführen.
Dann ist alles wieder gut. Alle Eure Apps bleiben mit Einstellungen dabei erhalten.
Es gibt auch noch diese "Notbremse":
Wer, warum auch immer, alles vermurkst hat, kann auch alles wieder retten.
Einfach mit meiner aktuellen UPDATE.ZIP der B390 ein Update ausführen
und alles ist wieder gut.
Viel Spaß !
Thread Update:
22. Mai 2017
Als Alternative habe ich hier noch ein ROM auf die reine B390 aufgebaut.
[Custom Rom] Huawei Mate S -CRR-L09-C432B390–PHOENIX
EMUI 4.0.3 - Android 6 -
App Manager
App Drawer
Dolby Atmos
Dolby Cinema
HiLink
CPU Saver
Perfect Color Bar
GravityBox
Viper4 Android FX
Xposed
K-Settings sind nicht dabei.
- CPU Saver ist auf 403 MHz
für den Lock eingestellt,
- im ES Autostart Manager habe
ich einiges deaktiviert, was sich
einfach zurücknehmen lässt.
App Manager
App Drawer
Dolby Atmos
Dolby Cinema
HiLink
CPU Saver
Perfect Color Bar
GravityBox
Viper4 Android FX
Xposed
Vielen Dank an: KangVip, Chainfire, Stephen (Stericson) + Jmz Software, rovo, sowie Huawei Technologies Co., Ltd 华为技术有限公司
[HINWEIS: Trotz sorgfältiger Ausarbeitung kann ich nicht garantieren, dass durch die Durchführung dieser Anleitung keine Schäden an Gerät oder Betriebssystem entstehen und übernehme daher keine Haftung für auftretende Schäden und Fehlfunktionen an Hard- und Software! Solltest Du noch unsicher sein, befolge diese Schritte: Die Anleitung nur durchführen, wenn evtl. genannte Bedingungen (Modellnummer, Android-Version etc.) auf dich bzw. dein Gerät zutreffen. Anleitung aufmerksam und vollständig lesen, unbekannte Begrifflichkeiten nachschlagen.Heruntergeladene Dateien auf Viren überprüfen. Ein Backup wichtiger Einstellungen und Daten machen. Die Anleitung nicht durchführen, wenn Du nicht weißt, was Du tust.
