2babe
Dauer-User
- 1.005
Es tut sich ja richtig was, hier der Original Tread:
[Kernel][MM 6.0][H815][Linux 3.10.94] Imperium Kernel G4 v1.3 [11/01/16]
v1.8 -10/02/2016
- ARM: 7884/1: mm: Fix ECC mem policy printk
- ksm: check and skip page, if it is already scanned
- cpufreq: qcom-cpufreq: Check return of cpufreq_frequency_get_table
- drivers: misc: qseecom: Fix app name size
- arm64: replace read_lock to rcu lock in call_break_hook
- ARM: 8167/1: extend the reserved memory for initrd to be page aligned
- block: fix blk_stack_limits() regression due to lcm() change
- genalloc: fix device node resource counter
- cpufrq: updated zzmoove cpu gov
- cpufreq/governor: avoid a possible crash in msm thermal driver when freq limits are changed due to thermal events [ZaneZam]
- cpufreq_elementalx: lower sampling_down_factor for big cluster. Also increase sampling rate to 20000
