Sh0X31
Enthusiast
- 828
Introduction:
TeamWin Recovery Project, or twrp for short, is a custom recovery built with ease of use and customization in mind. We started from the ground up by taking AOSP recovery and loading it with the standard recovery options, then added a lot of our own features that we deemed missing from current recoveries. After weeks of hard work, we are happy to announce the release of twrp.
Key Features:
- Clean, simple, intuitive Menu System
- Ability to save custom recovery settings
º Default partitions to back up
º Default zip folder location
º Default color theme (lots to choose from) (Thanks to ffolkes!)
º Default Time Zone (for more accurate time stamps)
º Zip Verification
- Ability to select which individual partitions to backup, and restore.
- Ability to choose compression or no compression backups.
º Compression takes longer of course, but you save roughly half the space. You choose.
- Ability to auto reboot after successful flashes (for the lazy)
- Battery Level and Timestamp (Better safe than sorry)
Known Issues:
- Battery level does not display correctly yet
- If you see a checkbox in backup or restore below cache and above android_secure, do not check this box
Disclaimer:
As usual, use at your own risk. TeamWin is not responsible for anything bad that may occur from using twrp. We do however take responsibility for the awesomeness that comes with it. Don't be a d3rp and use twrp for bad. With great power, comes great responsibility.
Special Shout Outs:
- TeamWin
º toastcfh - for his under appreciated dedication to the community.
º AssassinsLament, agrabren, Dees_Troy, joeykrim, shift, vividboarder, onicrom, netarchy, kevank, myndwire, bigbiff, dkelle4, shinzul, spiicytuna, eyeballer, OtisFeelgood.
- Amon_RA - for his great Recovery for which we gained a lot of inspiration from.
- Koush - for his dedication to the community and ClockworkMod.
Source Code:
GitHub
Download:
Download link is on our site, click on the link for your device at the top of the page.
MD5 will display with the download link.
(updated download link to include flashable zip - flash using hboot courtesy of xboarder56)
Key Features:
º Zip Verification
Known Issues:
Disclaimer:
Special Shout Outs:
- TeamWin
Source Code:
GitHub
Download:
