welches rom den nun ics??
  • 8 Antworten
noch gar keine.die letzte und neuste ist die B919 aber diese soll wohl noch eine beta /demo sein.
also heißt es leider noch warten.
also gehe ich wieder zurück auf 2.3.6?
gibts da ne empfehlung?
welche hast du denn jetzt drauf ?
4.0.3 CV100R001CHNC00B919
gerootet, alles genau nach aneleitung von hier
Upgrade to ICS 4.0.3
Download ICS 4.0.3 upgrade from huaweidevice.com/cn/downloadCenter.do?method=toDownloadFile&flay=softw are&softid=NDExNTI=
Make a “dload” directory on SD card root directory
Copy the "UPDATE.APP” and "UPDATE_CUST.APP" to "dload" folder on SD card.
Long press volume up + volume down + power button on the handset to startup you device in upgrade mode.
It will reboot few times.
Delete "dload" forlder on sdcard
Root access
Download recovery image at mediafire.com/?2e8prgk99e3n0f7
Download su-3.0.3.2-signed.zip at mediafire.com/?burku15l62eb4te
copy su-3.0.3.2-signed.zip to the root of sdcard
Delete "dload" folder on sdcard
Open settings / application then turn off/unthick "fast boot"
Unplug any usb connection and turn the phone completely off
Holding both the volume up + volume down + power button to startup you device. Let go when you see a pink/purple screen.
Attach the usb cable to your computer and wait until a few usb mass storage devices are detected and mounted.
Look for one that has just one directory called "image" in it. Navigate into this directory and you'll see "recovery.img" etc.
Rename "recovery.img" to "recovery.org"
copy "recovery-v8.img" to image folder and rename to "recovery.img", unmount the mass storage device (safely remove in windows) and then pull the battery out to turn the phone off
Long press volume up + power button on the handset to startup you device in recovery mode
Select “Install zip from sdcard”
Select “choose zip from SD card”
Find and select "su-3.0.3.2-signed.zip"
Select "++Go Back++"
Select "reboot system now"
Add google apps to ICS 4.0.3
Download gapps-ics-20120215-signed.zip at goo-inside.me/gapps/gapps-ics-20120215-signed.zip and copy to sdcard
Find and select "gapps-ics-20120215-signed.zip"
On dial pad type ( *147258369# ) select "Display GMS apps" and "Ok"
Reboot phone
All done
Arnt
wenn sie dir soweit gefällt kannst du sie drauf lassen.
wenn nicht kannst du wieder zurück zu GB.huawei hat es ja mittlerweile geschafft die GB version freizugeben die ursprünglich auf dem honor drauf war.
mir gefällt es überhaupt nicht, habe kein play store(anscheinend nur die chinavariante), also allg. keine gapps, noch viele chin. apps, komme gar nicht richtig klar
wie installier ich das GB? mit dload auf sdcard?
danke für deine mühe!
danke,
ich habe nun einige versionen drauf gehabt,das china b919, birdy-rom, mui 2.6.1 , alles irgendwie nicht zufriedendstellend, weil zu langsam, wird das denn besser wenn die offizielle ics raus ist?
