[ROM][LB&UB] CriskeloROM [AROMA][STABLE]
Warren Piece
Warren Piece
Nach meiner Galaxy S2 ROM kommt nun Die CriskeloROM für das Xperia Z.
Much FUN:thumbsup:
Original Forum
Android 4.4
Code:
## [COLOR="Red"]CriskeloROM [/COLOR]v6.0 ##
New Firmware 10.5.a.0.233
+ Deodexed
+ Zipalgin All Files
+ CWM Recovery
+ Root
+ SD Card Fix
+ SuperuserMOD
+ init.d Support
+ Remove Bloatware
+ Criskelo Settings
- GravityBOX - Update variable
- Criskelo Explorer
- App Settings
- Autostart
- Display Tuning
- LED Control
- LED Flash Settings
- Battery Issues
- Criskelo Weather
- Netweork Speed indicator
- Kernel Control
- Display Test
- CPU Spy
- Criskelo INFO
+ Criskelo Bootanimation
+ Criskelo Wallpaper
+ Performance Scripts
+ Build.prop Tweaks
- Net Speed
- Wifi Speed
- Signal Tweaks
- Performance Tweaks
+ Delete Lockscreen Text
+ Sqlite
+ Tap on Build open Changelog
+ Adblocker HOST
+ Adb Notification Disabled
+ Clear Home Interface
+ OTA Updater
+ AOSP Browser
+ PlayStore 4.8.20
+ Set Softkeys 40 dpi
- Aroma: 32, 36, 43, 48 DPI
+ Enable Call Recording
+ Traffic Banner Disabled
+ Slider Widget
+ Torch
+ Black YouTube HD
+ Criskelo Sony Theme
+ Choose 5 or 7 Dock
+ Fix Mount to Reboot
- Folder Mount and DirectoryBind works perfect
+ Replace Bravia Engine 2 with X-Reality
## Black Apps ##
+ Settings
+ SystemUI
+ SmallAppsLauncher
+ SomcMirrorLinkServer
+ SomcMusicSlideshow
+ SomcWifiDisplay
+ WirelessControllerMangerService
+ Skin-Core
+ Textinput
+ SemcEmail
+ Calendar
+ Phonebook
+ Call Menu
+ Calculator
+ SemcClock
+ Conversations
+ AnonymousData
+ enhancedusbux
+ GpsSatellitesNotification
+ HotSpotAdvanceSettings
+ LocationsBasedWifi
+ OMAClientProvisioning
+ ReadyToRun
+ SomcPlayAnywhere
+ SemcTvOut
+ SomcMirrorLinkManualSwitch
+ TetherEntitlermentCheck
+ SOMCTTwitterAccount
+ TopContactsWidget
+ sneiaccountmanager
+ PrintSpooler
+ POBoxSknSelector
+ DocumentsUI
+ Sound-Picker
+ SuperStamina
+ MyXperia
+ SEMCFacebookProxy
+ SemcSettings
## [COLOR=#FF0000]CriskeloROM [/COLOR]v5.0 Kit Kat ## (Via OTA)
+ XReality Port Z2
+ Xperia Keyboard Update BLACK
+ Deodexed
+ SD Card FIX
+ SuperuserMOD
+ Root
+ BusyBox
+ init.d
+ Remove Bloatware
+ Criskelo Settings
- Criskelo Explorer
- App Settings
- Autostart
- Display Tuning
- LED Control
- Battery Issues
- Criskelo Weather
- Kernel Control
- Display Test
- CPU Spy
- Criskelo INFO
+ Build.prop Tweaks
- Net Speed
- Wifi Speed
- Signal Tweaks
+ Sqlite
+ Adblocker HOST
+ OTA Updater
+ AOSP Browser
+ Modify Camera Sound Bitrate "High"
+ Virtual Power Button in Statusbar "Left"
+ Add New PlayStore with PayPal
+ Flash Player
+ Slider Widget
+ Torch
+ Black YouTube HD
+ Choose Between 2 Lockscreens
## Black Apps ##
+ Settings
+ SystemUI
+ SmallAppsLauncher
+ SEMCSetupWizard
+ SomcWifiDisplay
+ Skin-Core
+ Textinput
+ SemcEmail
+ Calendar
+ Phonebook
+ Call Menu
+ Calculator
+ SemcClock
+ Conversations
+ AnonymousData
+ enhancedusbux
+ ReadyToRun
+ SomcPlayAnywhere
+ SemcTvOut
+ TopContactsWidget
+ PrintSpooler
+ POBoxSknSelector
+ DocumentsUI
+ Sound-Picker
+ SuperStamina
+ MyXperia
+ SEMCFacebookProxy
+ SemcSettings
Rush
Pseudofreak
Sentakage
Goldieking
Criskelo
Maanz
Carotix
::indie::
Wanam
GoA
Salesale
Westcrip
bajee11
Thanks for Donor
-Stormi
-Osimonster
-Bernd L.
-Zelle
-Hottentott
-Roland W.
-Thomas M.
-XXX_SunnyBoy_XXX
-Sentakage
-Marcin
Flash your own Risk
Verteile NICHT MEINE DOWNLOADS
Download NUR im Original Forum
Reaktionen: veryjo, mrrbr, Ghostrider68 und 2 andere
CriskeloROM [LITE v1.7]
+ PureX Audio
+ Set Settings Icon
+ Monx Battery Icons
+ Remove Radio
+ Remove Update Center
+ Remove Car Home
+ Remove Velvet
+ Remove Play Games
+ Remove My Xperia
+ Remove Google+
+ Remove Top Contacts Widget
CriskeloROM [FULL v1.7]
+ PureXAudio v22 Final
+ Update GravityBox 2.7.2
+ 23 Battery Styles
+ Add Changelog Function to press on Build ROM
+ Set Settings Icon
CriskeloROM FULL
MIRROR1 FULL
CriskeloROM LITE
MIRROR1 FULL
[ROM] [LB&UB] CriskeloROM v1.7 [FULL & LITE][18/11] - xda-developers
Vielen Dank für die Lite Version! :drool:
Reaktionen: Replikant und Warren Piece
Danke für das benutzen meiner ROM :D
Ja ist super zumindest die 1.5 die 1.7 werde ich gleich flashen!
Kannst du das ganze in Verbindung mit Aroma bringen??
Ich habs versucht ist nicht so wie mein S2 damals. Der Aroma funktioniert nicht auf jedem CWM
CriskeloROM [LITE v2.0]
+ New Firmware (Inspirate of MonX)
+ Remove PureX Audio (please Install as MOD)
+ Stock Browser
+ Add RescanSD
+ Set 5 Way Reboot (By Monx)
+ Terminal Emulator
+ Total Commander
+ Kill All Button (by Monx)
+ Honami Launcher
+ The Fastest ROM
CriskeloROM [FULL v2.0]
- PureX Audio
+ Stock Browser
+ Add RescanSD
+ Terminal Emulator
+ Total Commander
+ Honami Launcher
+ Android Keyboard
+ Android Kamera 4.2
+ Android Gallery 4.2
- 23 Battery Styles
xda-developers - View Single Post - [ROM] [LB&UB] CriskeloROM v2.0 [FULL & LITE][20/11]
Reaktionen: Warren Piece
Danke.
Ich habe den Thread mal Bearbeitet
Perfekt!!
Jetzt also doch in Verbindung mit Aroma! :thumbup:
Hab das ADDON Packet nochmal geupdatet.
ChangeLog steht oben
Reaktionen: lkrys
Thread Aktualisiert
Da ich jetzt auch ein Z habe stelle ich mir nun die Frage ob das im Grunde die gleiche Rom ist, die ich auf dem Z1 habe :-D
(kurze Erklärung, das Z1 muss leider WIEDER in den Service und da kam mir Nachbars Z (für 200€ im top Zustand) natürlich sehr gelegen :D
Werde das Z1 jetzt am WE platt machen und denn Bootloader wieder schließen und Montag versenden.
B2T: ist die Version für das Z genau wie für das Z1?
Im grunde muss ich zuerst Sagen ich habe MEINE Tweaks, Scripte, MODs und Funktionen.
Also es ist das Selbe Grundkonzept und ich versuche meine ROM auf allen ROMs gleich laufen zu lassen.
Also sind wenn überhaupt kleine sachen anders ansonsten gleichen MODs etc.
Alles was man an Problemen aufm Z1 hat, hat man auf dem Z nicht.
Das Xperia Z ist ja mein Haupt Handy und ich kann dort alles viel besser durchdenken als wie beim Z1. Da müssen meine Tester ran da ich ja keins habe
Reaktionen: derOyabun
Sehr feine Rom... hab diese jetzt seit etwas mehr als ner Woche drauf und bin äußerst zufrieden, daher hier nochmal n "ordentliches Dankeschön" (statt nur nem Klick untern ersten Post)
Grüße
wie bekomme ich CWM wieder?
Ich komme da nicht rein Root ist I.o
Danke für die Info :)
Superuser fix installiert?
Immer nach der anleitung halten
Hat Du es vergessen musst du neu aufsetzen weil du kein root hast und somit auch kein cwm
genau das habe ich getan root habe ich ja das ist nicht das problem
Dann schnapp dir NUTs Cwm und flash die BAT per pc
Echt seltsam
Bei offenen bootloader kommt es momentan zu Root Problemen.
Supersu muss nach geflasht werden, das passiert beim ota Flash.
Selber Fall wie beim z1
nee mein Bootloader ist geschlossen
Ich werde mich nachher mal dran setzten
Danke erstmal
so ich habe cwm nachträglich installiert und was soll ich sagen....
hängt beim sony fest
Apollonios
Anonym6x6
Anonym6x6
Anonym6x6
honigfisch
  • honigfisch
honigfisch
honigfisch
