[ROM][N7100][4.4.4] *30.03.14* SOKP - Sonic Open Kang Project [ChameleonOS]
Dodge
Dodge
Dauergast
597
[★N7100● KK 4.4.4★][★★][★DTS Audio X-Reality★][★Multi-Window ★][★AIO★]
picture.php
Grundlegende Features
Basierend auf CyanogenMod 11
HALO floating Benachritigungen
MultiWindow
ActiveDisplay
PIE Steuerung
Gesture everywhere
MultiUser
Build.prop mods
INIT.D mods
LCD Density Changer
HyBridUI - Phablet & PhoneUI
Custom ProgressBar
Multimedia-Features und Apps
X-Reality Engine ported vom Xperia Z2True HD Display
Pure HD Theater Mode Video Rendering aktiviert mit High-End Grafik-Einstellungen
Neuster Sony Walkman Player vom Xperia Z2 mit Clear Audio+
Neueste Sony Movies & Album vom Xperia Z2
Digital Dolby vom Huawei ACSEND P6
Unique DTS HD Audio System für True HD Sound
Audio FX Widget als Equalizer für Musik, Video & Gaming
Alle Features
CyanogenMod 11.00 Based
Option to Hide Notification Lables
Notification Transparency
Contextual Notification Panel Header
Notification Power Widgets with changeable background and icon colors
Tiles layout customization with quick pull-down,smart pull down,quick collapse.,background and icon color options
Status Bar Customizations like Battery icon,Clock and Date,Status Bar colors
Network Traffic Meter
Signal Text Color,Hide Signal Bar option
Custom Carrier Lable
Double Tap to sleep Option
Breathing Sms Notification
Breathing missed cal notifications
Breathing voice-mail Notification
Customizable Low battery warning
Limit the notification sound of each application
Screen on Notification Light(enable/disable)
Custom System Animations
CRT Animation
List view Animation
Toast Animation
IME Animations
Multiuser Support in lock-screen security
screen lock options
Lock screen themes for rings and elements
Customizable Slider Targets and Shortcuts with Eight slider Targets
Lock Screen widgets with maximize and minimization option
Phone encryption
Lock Screen Notification Access control
Lock Screen Notifications
Customizable Lock Screen Icons
Lock-screen Power menu
Transparent & Blur Lock-screen
Lock Icon Torch
Halo floating Notifications
Customizable Power menu with lots of options
Advanced Display control Configure your screen colors
Chameleon OS Active Display
Gesture Navigations
Chameleon OS Gesture Every where
Customizable Navigation bar with Navigation Rings'
Custom Progress bar make your own color full progress bar
Slim PIE control
Chameleon OS Identicons
Recent View customization can chose stock or Slim recent view with memory indicators,clear all button
Customizable recent panel color
Build Prop mods enable disable option menu
INIT.D mods enable disable option menu
System Application remover
LCD Density Changer
Wake lock Blocker
Suspend Action When screen goes off
Scrolling Animations
Disable full-screen keyboard option
Recent ram Bar with customizations
Media Scanner Behavior Controller
Option To Disable FC Notifications
Default App grip option
Dual Pane options
Do not disturb option
Show notification count
Kil app back button with customizable timeout values
High end graphic effects option
Dark SOKP UI
App Permission Options
Advanced Kernel Tweaker Instead of Performance control with lot option to control CPU & GPU
GPS Location Fix
Build Prop Editor
Seeder Entropy Generator
X-Posed Framework
Per Application DPI
HyBrid UI>>>Phablet And Phone UI
Omni Duel Split Screen
Unlimited Floating Multi window
Network Connection Manager
Status Bar Battery Bar
Status Bar Brightness slider
Cast Screen
Screen Recorder with Audio option
Adaptive Back light
Privacy Guard
Sony Xperia Z2 application like Sketch (Pen Supported),Tasks,Converter ,Car launcher.
option to use a fully themable MMS packages. You can access from mms - settings - theme settings
Superuser fully embedded into the build and accessed from settings menu
Enable/disable wake up on charge option
insane amount of edits/tweaks/fixes to make this ROM absolutely fly
option to disable/enable vibrate on expand for notifications alerts
ScreenShots
Installationsanleitung
► Philz Touch Recovery flashen
► Wipe data/Factory Reset
Direkt hier fortfahren wenn Update
► Wipe Cache & Dalvik Cache
► Installiere ROM
► Installiere GApps
► Neustarten
Download Recovery Goo.im Downloads - n7100
Official Philz Touch Recovery
Download ROM Samsung Galaxy Note II | Sonic-Developers
Download GApps SensonicUltralimGapps V-1
SENSONICHD Ultra Slim GApps V-1
XDA Developers Thread SONIC OPEN KANG PROJECT - xda-developers
Sonic Developers Thread [ROM][Note-2 N7100
Changelog GEN INFO | Sonic-Developers
Entwickler
Audio God, a2441918 (xda-devs)
ROM OS Version: 4.4.x KitKat
ROM Kernel: Linux 3.0.x
Basierend auf: CM11.00, Bean Stalk, AOKP, SLIM, PA, Chameleon OS
Version Information
Status: Stable
Current Stable Version: RC-01
Stable Release Date: 2014-03-30
Haftungsausschluss | Sonic-Developers
Credits | Sonic-Developers
Wie bei jeder ROM gilt auch hier..
weder ich, die xda-devs, noch das Android-Hilfe-Forum ist für jegliche Schäden haftbar,
flashen und benutzen auf eigene Gefahr!
Reaktionen: ballonchef und Bastizpunkt
Ich habe vom AOSB Project genug, wird mir zu langweilig, kaum noch Updates und Neuerungen, Audio-Ruckeln im Standby und mit dem WLAN meiner Uni beißt es sich in letzter Zeit auch..
Die ROM ist bereits runtergeladen, nach dem Muckie-Training werde ich's mal flashen und einrichten.. berichte anschließend.
@Mods Seid zart mit mir, ist mein erster ROM-Thread. :D
Ich hab's versucht nach dem gängigen Layout zu gestalten, bei Wünschen und Hinweisen gern PN :)
Hi,Danke für das ROM.Bin schon am laden und werd`s testen.Mal sehen wie es mit der Zeit aussieht.Vielleicht gleich morgen.
Gruß Fiedl
Hallo Dodge! Danke fürs Herholen des ROMs zu uns! :thumbsup:
Der Thread ist bereits hier zu finden: https://www.android-hilfe.de/forum/...links-zu-allen-note-2-custom-roms.395825.html
Ich persönlich finds gut. Auch wenn viele hier wissen, was zu tun ist, würde ich dich dennoch bitten, dass du noch eine kurze Installationsanleitung einfügst. :) Dann wäre der OP perfekt.
Wenn du in irgendeiner Form Unterstützung benötigst, z.B. einen 2ten Post für Changelogs, etc., so melde dich bei mir. :)
Der ursprüngliche Beitrag von 18:38 Uhr wurde um 18:39 Uhr ergänzt:
Ich bin wirklich versucht, den ROM auch mal zu testen. Der klingt sehr interessant!
Reaktionen: Dodge
Hi, brauch man da nicht auch gapps dazu?
Gruß Fiedl
Yep, braucht man. Die kann man ja dann in den Installationsinstruktionen unterbringen.
Reaktionen: Fiedl
Ich hab die Rom schon getestet, läuft wirklich wunderbar und ich hätte sie gerne drauf gelassen, aber ich bekomme die LED nicht zum Laufen.
Bei XDA hab ich schon beim Dev nachgefragt, ich schein wohl eine Ausnahme zu sein, denn angeblich geht die LED bei allen anderen.
Ich hab es mit Light Flow probiert, einmal mit einer älteren Version und mit der neuesten (hab die Donate App), alles aktiviert, wie es sich gehört und keine LED leuchtet. Auch beim Testdurchlauf der aktivierten Apps tat sich nichts.
Nun ist mein Englisch:scared: und wie ich den Dev verstanden habe, gibt es auch innerhalb der Rom die Möglichkeit, die LED für die jeweiligen Apps einzustellen.
Aber ich finde rein gar nix. Bin die ganze Rom durch.
Wäre schön, wenn Jemand zur LED mal ein Feedback abgeben kann, ob die funktioniert und wenn ja, mit welcher App.
Gern, hat mich vom Mix sehr gereizt, mal sehen wie's sich anstellt :)
DirtyKlot schrieb:
...eine kurze Installationsanleitung einfügst. :) Dann wäre der OP perfekt.
Wird gemacht, wusst' ich doch dass etwas fehlt :tongue:
Fiedl schrieb:
Exakt, wurde in die Anleitung aufgenommen, Danke :thumbup:
/OP aktualisiert.
Nun wird geflasht, los gehts! :drool:
Der ursprüngliche Beitrag von 22:32 Uhr wurde um 23:59 Uhr ergänzt:
Bis jetzt alles schön smooth, Oberfläche wirkt sehr aufgeräumt, die SlimRecents finde ich sehr hübsch gemacht.. :thumbsup:
Soo jetzt ist alles drauf und schön eingefahren.. ein entdeckter Bug: ActiveDisplay - beim Swipen kommt nicht der Lockscreen, sondern kurz die letzte App und dann der Lockscreen, ich schau mal was ich falsch gemacht hab :D
Also SystemUI.apk schmiert anscheinend ab.. finde den Bug leider nicht :o
Reaktionen: Denowa
So, meine erste 4.4.2 ROM, hatte vorher immer 4.3 (Samsung Basis) drauf. Bisher bin ich sehr zufrieden.
Einzigst... ich habe irgendwie jetzt schlechten Download Speed. Wenn ich vorher was aus dem Google Playstore gezogen habe, ging der Download immer sehr schnell. Jetzt komme ich bei keinem Download mehr über 100 KB/s.
Liegt das jetzt an der ROM, oder an der 4.4.2 Android Version oder am Playstore selber?
Nachtrag: es ist alles viel langsamer, auch Downloads aus anderen Quellen. Wenn ich jetzt z.B. beim Themer durch die Themenliste scrolle, braucht das ewg zum laden, vorher waren die Vorschaubilder immer sofort da.
komisch, ich konnte keine Einschränkung feststellen, sowohl PlayStore als auch downloads über Opera.
LED funktioniert bei mir auch - lediglich Viper4Android AudioFX konnte ich nicht installieren.. wird auch nicht unterstützt werden.
Auch hat ActiveDisplay immernoch zicken gemacht, auch wenn es keine Benachrichtigung gab..
ich switche derzeit zwischen AOSB und SOKP hin und her, werde morgen mal das Backup wieder einspielen und alles intensiver testen :)
Hab nochmal Full Wipe gemacht und neu aufgespielt. Jetzt läuft der Download wieder gewohnt schnell. LED funktioniert bei mir auch ohne Probleme.
Habt ihr denn irgendwas eingestellt, damit die LED funktioniert?
Ich hab nichts weiter eingestellt, funktionierte sofort.
Es gibt seit gestern ein neues ROM release!
@skysat danke für die Info
Dieser Thread ist ab sofort ausgeschrieben!
Danke hierbei an Dodge für das bisherige pflegen! :thumbsup:
Wer sich bereit erklärt, den Thread zu übernehmen, möge sich bitte hier im Thread oder bei der Moderation per PN melden. Vielen Dank!
Grüße
Reaktionen: Dodge
Es gibt mittlerweile eine neue Version basierend auf Android 4.4.4 und sie läuft sehr gut. Bin von Aosb hierher gewechselt und habe es bis jetzt noch keine Sekunde bereut. Kommen auch jede Woche neue Weeklys raus.
Hi Fan Gemeinde,
ich vermisse bzw. finde die HybridUi nicht.
Bei mir läuft das ROM etwas hacklig.Würde ein Kernelwechsel was bringen?Wenn ja,welcher am besten.
Ansonsten TOP.
Gruß Fiedl
Dr.No
Taker18
Sealsman
Silverblade
Nufan
Nufan
