[ROM][ICS][AOSP] 4.0.4 Alpha (Build 1) by Broodplank1337
  • 63 Antworten
XeLLaR
XeLLaR
Dauer-User
621
Broodplank1337 hat mal wieder was für uns :flapper: :drool:
Orginal Thread@XDA-Developers: [ROM][ICS][IMM76L]AOSP 4.0.4 Stock Alpha (Build 1) *HOT* - xda-developers
AOSP 4.0.4 IMM76L by broodplank1337
Info:
I'm very happy to release the first alpha build of AOSP IMM76L for Samsung Galaxy S Plus (GT-i9001). Most of you probably know that i've been busy with compiling AOSP for a long time now, and I finally succeeded to compile it by using a very wrong and lame way (tut will come later). Anyways the build is running very stable so far and the performance is very neat. Currently some CM9 sources are copied to the AOSP build to make it working correctly, all the apps (except Phone.apk) are compiled from original AOSP source, I use the framework files from CM9 (Ivendor) but downgraded to get the AOSP wanted result.
I've included a stock kernel based on Arco's i9001 kernel, I've replaced interactive with smartassV2 and added SIO, these 2 are the default choices for the kernel/rom. The kernel is compiled with Linaro toolchain for best performance.
Finally we got ourselfs an AOSP Stock ROM to modify ! Please give me as much feedback as possible, so I can improve the ROM!
What's working:
Audio
Receiving and making calls
GPS
Compass
Proximity sensor
Wifi
Bluetooth
USB mass storage
HW accelerated gui
HW accelerated video
Camera
Wifi and USB tethering
What's not working:
FM Radio
CHANGELOGS:
New Release! Alpha 02
- Fixed FC's at APNList/AccessPoints
- Removed Dialpad preferences / additional vibrate options for Phone.apk (CM9)
- Original Extended Power Menu / Statusbar now
- Removed ThemeManager/ThemeChooser/Development apks
- Added more sounds
- Much higher performance thanks to linaro "stock" kernel (with some castagnait tweaks)
- Updated libs/egl
- Removed all deprecated and useless files
- Added init.d support (make the folder and give permissions of atleast RWX-RX-RX)
- Probably more, but I forgot it, will add it when I remember
And for the record, I have no clue if incall volume is fixed, couldn't really test it today. Also same thing for random reboots, I haven't experienced one since the new version, so I hope that's for all of you!
Download:
Note: I am not responsible for any damage caused to your device.. >>> insert violation warranty bollocks here <<<
Version Alpha 02 (19-11-2012)
Mirror #1 Mediafire.com
Version Alpha 01 (03-11-2012)
Mirror #2 Sourceforge.com
Mirror #3 Zippyshare
Mirror #4 broodplank.net
Also download gapps
Goo.im Downloads - Downloading gapps-ics-20120429-signed.zip
Install
Make sure you use CWM5 or CWM6. (important!)
(Newer CWM 6.0.1.2 version available here)
- Wipe data and cache. (if coming from samsung rom, if you're using CM9 you may only wipe cache)
- Flash AOSP_IMM76L_AriesVE-Alpha01-broodplank-signed.zip.
- Flash update-Gapps-ICS-20712.zip. You must flash gapps after every upgrade to AOSP 4.0.4 since /system is formatted, wiping your previous add-ons.
- Reboot phone.
Credits
CyanogenMod Team
AOSP Team
arco
ivendor
Reaktionen: pjozsef54 und burns_vectra
Feine Sache was Brood da mal wieder rausgebracht hat... wird Morgen wohl gleich mal angetestet :)
Brauchst du noch einen Mirror von uploaded?
uploaded wäre super :rolleyes2:
wo liegt eingentlich der unterschied zwischen 4.0.1 und 4.0.4 ?
Einige Bug-fixes im Sourcecode von Android.
Ein Tipp an alle: Mit Zippyshare könnt ihr eure Inet leitung auslasten. Da bekommt ihr auch als Unregistriert den vollen Speed!
Na ich bin mal gespannt wie die AOSP von Brood ist... macht keinen ganz schlechten Eindruck aber ist IMHO nicht ganz so flüssig wie EhndroiX ...
Na warten wir mal ab was der morgige Tag so bringt und welche neuen ROM´s auf Android Open Source Project aufgebaut werden :D
Greets
Wer einen Uploaded Mirror will, bitte einen entsprechenden Beitrag machen oder diesem Beitrag danken. Bei über 15 mache ich einen.
Uhhh feine Sache :)
Ein "reines" Android und keine CyanogenMod. Sieht gut aus!
Die Rom läuft soweit sehr sehr gut! Überzeugt mich.
Ich werde jetzt mal NFSMW testen.
Kommt gleich mal drauf, mal sehen ob sich der Akkuverbraich gegenüber GB behaupten kann ... ;)
NFS läuft erste sahne.
Werde weiter berichten.
Mal eine dumme Frage am morgen.
Kann ich das auch mit TWRP installieren?
Da die AOSP von Brood auf CM9 basiert behaupte ich jetzt einfach mal ja.
Greets
Werde es mal testen, wenn nicht habe ich ja mein Backup.
Denke auch das es funktioniert, wollte halt nur auf Nummer sicher gehen.
Greets
AOSP basiert nicht auf CM9. Brood hat die Configs von CM9 für das Kompilieren der Rom übernommen.
CM9 basiert auf AOSP ;) :thumbup:
Ich benutze die Rom jetzt seit Gestern abend, und muss sagen die stellt CM9 und AOKP Weiiit weit in den Schatten. Mein S Plus fliegt fast.
Ich denke auf der Rom bleibe ich jetzt erstmal bis Arco/Ivendor ihr Cm10 releasen.
Oh sh*t.... AOSP oder CM10?! Ich kann mich nich entscheiden -.-
Wenn nur nich immer ein fullwipe nötig wäre würd ich stündlich wechseln :D
Sent from my rooted toaster using Tapatalk
Hat mit TWRP funktioniert.:thumbsup:
Läuft bis jetzt gut.
Jaschi
Reaktionen: Rhonin
releasen.
AOSP im allgemeinen ja... Ist ja logisch da AOSP die Stock aller Stock´s ist ^^ Hier ist das jedoch etwas anders... :p
Zitat Broodplank : "Well what is better.. more options? better performance? you tell me. CM9 is built on AOSP, but in this case AOSP is built on CM9 which is built on AOSP"
Bin soweit ja wirklich auch zufrieden mit dem was Brood da gemacht hat... solange keine Rom rausgebracht wird die auf diesem AOSP aufbaut bleib ich da erstmal :D
Greets
Reaktionen: XeLLaR
Ich denke mal, dass ich die auch mal testen werde. Sie scheint mir mal eine ROM zu sein, die eine gute Performance bietet.
Leider konnte ich nirgends etwas darüber finden, ob diese über die orignial Ladeschale von Samsung geladen werden kann ? Hat da jemand Erfahrungen ? Da ich diese weiter nutzen möchte, wäre dieses das einzige No-Go Kriterium.
Cheers
Rhonin
