Android 2.2 download + anleitung für nexus one oder mehr...
WiRsindDi3BorG
Gast
so hier die von google heute veröffentlichte version von android 2.2 froyo für das nexus one ob bei anderen auch funzt kein plan ^^
How to manually update your Nexus One
If you're the type who just can't wait for an update to be pushed out (erm, like some of us around here), you're in luck. You can manually apply today's update to your Nexus One, enabling multitouch and (hopefully) fixing that pesky T-Mobile 3G issue. Here's how to do it: [via Android Forums]
1. Download the update from here signed-passion-ERE27-from-ERD79.a487b405.zip ... at uploaded.to - Free File Hosting, Free Image Hosting, Free Music Hosting, Free Video Hosting, ...
2. Rename the file to update.zip. Note that if you're using Windows, just rename it to "update" (no quotes, of course) because it's already a zipped file.
3. Copy the update.zip file onto your microSD card.
4. With your Nexus One off, hold down the trackball and press the power button.
5. You'll be booted into a white screen with three Android robots on skateboards. Select "Bootloader."
6. On the next screen, select "Recovery."
7. Your phone will reboot, giving you a picture of the Android robot and an exclamation point inside a triangle.
8. Now press the power button and volume up button at the same time. It could take a couple of tries.
9. Now (using the trackball this time) choose "Apply sdcard:update.zip" and let things run their course.
You may have to soft reset a couple of times after this. (I got a picture of the Android guy outside of a box. But a couple resets later and all was well.) But now multitouch is enabled, and we can sit back and relax, knowing that we have zero patience and just can't help ourselves.
WiRsindDi3BorG
wiederstand zwecklos ;) :p
p.s. alles auf eigene gefahr ^^
Eine der wesentlichen Verbesserungen von Android 2.2 Froyo ist die um das zwei- bis fünffache verbesserte Gesamtperformance. Möglich wird dies unter Anderem durch die Dalvik VM Just in Time Compiler. Aber auch bestimmte Anwendungen werden schneller. So profitiert der Browser bei Android 2.2 Froyo von einer verbesserten V8 Engine, die ein schnelleres Laden von Webseiten mit JavaScript ermöglichen soll. Aber auch sonst hat sich viel getan. Neu auf dem Homescreen ist ein Tipp-Widget, das neuen Usern eine schnelle Einarbeitung garantieren soll.
Quelle: google.com
Ebenfalls neu auf dem Homescreen sind die drei Buttons für Telefon, Launcher und Browser, die von allen Homescreens erreichbar sein werden. Überarbeitet wurden auch die Galerie und die Bedienung der Kamera. Künftig wird es zudem auch möglich sein einen LED Blitz bei Video-Aufnahmen zu zuschalten. Interessant ist auch die neue Option des portablen Hotspots. Mit diesem können bis zu acht verschiedene Geräte, wie PCs, Tablets oder andere Smartphones, die über Wlan mit einem Handy mit Android 2.2 Froyo verbunden sind, gleichzeitig über das Android Handy ins Internet.
Auch für Entwickler bieten sich neue Möglichkeiten. Über eine neue Schnittstelle sind so zum Beispiel Push Nachrichten auf das Android Handy möglich, Anwendungen können künftig auch auf der SD Karte installiert oder in den Backup Manager integriert werden. Eine gute Nachricht gibt es auch für die User, die Android wegen des Flash-Supports gegenüber dem iPhone OS vorziehen: Android 2.2 Froyo wird künftig volle Flash 10.1 Unterstützung bieten.
Wird auf dem Desire leider nicht funktionieren.
darf man fragen wieso du glaubst dass es nicht klappt?^^
weil das das update fürs nexus one ist?
wie kommst du auf die idee, dass das funktionieren könnte?
Bitte den Thread am besten löschen sonst tut sich ja echt noch wer die arbeit an und macht den blödsinn, evtl ruiniert er dann auch noch was dabei...
Es gibt schon den einen oder anderen der es probiert hat, bei xda glaube ich gibts auch so nen halben 2.2 rom port für das desire. Testen würde ich es aber auch noch nicht
Thyrion
Thyrion
elch
elch
elch
mtemp
mtemp
mtemp
