Captiva 10 Zoll Dump und Anleitung
Schnapz
12
Anbei eine kleine Anleitung wie ich es gelöst habe, da das zweite Tablet nicht mehr starten wollte.
Captiva 10 Inch Tablet
Modell CAPTIVA PAD 10
Android: 4.1.1
Kernel Version: 3.0.8+ lsd@zed-server3 #29
Build-Number: RK30_ANDROID4.1.1-SDK-v1.00.00
ruifu_V2.60.20121105.dc72a7b
Well i did a dump from the Captiva 10 Inch Tablet. We had two, one died so we did a dump from the working one and put it back to the dead one and it is working again.
So now I want to share with you, how it worked for me, and of course the working system dump.
So if one Captiva Tablet isn’t working anymore turn it off.
After that do the following steps:
1. Load the 7-Zip file and extract it.
2. After that turn off the Captiva tablet.
3. Insert a Micro USB cable in your computer.
4. Hold Vol+ and put in the Micro USB cable in the USB Port on tablet side (not the “Host” port).
Now Windows should try to find a driver for the new unknown device.
5. So open up the device manager of your Windows system.
6. Right klick on the Unknown Device and update the driver manually.
You will find the driver in the Android Tool Folder which is included in the downloaded File.
Depending on your local Windows take the x86 or x64 driver.
7. After you installed the driver manually, you should see the device as a new class usb device, in this case “rockusb device” or like “rk30sdk”.
8. Next step is to open the “AndroidTool.exe”.
1-jpg.503344
9. The bottom should display “Found One LOADER Device”.
10. You need to deactivate the “Loader”, “Resoruce” and “Parameter” in the Tool.
11. Next you change the path of “Kernel”, “Boot”, “Misc”, “Recovery” and “System”.
12. Just doubleclick on the Path to change it manually or click on the right field of the changing part and a pop-up windows displays your windows explorer, so you get manually the way through the explorer to the extracted file from our downloaded file.
2-jpg.503345
13. I deleted the not necessary parts in my example. Even don’t wonder of the “No devices found”, because I did connect the captiva tablet to my computer for the tutorial.
14. After you changed everything like on my screenshot (Folderpaths can be different), click on “RUN”.
15. The tool will copy every IMG to the tablet.
16. After it finished your tablet should start again.
17. Please disconnect it from the USB cable.
18. Turn the Tablet off.
19. Hold the Vol+ and put in the Power Adapter.
20. Still Hold Vol+ and Push the Power Button.
21. The Tablet should start into Recovery. If there is an android with a red Triangle – You are in the recovery mode. If not, try again.
22. To go on push Power Button and Vol+ one time together.
23. The menu of the recovery should appear and just go to “Wipe Factory Reset” with the Vol+ and Vol- Button.
24. Press the Power button for Enter the Factory Reset.
25. Accept the Reset.
26. After that Reboot System.
27. Congrats. The Tablet should start normally.
Download: Neuer Ordner.7z (206,86 MB) - uploaded.net
Name: Neuer Ordner.7z - 212 MB
No Password
Hoffe Englisch ist ok, wenn nicht übersetz ich das nochmal. Habs nur so gemacht damit auch andere die Anleitung verstehen falls sie nach den Schlagworten suchen.
Keine Garantie oder Gewähr !
Themen/Beiträge in deutsch:
Wir sind ein deutschsprachiges Forum, weshalb auch alle Beiträge und Themen in deutsch zu verfassen sind. In Ausnahmefällen (z.B. dann wenn die Übersetzung durch technische Hilfsmittel erfolgt ist und daher Fehler bzw. Missverständnisse zu erwarten sind) kann der original- bzw. englischsprachige Text beigefügt werden.
Wichtig - Bitte lesen: Android-Hilfe.de Forenregeln / Verhaltenstipps für Mitglieder
Und bei copy&paste von fremden Texten ist die Quelle zu nennen.
Hier nochmal auf Deutsch was zu machen ist, Links sind oben:
1. Laden Sie das 7-Zip-Datei und entpacken Sie es.
2. Danach das Captiva Tablet auszuschalten.
3. Ein Micro-USB-Kabel an in Ihrem Computer anschliessen.
4. Halten Sie Vol + gedrückt und stecken Sie das Micro-USB-Kabel in den USB-Anschluss an der Tablet-Seite (nicht in den "Host" Port).
Nun sollte Windows verushcen einen Treiber für das neue unbekannte Gerät zu finden.
5. Also den Geräte-Manager Ihres Windows-Systems öffnen.
6.. Rechts Klick auf das unbekannte Gerät und den Treiber manuell aktualisieren.
Sie werden den Treiber im Android-Tool-Ordner finden, die in der heruntergeladenen Datei enthalten ist.
Je nach lokalen Windows nehmen Sie die x86 oder x64-Treiber.
7. Nachdem Sie die Treiber manuell installiert haben, sollten Sie das Gerät als eine neue USB-Klasse im Gerätemanager finden, in diesem Fall "rockusb Gerät" oder wie "rk30sdk" zu sehen.
8. Der nächste Schritt ist die "AndroidTool.exe" zu öffnen.
9. Im unteren Teil sollte "Found One LOADER Device" angezeigt werden.
10. Sie müssen die "Loader", "Resoruce" und "Parameter" im Tool deaktivieren.
11. Als nächstes ändern Sie den Pfad der "Kernel", "Boot", "Misc", "Recovery" und "System".
12. doppelklicken Sie auf den Pfad um diesen manuell zu ändern, oder klicken Sie auf das rechte Feld des vorgegebenen Pfads unterhalb der 3 Punkte und ein Pop-up-Fenster zeigt Ihren Windows-Explorer, so erhalten Sie manuell den Weg durch den Explorer auf die extrahierte Datei aus unserer Download-Datei.
13. Ich löschte die nicht benötigten Teile in meinem Beispiel. In meine Beispiel wird auch angezeigt, dass kein Tablet vorhanden ist, da ich es nicht angeschlossen habe.
14. Nachdem Sie alles wie auf meinem Screenshot geändert haben (Ordnerpfade können unterschiedlich sein), klicken Sie auf "RUN".
15. Das Tool wird alle IMG an das Tablet kopiert.
16. Nachdem dies kopiert wurde sollte das Tablet neustarten.
17. Bitte trennen Sie es vom USB-Kabel.
18. Schalten Sie das Tablet aus.
19. Halten Sie die Vol + gedrückt und schliessen Sie das Netzteil an.
20. Noch die Vol + Taste Halten und die Power-Taste drücken einmal drücken damit das Tablet startet.
21. Es sollte im Recovery Modus starten starten. Wenn es ein Android mit einem roten Dreieck ist = Recovery-Modus. Wenn nicht, versuchen Sie es erneut.
22. Nun den Power-Knopf und Vol + einmal zusammen drücken.
23. Das Menü sollte angezeigt werden und gehen Sie einfach auf "Wipe Factory Reset" mit der Vol + bzw Vol-.
24. Drücken Sie die Power-Taste für um die Werkseinstellungen zu bestötigen
25. Wieder den Reset mit YES bestätigen.
26. Nach diesem Schritt über das Recovery Menü das System rebooten.
27. Glückwunsch. Das Tablet sollte normal starten.
Ich übernehme keine Haftung, Garantie, etc. Es erfolgt alles auf eigenem Riskio.
Der Original-Thread findet sich bei den XDA-Developers unter [Dump] Captiva 10 Inch Tablet
Leider ist hier wie dort die Datei mit dem Dump nicht mehr herunterladbar (verständlich, denn im Internetzeitalter ist ein Jahr mehr als eine Ewigkeit :-o )
Hat jemand zufällig diese Datei noch irgendwo herumliegen?
Vielen Dank schon mal im Voraus und beste Grüße
DAC324
  • WikoFan400
WikoFan400
proph3t
  • hmtriebler
hmtriebler
