[HELP] [TRANSLATION] Kitchen Timer
JD82
Hi, I'm the developer of Kitchen Timer
Is a little free and open source app.
Screenshots and sources: kitchentimer - Project Hosting on Google Code
Stats: Kitchen Timer - Cyrket
I would ask your help to translate my application in German language.
Kitchen Timer is easy to translate, simply apply for access to this site (specify German in Personal note): Kitchen Timer | String. | myGengo
If you prefer you can directly translate the file strings.xml available at this address:
strings.xml - kitchentimer - Project Hosting on Google Code
Is not very long, will be a hundred sentences, almost all very short.
Thank you
Roberto
maikfr
  • 67027
67027
knuckles
knuckles
knuckles
