[KERNEL] Bulletproof | S2W | FIOPS | Intellidemand | battery life
Kevin336
Auf meine letzten Tage mit dem One S gibts wieder einen neuen CustomKernel.
siehe auch bei XDA -> klick mich
Bulletproof Kernel
for Sense-based Jelly Bean ROMs
This is a stockish kernel optimized for speed, stability and battery life with
a few added features like sweep2wake, NTFS, and higher refresh rate for HDMI output.
There is no overclocking or voltage adjustments, no scripts running at boot and no
installer options. It should just work.
Code:
* Standard disclaimer:
* Your warranty is now void.  Use at your own risk.
* In other words: It is your choice to use this software,
* I am not responsible for any damage or problems!
FEATURES:
  • based on HTC Jelly Bean source code 3.16
  • Aroma installer (coming soon)
  • optimized for extended battery life
  • sweep2wake
  • /system writable (but not yet mounted r/w, coming soon)
  • NTFS r/w support
  • intellidemand (default governor)
  • FIOPS (default i/o scheduler)
  • increased refresh rate for HDMI output via MHL adapter
INSTALLATION
1. Install zip from TWRP Recovery
2. Reboot!
S-OFF recommended for easy installation
NOTES
Elemental-S-JB-2.5
The modules from the Elemental kernel will probably still work with this, use at your own risk. If you have previously installed Elemental, I recommend deleting /etc/init.d/99elementalx. Later I will make a proper installer that deletes all conflicting files.
Sweep2wake
To use sweep2wake, make sure it is enabled. It can be enabled using Kernel Tuner or Venom Tweaks, or by typing:
echo 1 > /sys/android_touch/sweep2wake
Special thanks:
showp-1984 for S2W
Source:
Bulletproof-1.0
CHANGELOG:
Mai 26, 2013 - Bulletproof-1.4
-add doubletap2wake
-add button light notification
-fix fm radio
-remove autogroup: group by current UID
-arm/crypto: Add optimized AES and SHA1 routines
April 13, 2013 - Bulletproof-1.3
-force fastcharge
-force ac for unknown chargers
-ROW (default scheduler)
-enable automatic process group scheduling
-switch do_fsync() to fget_light()
-use glibc string
-use glibc memcpy
-WiFi module fix (thanks thicklizard)
-various patches from ElementalX
March 6, 2013 - Bulletproof-1.1
-add aroma installer
-fix min/max frequencies
-make sure intellidemand sticks
-automatically delete conflicting files from Elemental-S-JB-v2.5
March 5, 2013 - Bulletproof-1.0
-based on HTC source code 3.16
-intellidemand default governor
-fiops default scheduler
-add sweep2wake
-init.d support
-ntfs r/w support
-fix HDMI refresh rate
-xz kernel compression
-arm cpu topology
-disable system write protection
-add fix for crash when wp_mod.ko loaded
-update cpupower according to cpu load
-adjust readahead to 2048
DOWNLOAD
Bulletproof-S-1.4[/SIZE]​
Reaktionen: Murph und Nobbell
Bulletproof 1.1 funktioniert bei mir bis jetzt tadellos. :)
Nur die ZIP im TWRP 2.4.2.0 geflasht
OneS/S4/S-OFF
Viper 2.1.0
Radio 1.11.50.05.28_10.27.50.08L
bei mir saugt JB sowas von am Akku... ob Stock, Elemental oder dieser Kernel... je nach nutzung 15-20h maximal.
ViperOneS 1.2.1 mit Zarboz Kernel auch gerne mal über 1 Tag.. selbe Apps, selbe Einstellungen... :/
Mehr wirst auch nicht rausholen können.
Gesendet von meinem HTC One S mit Tapatalk 2
Androphon von hier hatte 2,5 Tage mit dem Stock kernel ^^
benötigt man S-off für was?
nein. geht auch mit s-on
gesendet von meinem HTC One S powered by ViperOneS
Mmh ich komme vom Stock Viper Kernel, habe ihn geflasht installer läuft auch durch ohne Fehler allerdings hatte ich dann eine reeboot schleife
Muß man bei S-on vielleicht das Boot.img noch über Fastboot usb nachflashen?
Nachdem ich die Viper Rom nun nochmal installiert habe und bei der installation ausgewählt habe das ich einen costum Kernel verwende, funktioniert der Kernel
so nachdem ich nun am laufen habe, kommen auch die ersten Fragen.
Es sollte doch als default der intellidemand laufen, wenn ich aber in den Tweaks nachschaue steht es dort auf ondemand. Kann dort aber auf intellidemand umstellen.
Ist das korrekt so?
Gilt diese einstellung wenn ich sie über die Tweaks mache dann für beide CPU´s?
oder benötigt man den Kerneltuner um auch die 2te Cpu einzustellen?
Der ursprüngliche Beitrag von 09:42 Uhr wurde um 09:43 Uhr ergänzt:
Sehe ich es richtig das der unterschied zum EmlementalX darin besteht das man nix an freq und voltage veränder kann?
Welchen von beiden Kernel würdet ihr empfehlen?
was ist schon normal ^^
bei mir ist hin und wieder auch ein anderer governor eingestellt als der default.
einfach mit dem kernel tuner umstellen (Venom tweaks stellt nur 1 CPU)
richtig.. der bulletproof ist mehr stock und lt. dev 100% stabil, der Element hat die OC/UV/.. Tweaks
ich bin wieder zurück zum Elemental, da er meiner meinung besser mit meinen settings läuft
bin ich echt zu blöd zum flashen oder warum bekomm ich andauernd eine bootschleife nach flashen des kernels ?? ich bin S-ON ..
versuch mal folgendes:
entpack die boot.img. ist im Verzeichniss boot. flash diese per fastboot, danach flasht du den kernel ganz normal. so werden die module des kernels installiert
schon probiert, aber alle guten dinge sind 24 ... hab jz den elemental mal probiert aber bei dem funktioniert s2w bei mir nicht ... ich will doch nur dass dieser funktioniert :/
hat nun funktioniert, habe direkt nach dem elemental den bulletproof geflasht und er funkt jetzt ;)
hat dieser kernel sweep2sleep nicht ?
edit ... sweep2sleep funkt bei mir nur sporadisch
gut.. ansonsten hätte ich noch nen anderen vorschlag gehabt.
mit der app Flash Image GUI die boot.img flashen, reboot in die recovery und den kernel flashen
http://goo.gl/T6GsJ
ne läuft schon danke :))
beim sweep2sleep geht er bei mir oft ins multitasking menü weil es nicht richtig funktionieren will :/
bin derzeit auf dem elementaX 3.3 und möchte zurück auf den Bulletproof, der läßt sich auch flashen jedoch geht mein WLan dann nicht mehr.
auch das vorherige flashen des boot.img über fastboot bringt nichts.
Kann da jemand helfen?
Habe irgendwas davon gelesen dass du Dateien vom elemental löschen musst
Macht die Version 1.1 selbst
Aber auch das habe ich kontrolliert die besagte Datei ist weg so wie es sein soll
Hab es gelöst
Man muß das wifi Modul löschen welches der Elementx Kernel installiert und auf das Stock Modul wechseln dann geht auch der bulletprof wieder
Hopie
Hopie
  • BeardNinja
BeardNinja
Chris6057
