[Rom][28/5] SD V20.1 ULTIMATE | 4.18.401.2 | SD SOUND| SD HUB | APM| EQS| Batt%|Hi5
Touchscreen-Lover1
Touchscreen-Lover1
Enthusiast
530
Hier nochmal auch ne sehr gute und gelungene Rom,vorallem der Bass ist super wegen dem One Sound :)
All Credits to the SkyDragon Team on xda-developers.de!!
Please, take 2 minutes to read below
New!!! 12-4-13
Rom Base on last Ota Firmware 4.18.401.2 using a System Dump All Credits and Thanks To Patensas:laugh:
And Also Credits to Mike cause his system Dump
For Hboot 1.31, 1.33, 1.36 & 1.39
  • Download Rom From Main link or mirrors
  • Flash Boot.img via CMD/PC
  • Install Rom Via Recovery
  • Follow Aroma Instructions
  • Done!
IMPORTANT
Dont Forget to Visit Xcesco89 Thread for Discussing CustomSettings App feedback!!!
Also Thanks Him and all!!!
Click ME
Code:
Das warten hat ein Ende
SD V 20.1 ULTIMATE is OUT!!!!
# Based on 4.18.401.2
# Made From Scratch
# De-Odexed
# Rooted
# Zipaligned
# Nano Text Editor
# Bash Shell
# Removed Bloatware
# Added Aroma Installer
# Now Aroma remember your last Setting ( Thanks to Thunder07 )
# New Feature SKYDRAGON HUB ( Thanks to Xcesco89 )
(Find our skins, Mod, wallpapers, News and More)
# Build.prop Wicked tweaks
# Cleaned build.prop
# Updated OEM apps
# Updated hosts for ad blocking
# Removed CID language restrictions
# Added Superuser
# Stock Kernel
AND MORE
Check OP
Soon hub will be updated!!!!
Cheers and Happy flashing!!!
Htcfanboys.com Thanks to Patensas
Click Me
Md5 Ckecksum
Md5 checksum : c89ebd8ae2edaab3923c88700280b4e3
SkyDragon V 18.6 ULTIMATE!!! New!!! 28-May-2013
# Made from scratch ( Not Beta Base )
# Firmware 3.20.401.3
# Rooted ( SuperSu )
# Busybox
# Deodexed
# Zipaligned
# MultiLanguages
# Stock Kernel
# New Aroma Configuration
# Updated SD Sound Mod with Sense 4.2.2 Leak files
( Credits To MenAllocatoR )
# Tweaked for Performace and Battery life
# New Sense Skin As Stock ( Credits to Patensas )
# HTC One Ringtones set as Stock in Build.prop
# HTC One Font as Stock
# HTC Sense 4.2.2 leak files Wallpaper as Stock
# HTC One Icons as Stock
# HIDEF Icons in Notification Bar as Stock ( Credits to Laypota/ Sebastiaan )
# HTC Sense 5 Battery Mod as Stock
# Htc Sense 5 themed look Keyboard as Stock
# SD HuB, Parandroid Halo, Weather Notification, GSam Battery, Titanium Backup, Ex Explorer and Adaway
# and.. More
Download:
http://htcfanboys.com/download/paten...list&file=5081
http://www.mijnbestand.nl/Bestand-WCYB8TQUYUT4.zip
https://mega.co.nz/#!3sYFkT4D!PdAyym...UfW-PKfkTJOzpw
https://docs.google.com/file/d/0BzFn.../preview?pli=1
SkyDragon V 14.0 ULTIMATE!!! 23.4.2013!!!
# Re Based To latest HTC Firmware 3.20.401.1
# Stock Kernel
# Ported all Mods and Tweaks presented in SD roms
# Rooted
# Busybox Prenset
# Zipalinged
# Deodexed
# sysro/sysrw
# NAno Editor
# Bash
# Added Patensas Theme 5 Keyboard
# Added Wicked build.prop Tweaks
# Updated OEM apps
# Added New free apps as Notification weahter Free and Gsam Batt Stats Free
# And More ( I was Rushing as Hell!!! )
[Hide]
SkyDragon V 13 ULTIMATE!!!
Omitted Release, Bad lucky number
SkyDragon V 12.2 ULTIMATE!!!
# Fixed Chipmunks bug ( credits to MemAllocator )
# Added Additional build.prop tweaks
# Added Themed Keyboard ( Adjusted Sense 5 Style by Patensas )
# Added Incall recording option ( on request )
# Things we forgot ( late night work!!! )
[B]IMPORTANT:[/B] You need to flash first SD V 12.1 FIRST if coming from another ROM!!!
SkyDragon V 12.1 ULTIMATE!!!
# Re Based ( Still 3.19 )
# New Kernal XM #289 latest beta ( if there is one latest )
# Updated HTC ONE Sound Mod
# New Ramdisk
# Updated Sound Mod to latest ( Check Screenshots in OP )
# Clean Build.prop tweaks and added Wicked ones
# Updated OEM apps
# Removed Custom Settings apk
# Removed Lux Lite Dash
# Added Trickster Mod apk
#Added Whatsapp ( You should be registered, so delete original and use Whatsapp Plus )
# Things i forgot ( late night work!!! )
SkyDragon V 11.1 ULTIMATE!!!
Stock kernel
New Ramdisk
Patched services.jar
Supercharged with unsp build.prop for reverting with v6
Fixed Friendstream
EQS Location option added to Aroma installer
Lockscreen style options added to Aroma installer
Fixed missing languages
Added missing Whatsapp
New Sense 5 Wallpaper
Cleaned some build.prop lines
New tweaks for better battery and performance
Fixed default alarm and notification sounds
Added Custom Settings app
Updated Playstore apps
Minor fixes for stability
Added Patensas to Team Member!!!:p
SkyDragon V 11.0.1 ULTIMATE!!!
  INITIAL RELEASE
New Build base 3.19.401.1
Made From scratch using Dsixda kitchen
Ported most of the V 9.0 Goodies to the new base
Added HTC ONE ringtones and sounds
Custom HTC ONE walppaper
Stock Kernel for now
and more
SkyDragon V 10.1 ULTIMATE!!!
Made From Scratch
Fixed tweaks in Build.Prop
Added MX #281 Kernel
Fixed EQS Vertical Lag
Fixed Aroma Font
Fixed Aroma Non uninstalling of some Apps
Small Details and things I forgot
Still V 9 Changelog present
SkyDragon V 9.0 ULTIMATE!!!
-Full Wipe/ Without Wipe
-Mods
 #Remove HTC Sense
 #Force Gpu Rendering
 #Disable 3-Dot Menu
 #Disable Exchange Mail Security
 #Enable SQLite Support
 #Remove Boot Sound
-Option To Remove Apps
-Option To Remove KeyBoards
-Option To Install KeyBoards
 #HTC Vietnamese IMEI
 #Android AOSP KeyBoard
 #Arabic KeyBoard
-Option To Add Battery Skin
-Option to Select Rosie Mod
 #Stock
 #5*5 7*3 Landscape
 #5*6 8*4 Landscape
-Option to Add APM Skin
 #Stock
 #AOSP
 #Sense 5
 #Blue-Shift
-Option to Select Common Resouerces
 #Sense 4
 #Sense 5
-Option To Select UI Animation
-Option To Select System Fonts
-Option To Select StatusBar Transparancy Level
 #Stock
 #Transparent Full
-Option To Select Widgets
 #Stock
 #Semi Transparent
 #Fully Transparent
Moved Additional  Keyboards to Aroma Options
Added Whatsapp
Added Tethering app
Added CustonSettings 1.2.0
Fixed Aroma Mistype
Added Option To Removed Boot Sound
Updated XM 280 Kernel
Added Wifi Fix By JoiWong
Full Multilang Including Chinese, Vietnam and More
Added Arabic Keyboard
Updated ONE Sound Mod
Updated Lapotia Mods to the Latest
Updated 3rd Party Apps
FriendSteam Should work now
And more
SkyDragon V 8.2 ULTIMATE!!!
Added Official Skydragon Theme
Add Ncx #26 kernel
Updated Htc One Sound
Added New sense 5 Battery skin
AppDrawer 5x6/8x4
Added Custom Wallpaper Sense 5
AOSP Animations
Ubuntu Fonts
SemiTransparent Widgets and NavBar
Updated Laypota Xtrim Cam Mod
Updated OEM apps
Minor fixes
 SkyDragon V 8.1 ULTIMATE!!!
Added HTC ONE Sound Mod
Added HTC ONE Ringtones and Sounds
Added HTC ONE Fonts
Added HTC ONE icons and Pngs inside Apps
Added Nes Custom HTC ONE Wallpaper, my choice!!!
re Zipaligned and optimized!!!
Added titanium Back up
SkyDragon V 8.0 ULTIMATE!!!
Initial Release
[/Hide]
- Patensas for his Aroma skilz and More
- Nash for his skins/Full Themes
- Hassan89 for all his magic
- MenAllocator for his Music Mod
- Laypotia for his mods and help
- Xcesco89 for his widgets and CS Apk
- Fisha and Ill Duce Best Sense Themer in XDA
- Jarein For his Great Sense 5 mod
- SkyDragon FULL Team
- SkyDragon Betatesters
- Our Family for the time we take away from them
- And all Xda-Dev and Skydragon user.
- If i forget somebody pm Mehh.
SkyDragon V 14.0 ULTIMATE!!! New 23.04.2013
Click Me
MEGA.CO.NZ REPACK FOLDER By Axbaquero Click
DROPBOX REPACK FOLDER By Jeryx SD v 12.1
Rotemkk
MauryDes x5
Exocetdj
Kalimpula1
Jeryx
Vette95
xSilv85
BeanBean50
Thedonk13
Amirage
Forster
Dragonesdenano (Leader/Chef/GranPa)
Nashshafrulrezza (Themer/AllInOne)
Patensas(AllInOne)
Hassan89 (Java/Mods)
Xcesco89 (Themer)
Jeryx (Betatester/Assistent)
Kali (Spinning/Tractor/Betatester)
Maury (Betatester/GraphicX)
Debaki (Chef)
MenAllocatoR ( sound Man/ Mods )
geenyouz (Themer)
Joewong1991 (Chef/Rerited)
ExocetDJ (Father/Betatester)
MaartenXDA (Desire X Chef)
Guich (Themer/ Student of English)
Forster (Betatester/GranPa)
Jarein( Mods/3gPlan)
Axbaquero(Tester/GoogleFisher)
GraveDigger176(HardMEtal)
sciffietrekkie(Trekkie)
xSIL85(Videos)
Thedonk13(Betatester/Helper)
Vette95(BetaTester/Helper/Mi pana)
codexc(Web Designer)His Web
Teejayd(Betatester)
Skydragon Thread Links
Skydragon Base 3.19 Skins By Nash And Patensas
New
Click
Skydragon Theme Thread
Click ME
Skydragon Repacks
Click ME
Skydragon Ultimate
Click ME
Skydragon Hellfire
Click ME
Skydragon xpartacus
Click ME
Skydragon Poseidon
Click ME
Viel Spaß beim Flashen :)
Reaktionen: Schaeferreiner und cappuccina
Ich hatte es die letzten Tage auch mal kurz installiert. Gefällt mir grundsätzlich nicht schlecht, aber die beworbenen Sound-Tweaks halten nicht das, was sie versprechen. In der Abstimmung finde ich es weniger flüssig als das NikProjekt-Rom, aber sicher ist es eine Alternative auf dem Rom-Markt. Wird ja vom Rom-Koch mit ähnlich viel Tam Tam wie ViperX beworben...da muss man bei XDA natürlich auch an die Donations denken, die schonmal hin und wieder gute Erträge bringen.
Also ich finde dass dieses Rom schon Sehr flüssig ist,hab es immer wieder seit Version 10 in Abwechslung mit anderen Roms gehabt und fande gerade die Entwicklung sehr interessant :)
Aber jedem das seine,das Nik Project hatte ich jetzt noch nicht drauf,will es aber auch mal antesten die Tage...
Lg Ardi :)
✪ Sent from my ✪ ★ One™X ★
Du hast recht, im Gegensatz zum Stock-Rom ist das Skydragon-Rom deutlich flüssiger. Es ist auch wirklich ein schönes Rom. Wenn du allerdings NikProjekt in der richtigen Konfiguration drauf hast merkst du, wie butterweich JellyBean wirklich sein kann. Aber das sind dann trotzdem nur Millisekunden...letzten Endes ist doch das Bauchgefühl für ein bestimmtes Rom das Entscheidende, denn die geringe Zeitspanne, auf etwas mal warten zu müssen, bringt einen normalen Menschen nicht um. :scared:
Reaktionen: Touchscreen-Lover1
Eben aber wie gesagt: Jedem das seine :)
[/OT off]
LG Touchiiiii ;)
✪Sent from a Fandragorastic✪★One X★
One Sound was ist damit gemeint ?
Des ist ein Sound Mod,sie haben es AFAIK irgendwie hinbekommen einen Teil vom Sound des One zu "porten"
LG Touchiiiii ;)
Wobei man aber sagen muss das man überhaupt keinen Unterschied merkt.
Gesendet von meinem HTC One X mit Tapatalk 2
Bist du dir da sicher? Ich merke da schon was,besonders im Punkto Bass ;)
LG Touchiiiii ;)
Mal was zu der "Wischgeste" zum entsperren - habe das im EQS aktiviert. Jedoch ist die Funktion irgendwie etwas tricky oder ich blick`s einfach net.
Wische wie ein Bekloppter über den Screen und nichts entsperrt sich. Oder ist das generell nur die Funktion für das Bildschirmsperren Muster?
Dachte das ist wie bei der Viper unten die drei Buttons!?
Hat das jemand schon ausprobiert?
Gruß Dissy
Könntest du mal nen Screenshot posten? Ich glaub dass ist aber die normale Lockscreengeste. S2W geht aber afaik nicht mit dem Stockkernel den die Rom nutzt.Ich benutze den XM und da funktioniert alles:D
Lg Ardian :)
★ Sent from my ★ ✪ A210 ✪
Denke das sollte es doch sein... Stock Kernel und XM Alter Falter... das sind wieder Nägel, die Du da reinhaust...lol:confused2:
Irgendwas scheint da eh noch nicht ganz zu stimmen (siehe auch grüner Pfeil...) aber was soll`s :crying:
Gruß Dissy
Ja das ist Swipe to Wake. Schau auch mal unter Nutzer und Kernel Optionen. Oder in der App Trickster Mod. Sollte damit auch nichts funktionieren würde ich den XM nehmen da er bei mir keine Probleme macht
Lg Ardian :)
Danke Dir für Deine Hilfe erst Mal. Unter Kernel Optionen ist das leider grau und unter Trickster Mod finde ich nix passendes.:o
Das mit dem XM Dingenskirchen... ähhh wie mache ich das? Woher bekomme ich das und was am wichtigsten ist - kann man das wieder Rückgängig machen???:confused:
Link würde schon reichen - bin net lesefaul:p
Gruß Dissy
Supi... aber dachte immer, dass man das boot.img explizit aus der Rom verweden soll (muss)!?:eek::confused::rolleyes:
Ich wuerde das boot.img lieber Repacken,kuck mal im Dev Thread von der Skydragon Rom . Da hat Dragonesdenando in seiner Signatur den Repack Thread wo alles schon geklärt ist. D.H du musst in den Repack Thread gehn und dann in Dropbox den Ordner XM 188v4 anklicken und das boot.img flashen. Danach ganz normal die ganze zip im Recovery flashen.
LG Touchiiiii ;)
Der ursprüngliche Beitrag von 15:00 Uhr wurde um 15:03 Uhr ergänzt:
Hier der Link zum Dev-Thread http://forum.xda-developers.com/showthread.php?p=36920159
LG Touchiiiii ;)
Reaktionen: dispender
Neue Version ist da :)
SkyDragon V 15.0 ULTIMATE!!! New 27.4.2013!!!
# Based on 3.20.401.1
# De-Odexed
# Rooted
# Zipaligned
# Removed Bloatware
# Added PureX Sound Mod
# Added EQS ( thanks to Lyapota )
# Build.prop tweaks
# Updated OEM apps
# Added New Sense Skin
# Reworked Sense 5 lockscreen
# Added Black Playstore ( credit to gerardroid )
# Added Black Google Now ( credit to gerardroid )
# Added Black Youtube ( credit to gerardroid )
Download: http://htcfanboys.com/download/patensas/?action=list&file=2893
Md5 : 246e361791c920c792db9df7687218c3
Viel Spaß beim Flashen :D
LG Touchiiiii ;)
Braucht das ein Full wipe oder kann man das einfach drüber bügeln???
Brauche sonst demnächst einen Full wipe Button:p
Gruß Dissy
Nein Am besten einfach davor wipe Cache und Dalvik cache das sollte reichen :) hier mal ein Paar screens :) Die schrift ist glaub die unter Comicsans
LG Touchiiiii ;)
Schubbie
DnT
redybull
redybull
Palindrom
Palindrom
