1. FotoMichi, 09.05.2012 #1
    FotoMichi
    FotoMichi Threadstarter Erfahrener Benutzer
    ZetaROM CLASSIC Theme STOCK v2.0 - XWLPD 4.0.3-------SOON THEME ZETA
    INFO´S HIER--->http://translate.google.com/translate?langpair=it%7Cde&u=http://zetaserie.blogspot.it/
    DOWNLOAD 2.0 Classic:https://www.wuala.com/davidez25/Documenti/ZetaROM%20CLASSIC%20v2.0%20-%20GT-I9100_LPD_4.0.3.zip/?key=PBv7GFnOTwtV
    Changelog:
    LP5 Modem - Kernel Siyah v. 3.2.5.1 + cwm manager
    Rooted - Busybox - Deodexed - NO WIPE - Zipaligned Cars - Hosts Adblocking
    Improved Touch Sensitivity - GPU Acceleration
    WiFi tweak saving battery - Scrolling improved responsiveness
    SONY BRAVIA: Increase the quality of photos and video
    Modified Dalvik VM 180MB heap size
    The user interface rendering with GPU
    Internet connection ottimizzat - Fewer delays in calls
    Sensor Screen Delay off - Memory management improved
    Added Power Panel: Reboot - Download - Hot boot
    MicroSD Card speed 1024KB / s
    Market connections Fix Speed
    Switch-off the camera when the battery charge 0%
    Video / audio profiles 24-20Mbps/192Kbps_44100Hz
    Disabled increased volume for incoming calls
    Removal of the options for reducing noise in call
    Off SMS to MMS - no autoconversion
    Deactivated limit number of contacts for the simultaneous sending
    Increase the maximum size of messages sent with 300 KB to 1 MB
    Increase the response speed automatic brightness control (ABC)
    Faster and smoother transitions of brightness (ABC)
    Custom Brightness - static bus frequencies
    DeepSleep custom levels - Tweaks GPS - Tweaks WIFI/3G/4G
    AutoBackup EFS Folder - YoutubeHD Mod (Wifi-3G) - Mod LockScreen
    Tweak your SD card for added control features: Lock Screen:
    ICS / SAMSUNG
    Text display screen unlock: ON / OFF
    Torch lock screen when you press the home button: ON / OFF
    Delay action to pressure the home button: ON / OFF
    Changed Sound Power - Added pach font characters
    Call Recording no Full Screen
    15 toggles the status bar + battery percentage %
    Silent Camera - eliminated sound battery
    Mod. Play Store
    Other extras: Audio Beats with a better sound quality and power thanks to app volume + - youtube hd that is 3g wifi and much more ....
    Added apk:Touchwiz Galaxy S3, 80 pack font, SwiFTP, CMW Manager, FasterFix
    Added soung notification Galaxy S3
    [​IMG][​IMG]
    [​IMG][​IMG]
  2. Chris1996, 13.05.2012 #2
    Chris1996
    Chris1996 Android-Experte
    Werd der Rom mal ne Chance geben obwohl (!) Ich aosp / aokp Roms bevorzuge :D und ein Link zu xda - thread wäre nicht schlecht :thumbup:
  3. Scoty, 18.05.2012 #3
    Scoty
    Scoty Android-Ikone
    Super Rom, gefällt mir sogar besser als das GoA. Sehr smooth und das Theme ist klasse finde ich.
    soxian bedankt sich.
  4. soxian, 18.05.2012 #4
    soxian
    soxian Android-Lexikon
    Seit gestern auf der Suche nach einer neuen ROM? :p
    Flashsuchti *hihi*
  5. Scoty, 18.05.2012 #5
    Scoty
    Scoty Android-Ikone
    Ich habe die Lite Verison installiert und läuft bis jetzt mit dem Syiah Kernel sehr gut.
  6. debaki, 20.05.2012 #6
    debaki
    debaki Android-Lexikon
  7. FotoMichi, 23.05.2012 #7
    FotoMichi
    Neue Version Online!!!
    Changelog:
    ICS / SAMSUNG
    Mod. Play Store
    [​IMG]
    [​IMG]
    [​IMG]
  8. mecss, 23.05.2012 #8
    mecss
    mecss Ehrenmitglied
    Thread-Titel aktualisiert... ;)
    FotoMichi bedankt sich.
  9. Dr.Franz, 24.05.2012 #9
    Dr.Franz
    Dr.Franz Android-Guru
    Bin ich blind, oder gibt es wirklich keinen Download-Link?
  10. reneph, 24.05.2012 #10
    reneph
    reneph Android-Lexikon
  11. Dr.Franz, 24.05.2012 #11
    Dr.Franz
    Auch wenn ich blind bin, zu bloede um eine ROM zu finden bin ich nicht, sprich ich habe sie woanders gefunden.
    Aber ich scheine zu bloede zu sein um den LINK zu sehen den du reingestellt hast, also dieser hier
    ZetaROM SERIE
    ich finde den auf den vorherigen Seiten nicht
  12. debaki, 24.05.2012 #12
    debaki
    Dr.Franz bedankt sich.
  13. reneph, 24.05.2012 #13
    reneph
    Naja... 3 Posts vor deinem "bin ich blind?"-Post steht der XDA-Link... :ohmy:
  14. Scoty, 24.05.2012 #14
    Scoty
    Scoty Android-Ikone
    Hoffentlich kommt bald das Theme dazu. Sonst läuft das Rom sehr gut.
  15. debaki, 24.05.2012 #15
    debaki
    Naja man sollte schon in seinem thread im ersten post alles auf einmal haben, xda link und download link.^^
    Stell dir vor der thread hätte 200 seiten... Dann wäre es mies oder? :p
  16. reneph, 24.05.2012 #16
    reneph
    Natürlich, sag ich garnichts dagegen. Aber da der Thread bis dato nur 1 Seite hatte, hätte man ruhig die paar Posts lesen können :) So genug OT :o
  17. FotoMichi, 24.05.2012 #17
    FotoMichi
    sorry, vergessen :(
    downloadlink mit info´s hinzugefügt
  18. Dr.Franz, 25.05.2012 #18
    Dr.Franz
    Entschuldige mal bitte.
    Der XDA Link ist nicht unbedingt der Download Link, ich denke das sind wir in diesem Forum etwas komfortabler anrangiert und haben nicht jnur den Hinweis auf den Original Thread sondern auch den Downloadlink in der Vorstellungen einer neuen Costum ROM sprich Opener. Und wenn ich mir ROMs bei XDA anschauen will, dann geh ich sofort in dieses Forum und nutze nicht den Umweg ueber dieses hier. :D
    Aber hat sich ja erledigt mittlerweile
  19. mecss, 25.05.2012 #19
    mecss
    mecss Ehrenmitglied
    @FotoMichi,
    kannst du das bitte nachholen und am Besten in all deinen Threads. Ist Usus einfach strukturell der effektivste Weg...Danke... ;)
  20. FotoMichi, 25.05.2012 #20
    FotoMichi
    ZetaROM CLASSIC v2.0 - XWLPD Online!
    Infos und Download, siehe Post 1. Habe sie mal installiert, sieht sehr sehr schön aus! Alles auf Deutsch(!) läuft Stabil und Solide.
    Kann ich jedem nur empfehlen!
